您的位置:控制工程论坛网论坛 » 产品供求 » Rohde&Schwarz SMU200A 6G矢量信号发生器|罗德与施瓦茨|100kHz至2.2/3/
xiaogui0344
xiaogui0344   |   当前状态:在线
总积分:516  2025年可用积分:0
最后登录时间: 2013-06-27
空间 发短消息加为好友
xiaogui0344  发表于 2011/11/25 15:27:32      688 查看 0 回复  [上一主题]  [下一主题]
手机阅读
产品介绍
Rohde &Schwarz SMU200A
Vector SignalGenerator
The new Vector Signal Generator from Rohde andSchwarz SMU200A is designed to meetall requirements encountered in research and of moderncommunication systems as well as in their production. The Rohde andSchwarz SMU200A not only combines up to two independent signalgenerators in one cabinet of only four height units, it also offersunrivalled RF and baseband characteristics.
The modern, intuitive concept of the R&S SMU200Aensures fast and easy operation.
Features andBenefits:
Up to twosignal generators in one
  • Frequency options from 100 kHz to2.2/3/4/6 GHz for the first RF path
  • Optional second RF path up to 2.2 GHzor 3 GHz
  • Up to two complete basebandpaths
Outstanding signal quality
  • I/Q modulator with 200 MHz RF bandwidth
  • Very low SSB phase noise of typ. ?135 dBc (f = 1GHz, 20 kHz carrier offset, 1 Hz measurement bandwidth)
  • Wideband noise of typ. ?153 dBc (CW, f = 1 GHz,>10 MHz carrier offset, 1 Hz measurement bandwidth)
  • Excellent ACLR of typically +70 dB for 3GPP FDD
  • Very high level repeatability of 0.05 dB
Unrivalled flexibility
  • Baseband generator with universal coder forrealtime signal generation
  • Arbitrary waveform generator with up to 64MSamples
Intuitive operation
  • Intuitive user interface withgraphical display of signal flow (block diagram)
  • Context-sensitive help system
Ideal for production
  • Very short frequency setting times(<3 ms); only 450 祍 in List mode
  • Electronic attenuator up to 6GHz over the full level range
Connectivity
  • Can beremote-controlled via GPIB and LAN
  • USB connectors for keyboard, mouse and memory stick
Modular design
  • Future Oriented
  • Owing to its modulardesign, the Rodhe and Schwarz SMU200A is a safe investment.
  • Options can be added at anytime. This concept allows the SMU200A to be tailored to specificapplications.
  • The user need not to payfor functions not required.
SMU200ACharacteristics:
Due to its modular design,the R&S SMU200A can be optimally adapted to the requirements ofdifferent applications. The first RF path can be equipped with oneof the four available frequency options. The upper frequency limitof 2.2 GHz / 3 GHz / 4 GHz or 6 GHz is user-selectable. In additiona second frequency RF path can be installed with upper frequencylimits of 2.2 GHz and 3 GHz.The lower frequency limit of allfrequency options is 100 kHz.
Up to two generators canalso be installed in the baseband section. They generate complexsignals in realtime and are equipped with an arbitrary waveformgenerator with up to 64 MSamples. The signals generated in thedifferent basebands can be added, even with frequencyoffsets.
List of Options Available for ROH SMU200A
B102 - RFPath A: 100kHz to 2.2 GHz K61 -Multicarrier CW Signal Generation
B103- RF Path A:100kHz to 3 GHz K11 - DigitalStandard IS-95 2
B104 - RF Path A:100kHz to 4 GHz K12 - DigitalStandard cdma2000 2
B106- RF Path A:100kHz to 6GHz K13 - DigitalStandard 3GPP TDD 2
B30- RF Path A:Overvoltage Protection K14 - DigitalStandard TD-SCDMA 2
B31 - RF Path A:High Power Output K15 -User-Defined OFDM Signals 2, 3
B32 - RF Path A:Overvoltage Protection and High Power Output K17 - DigitalStandard 1xEV-DO 2
B202 - RF Path B:100kHz to 2.2 GHz K19 - DigitalStandard IEEE 802.11 (a/b/g) 2
B203 - RF Path B:100kHz to 3 GHz K20 - DigitalStandard 3GPP FDD incl. HSDPA
B35 - RF Path B:Overvoltage Protection K5 - DigitalStandard Bluetooth
B36 - RF Path B:High Power Output B14 - FADINGSIMULATOR
B37 - RF Path B:Overvoltage Protection and High Power Output B15 - FADINGSIMULATOR Extension
B10 - BasebandGenerator with ARB (64 Msamples) and Digital Modulation K71 - EnhancedResolution and dynamic fading
B11 - BasebandGenerator with ARB (16 Msamples) and Digital Modulation K62 - AdditiveWhite Gaussian Noise (AWGN)
B13 - BasebandMain Module K80 - BER/BLERMeasurement
B16 -Differential I/Q out B81 - Rear pannelconnectors for 1st RF path
B17 - Analogbaseband input B82 - Rear pannelconnectors for 2nd RF path
K40 - DigitalStandard GSM / EDGE ZZA-411 - 19''Rack Adapter
K42 - DigitalStandard 3GPP FDD ZZA-T45 - Adapterfor Telescopic Sliders
K43 - 3GPP FDDenhanced MS/BS tests incl. HSDPA SMU-Z5 - BNCAdapter Board for AUX I/O connector
K44 - DigitalStandard GPS PSL-Z2 - Keyboardwith USB Interface (US assignment)
K46 -Digital Standard CDMA2000 incl. 1xEV-DV PSL-Z10 - Mousewith USB Interface, optical
K48 - DigitalStandard IEEE 802.11 (a/b/g) PSP-B6 - ExternalUSB CD-RW Drive
K49 - DigitalStandard IEEE 802.16
联系方式:深圳市嘉惠捷科技有限公司
联系人: 王R
手 机 :13715327187
客服QQ : 644842572
邮箱: wht19823@126.com
电话:86641139
公司网站:http://www.test-e.com/
公司地址:广东省深圳市南山区西丽留仙大道西丽蓝天花园山水阁13F
备注:
本公司长期低价销售!现金回收:租赁:网络分析仪、工厂报废仪器回收、无线综合测试仪、频谱分析仪、 视频图象信号源、LCR测试仪、高/低频信号源、示波器、万用表、电子负载、频率计、二手进口高挡仪器,等等二手仪器出售/维修/收购。有货请与我取得联系!迎来电咨询!13715327187
1楼 0 0 回复
