现金收购/销售数字多用表Agilent34401A HP34401A HP 34401A
<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1780114589
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt008@126.com<SPAN .="mso-spacerun: yes">
<P align=left .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">张先生:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">13652350058
HP/Agilengt34401 数字万用表
生产厂商:AGILENT(安捷伦)
产品简述:6位半台式数字多用表,0.004%基本直流电压精度,标准HP-B和RS232接口
? 12种测量功能
? 1000V最大输入
? 15 基本直流精度(24小时)
? 每秒钟1000个读数直接至GP-IB
? GP-IB和RS-232标准
? 512读数存储器
? 2SCPI标准命令
Agilent 34401A数字万用表以异乎寻常的经济价位建立了价格/性能的新标准,可以提供61/2数字分辨率、每秒钟1000个读数和15ppm的基本直流精度.34401A是满足你当前和今后需要的性能优良、适用面广的数字多用表.
良好的台式工作性能
34401A的清晰合理的前面板能够很容易地选择所有的主要测量功能,包括传统的“台面工作”功能,像连续性和二级管测试;数字运算功能,如零位,界限测试和最大/最小/平均等功能也很容易选择.简单的菜单可让你访问强有力的高级功能,例如把多达512的读数存储到内部存储器中.测量结果显示在明亮的高可见度的显示器上.坚固的机壳可保证仪器即使在恶劣的环境下仍然不会被损坏,而且选配的包装和携带方便.
在系统中的高级性能
34401A每秒能够处理1000个读数,包括ASCII格式的GPIB总线传输在内.GPIB和RS-232两者都是标准的,使你能选择要求的接口.34401A响应三种不同的指令语言.它接受SCPI命令(可编程仪器的标准命令),从而保证了当前的和未来的兼容性.它也响应Agilent 3478A和Fluke 8840A的命令,以其向下兼容保护你的软件投资.驱动器也可用国家仪器公司的和VEE两种软件.
通过Agilent 34812A Meter软件把Agilent 34401A置于测量系统
Agilent 34401A是一种不寻常的数字万用表,通过34812A Meter软件,可以使它变得更有价值.34812A Meter可使你的PC机和DMM变为更有力的、使用更方便的单通道数据采集系统.
技术指标
Agilent 34401A 数字多用表
量程
:6位 准确度:1年(或ac电压的频率) ±(读数的%+满度的%)
直流电压 100m V
1V
10V
100V
1000V 100n V
1μ V
10μ V
100 μ V 1μ V 输入电阻
0.0050+0.0035
0.0040+0.0007
0.0035+0.0005
0.0045+0.0006
0.0045+0.0010
10MW或>10/GW 10MW或>10/GW 10MW或>10/GW
10MW
10MW
真有效值交流电压
100mV量程
1V至750V量程 3Hz-5Hz
5Hz-10Hz
10Hz-20KHz 20KHz-50KHz 50KHz-100KHz 100KHz-300KHz
3Hz-5Hz
5Hz-10Hz
10Hz-20KHz 20KHz-50KHz 50KHz-100KHz 100KHz-300KHz 1.00+0.04
0.35+0.04
0.06+0.04
0.12+0.04
0.60+0.08
4.00+0.50
1.00+0.03
0.35+0.03
0.06+0.03
0.12+0.05
0.60+0.08
4.00+0.50
电阻
100Ω
1KΩ
10KΩ
100KΩ
1MΩ
10MΩ
100MΩ
100mΩ
1mΩ
10mΩ
100mΩ
1Ω
10Ω
100Ω
0.010+0.004
0.010+0.001
0.010+0.001
0.010+0.001
0.010+0.001
0.040+0.001
0.800+0.010 电流源
1m A
1m A
100μA
10μA
5μA
500μA
500μA
直流电流 10m A-3A量程
交流电流 1A-3A量程
频率和周期 3Hz(0.333s)-300k Hz(3.33μs)
连续性测试 1KΩ量程,阈值变化范围1Ω-1KΩ
二极管测试 IV量程, 1m A测试电流
数学运算功能 消零,最小值/最大值/平均值,极限测试
其它功能 自动读数保持,512个读数存储,直流电压比
最大输入 直流和交流电压 1,000Vdc,750Vrms ac 直流和交流电流 3A,从<250V源,双熔丝
冲击和振动 符合MIL-T-28800,III类,5级
电源 100/120/220/240V,45-65Hz,360-440Hz
重量 3kg(6.5Ibs)
尺寸 103.6mmH×254.4mmW×374mmD
