您的位置:控制工程论坛网论坛 » 产品供求 » Anritsu | MS8609A 数字移动无线发射机测试仪|日本安立|MS8609A|综合测试仪
xiaogui0344
xiaogui0344   |   当前状态:在线
总积分:516  2025年可用积分:0
最后登录时间: 2013-06-27
空间 发短消息加为好友
xiaogui0344  发表于 2011/11/26 12:15:17      751 查看 0 回复  [上一主题]  [下一主题]
手机阅读
如果您对该产品感兴趣的话,可以给我留言!现货供应,欢迎来电咨询!13715327187
详细介绍
品牌:日本安立 | Anritsu
产品简介
MS8609A 数字移动无线电发射机测试仪是一种配置有内部频谱分析仪,调制分析仪和功率分计的发射测试仪。 一台MS8609A数字式移动无线电发射机测试仪就可以完成基站的开发和制造,移动台的建设以及基站的维修保养.
频谱分析仪具有高达20MHz的分辨率带宽,这意味著该频谱分析仪能轻易的支持宽带信号的测量。
调制分析仪通过高速DSP实现了有矢量信号分析(VAS)功能。功率传感器通过采用不定形的功率传感器能完成达到+/- 0.4dB的高精度功率测量。
最多三种专用得测量软件(诸如 W-CDMA 和GSM/EDGE) 可以同时进行安装。输入信号可以选择通过RF或I/Q输入。 对于I/Q信号,也可以选择取平衡的或不平衡的输入信号。
MS8609A配置有GPIB,RS232C和10 Base-T(选件)接口,用于远程测量。高达120k byte/s的高速GPIB数据传输,使得制造生产 线实现了高速的测量。显示器采用易于浏览的6.5型TFT彩色LCD。
MS8608/09A Digital Radio Transmitter Testers
MS8608A and MS8609A are transmitter testers equipped with an internal spectrum analyzer, a modulation analyzer and a power meter. Just one tester can cover the development and manufacturing of base stations and mobile stations, as well as the construction and maintenance of base stations.
* MS8608A supports 9 kHz - 7.8 GHz and high power inputs up to +40 dBm.
* MS8609A supports 9 kHz - 13.2 GHz and input power up to +20 dBm.
The spectrum analyzer has resolution bandwidths up to 20 MHz, meaning that it can readily support measurements of wide-band signals. The modulation analyzer realizes all Vector Signal Analysis (VSA) functions through high-speed DSP. The power sensor can perform highly accurate power measurements of ±0.4 dB by using an amorphous power sensor.
Up to three measurement software options (such as W-CDMA, GSM/EDGE, HSDPA, WLAN/802.11, CDMA, 1xEVDO) can be installed simultaneously. Input signals can be selected from RF or I/Q inputs. For I/Q signals, balanced or unbalanced input can also be selected.
Each tester can be equipped with optional GPIB, RS-232C, and 10BASE-TEthernet interfaces for remote measurement. High-speed GPIB data transmission of 120 kbyte/sec enables high-speed measurement on the manufacturing line. The monitor uses an easy-to-see TFT color LCD.
Features & Benefits
* Excellent performance for evaluating W-CDMA modulation signals. This makes it ideal for the development and manufacture of W-CDMA radio transmitters (base station and mobile). GSM/EDGE, HSDPA, WLAN/802.11, CDMA, 1xEVDO, and Pi/4DQPSK (PHS, PDC, IS-136) measurements are also supported.
* The built-in spectrum analyser (standard) covers a resolution bandwidth of up to 20 MHz. It is ideal for evaluating devices such as base station power amplifiers, due to its wide dynamic ranges of 68 dB (typical for 5 MHz offset) and 75 dB (typical for 10 MHz offset) for adjacent channel power (ACP) measurement (sweep method). A new average detection mode permits high-accuracy measurement of signal power with this noise-like spreading modulation.
* The built-in power meter (standard) integrates an amorphous power sensor for high-accuracy (+-0.4 dB) power measurements.
* The installed MX860801A/MX860901A W-CDMA Measurement Software performs modulation and code domain analyses according to the 3GPP speculations for W-CDMA on both RF and I/Q signals. ACP Measurement (filter method) based on the 3GPP specifications is possible for RF input. Either balanced or unbalanced I/Q input can be selected.
* The MX860802A/MX860902A provides measurement of GSM/EDGE signals. Choose between GMSK and 8PSK modulation measurements. Modulation analysis functions include carrier frequency, frequency stability, RMS phase error, peak phase error and magnitude error. The software allows for the creation of constellation, eye, and trellis diagrams for detailed analysis.
* Up to 10 frames data after de-spreading can be stored for baseband data evaluation. With application software (sample provided) evaluation of demodulation data on a PC is possible. Data can be transferred at high speeds of 120 kbyte/s via GPIB, permitting highspeed measurement of the production line. The 6.5 type TFT color LCD provides an easy-to-read screen, and VGA signals can be output from a rear connector.
联系方式:深圳市嘉惠捷科技有限公司
联系人: 王R
手 机 :13715327187
客服QQ : 644842572
邮箱: wht19823@126.com
电话:86641139
公司网站:http://www.test-e.com/
公司地址:广东省深圳市南山区西丽留仙大道西丽蓝天花园山水阁13F
备注:
本公司长期低价销售!现金回收:租赁:网络分析仪、工厂报废仪器回收、无线综合测试仪、频谱分析仪、 视频图象信号源、LCR测试仪、高/低频信号源、示波器、万用表、电子负载、频率计、二手进口高挡仪器,等等二手仪器出售/维修/收购。有货请与我取得联系!迎来电咨询!13715327187
1楼 0 0 回复
