您的位置:控制工程论坛网论坛 » 产品供求 » AnritsuMS9710B/光谱分析仪
xiaogui0344
xiaogui0344   |   当前状态:在线
总积分:516  2025年可用积分:0
最后登录时间: 2013-06-27
空间 发短消息加为好友
xiaogui0344  发表于 2011/11/7 11:57:39      735 查看 0 回复  [上一主题]  [下一主题]
手机阅读
Anritsu/MS9710B/光谱分析仪
如果您对该产品感兴趣的话,可以给我留言!现货供应,欢迎来电咨询!13715327187
【详细说明】
MS9710 利用一个比别的优越, 稳定和可靠的衍射光栅 (暂时未有专利),容易而精确地测量 WDM 设备和系统。
  • MS9710C 在波长的准确性为: +/-20pm (C-频带) 和 +/-50pm (L-频带)
  • 新的! MS9710C 选择 15: 由 1520 至 1620nm 的波长准确性为 +/-20pm
  • 0.2nm 偏移在 >42dB 的动态范围(MS9710C)
  • 频宽分辨率 (FWHM) 为 50pm (MS9710C)
  • 对波长,电平和 SNR 的 WDM 测量达 256 个通道
  • 提供 MS9710B 的低价版本
技术指标
Fiber 10/125 μm SM fiber (IU-T .652)
Optical connector*^1 User replaceable:FC,SC,ST,DIN,HMS-10/A
Factory option(not user replaceable):E200-PC,E2000-APC,FC-APC,SC-APC,HRL-10
Wavelength Range:600 to 1750 nm
Accuracy:±20pm[1530 to 1570nm,reslution:0.05 to 0.2nm,after WI Cal (Ref)]
±50pm [1520 to 1530nm,1570 to 1620nm resolution:0.05 to 0.2 nm,after WICal (Ref)]
±200pm [1530 to 1570nm,after WI Cal (Ext)]
±300pm [600 to 1530nm,1570 to 1750nm,after WI Cal (Ext)]
Stability:±5pm(1min,smoothing:11 points,at half-width center wavelength)
Wavelength readout resoution:5 pm
Resolution accuracy*^2
±2.2%(1530 to 1570nm,resolution:0.5nm),±3%(1530 to 1570nm,reslution:0.2nm)
±7%(1530 to 1570nm ,reslution:0.2nm),±4%(1520 to 1530nm,1570 to 1620nm ,reslution:0.5nm)
±5%(1520 to 1530nm,1570 to 1620 nm)reslolution:0.2nm )±10%(1520 to 1530nm 1570 to 1620nm,resolution:0.5nm)
±7%(other wavelength,resolution:0.5nm),±15%(other wavelength,resoltion:0.2nm)
±30 %(other wavelength,resolution:.0.1nm)
Level Measurement range(resolution:≥0.07nm ,VBW:10Hz ,sweepaveraging:10 times):
-65 to +10 dBm(600 to 1000nm , 0° to 30℃,optical attenuator:off)
-85 to +10 dBm(1000 to 1250nm,0° to 30℃,optical attenuator:off)
-90 to +10 dBm(1250 to 1600nm , 0° to 30℃,optical attenuator:off)
-75 to +10 dBm(1600 to 1700nm , 0° to 30℃,optical attenuator:off)
-55 to +10 dBm(1700 to 1750nm , 0° to 30℃,optical attenuator:off)
-60 to +10 dBm(600 to 1600nm , 0° to 30℃,optical attenuator:off)
-80 to +10 dBm(1000 to 1250 nm , 0° to 30℃,optical attenuator:off)
-85 to +10 dBm(1250 to1600nm , 0° to 30℃,optical attenuator:off)
-70 to +10 dBm(1600 to 1700nm , 0° to 30℃,optical attenuator:off)
-50 to +10 dBm(1700 to1750nm , 0° to 30℃,optical attenuator:off)
-70 to +23 dBm(1100 to1600nm , 0° to 30℃,optical attenuator:on)
-63 to +23 dBm(1100 to1600nm ,30° to 50℃,optical attenuator:on)
Accuracy:±0.4dB (1300/1500min ,input:-23 dBm resolution:≥0.1nm)
Stability:±0.02B (1min resolution:≥0.1nm input:-23 dBm,no polarization shift)
Linearity:±0.05dB (1550 nm,-50 to 0 dBm,optical attenuator:off )±0.05dB(1550nm,-30 to +20 dBm,optical attenuator:on)
Flatness:±0.5nm,optiocal attenuator:off (measured with ML9050A StandardOptica Power Meter)
Polarization dependency ±0.05dB(1550/1600nm),±0.1dB(1300nm)*Setting resolution:≥0.5nm
Dynamic range*^3 High-dynamic range mode (20°+30℃):
70 dB (1nm from peak wavelength),60 dB (0.4nm from peak wavelength),42 dB(0.2nm from peak wavelength)
Normal mode(20°+30℃):
62dB (1nm from peak wavelength),58dB(0.4 nm from peak wavelength),42 dB(0.2nm from peak wavelength)
Optical return loss ≥35dB (1300/1550nm)
Sweep Sweep width:0.02 to 1200nm
Sweep speed(typial)*^4
0.5s(normal dynamic mode ,sweep width:500
nm,VBW:10kHz,center wavelength;1200nm,sweepstart to stop,o optical
input,samplingpoint:501)
Display 6.4 inch,color TFT-LCK
Memory A/B(2 trace),3.5 inch FDD (for MS-DOS^@format)
Printer Intemal (thermal type)
Interface GPIG,RS-232C,VGA output
Operating conditions Operaitng temperature:0°+50℃(FDD:+5°+50℃),storage temperature:-20°+60℃)
Relative humidity:≤90%(no condensation,FDD:20 to 80%)
Shock:30 G,11 ms pulse,halfsine
Power 85 to 132Vac/170 to 250Vac,47.5 to 63Hz ,150VA(max)
Dimensions and mas 320(W)*177(H)*350(D)mm,≤16.5kg
EMC*^5 EN55011:1991,Group 1,Class A
EN50082:1992
订货信息
Model/Order No. Name
  Main frame
MS9710V Optical Spectrum Analyzer
  Standard accessories
  Optical Spectrum Analyzer^*1:1pc
J0017 Power cord,2.5m:1pc
F0012 Fuse,3.15A(for 100Vac system):2pcs
F0010 Fuse,1.6A(for 200Vac system):2pcs
Z0312 Printer paper: 2rolls
W1579AE MS9710C opration manual: 1copy
W1580AE Remote contrlo operation manual:1pc
MX971003S LabVIEW driver(RS-232C):1pc
MX971003G LabVIEW driver(GPIB):1pc
B0329G Front cover: 1pc
  Options
MS9710C-02 White light soure^*2
MS9710C-03 Wavelength reference & SLD light souce^*2
MS9710C-04 SLD light source^*2
MS9710C-05 Wavelength reference light source^*2
MS9710C-25 FC-APC connector%*3
MS9710C-26 SC-APC connector^*3
MS9710C-27 E2000(Diamond)connector^*3
MS9710C-37 FC connector^*4
MS9710C-38 ST connector^*4
MS9710C-39 DIN connector^*4
MS9710C-40 SC connector^*4
MS9710C-43 HMS-10/A(Diamond)connector^*4
MS9710C-47 HRL-10 connector^*3
  Application parts
J0654A
RS-232c cable(9P-9P)
J0655A RS-232c cable(9P-25P)
J0007 GPIB cable,1m
J0617B Replaceable optical connector(FC)
J0618D Replaceable optical connector(ST)
J0618E Replaceable optical connector(DIN)
J0618F Replaceable optical connector(HMS-10/A)
J0619B Replaceable optical connector(SC)
J0635B FC-PC·FC-PC 2M-SM(FC-PC optical fiber cord,2m,SM
Z0282 Ferrule cleaner
Z0283 Replacement reel for ferrule cleaner(for Z0282)
Z0284 Cleaner for optical adaper(stick type)
B0336C Hard carrying case
G0084A polarization ratation module(for PMD measurement)
B0330C Tit stand
联系方式:深圳市嘉惠捷科技有限公司
联系人: 王先生
手 机 :13715327187
客服QQ : 644842572
邮箱: wht19823@126.com
电话:86641139
公司网站:http://www.test-e.com/
公司地址:广东省深圳市南山区西丽留仙大道西丽蓝天花园山水阁13F
备注:
本公司长期低价销售!现金回收:租赁:网络分析仪、工厂报废仪器回收、无线综合测试仪、频谱分析仪、
视频图象信号源、LCR测试仪、高/低频信号源、示波器、万用表、电子负载、频率计、二手进口高挡仪器,等等二手仪器出售/维修/收购。有货请与我取得联
系!迎来电咨询!13715327187
1楼 0 0 回复
