您的位置:控制工程论坛网论坛 » 产品供求 » 现货出售! HP4339A 高阻测试仪HP4339A 谭艳飞13543805887/胡S HP4339A/HP 4339A 高阻测试仪 Wide measurement range: 1 x 103 ohm to 1.6 x 1016ohm Stable test fixtures: resistivity cell, component test fixture High-speed measurement: 10 ms Test sequence programming Resistivity calculations Grounded DUT measurement Specifications Measurement Functions Measurement Parameters: R (dc resistance), I (dc current), rs (surface resistivity), rv (volume resistivity) Mathematical Functions: Deviation and percent deviation Ranging: Auto and manual Trigger: Internal, external, manual, and HP-IB Delay Time: 0 to 9999 ms in 1 ms steps Test Cable Lengths: 2 m maximum Measurement Time: Short, medium, and long Averaging: 1 to 256 Test Voltage: 0 to 1000 Vdc, 100 mV steps @ 0 to 200 V, 1 V steps @ 200 to 1000 V Maximum Current: 10 mA @ < 100 V, 5 mA @ < 250V, 2 mA @ < 500 V, 1 mA @ < 1 kV Current Compliance Setting: 0.5 mA, 1 mA, 2 mA, 5 mA, 10 mA
hu597709756
hu597709756   |   当前状态:在线
总积分:5837  2025年可用积分:0
最后登录时间: 2012-04-16
空间 发短消息加为好友
hu597709756  发表于 2012/3/29 17:25:21      532 查看 0 回复  [上一主题]  [下一主题]
手机阅读
Specifications
Averaging: 1 to 256
1楼 0 0 回复
