您的位置:控制工程论坛网论坛 » 产品供求 » DVI-I 转 usb 转换器(艾普飞系列)
sk82609286
sk82609286   |   当前状态:在线
总积分:129  2025年可用积分:0
最后登录时间: 2016-05-16
空间 发短消息加为好友
sk82609286  发表于 2012/2/6 17:36:17      549 查看 0 回复  [上一主题]  [下一主题]
手机阅读
Interface 接口
USB 2.0, USB 1.1
Dimensions 尺寸
6.7" x 4.3" x 1.2"
170 x 109 x 30 mm
Connectors 接口
DVI-I (integrated, digital & analog)
5V DC power supply connector
USB mini type B
Input  输入端
VGA and DVI
Video Sampling
24 bits per pixel, 8:8:8 format
16 bits per pixel, 5:6:5 format
8 bits per pixel, 3:3:2, 3:2:3, 2:3:3 or 256-grey scale format
4 bits per pixel, 16-grey scale format
Integrated Board Features
On-board loss-less image compression (proprietary)
On-board memory (no interlacing artifacts)
On-board cropping
VESA-compatible Sync-on-Green
Video mode support 支持模式
720x400, 640x480, 800x600, 1024x768, 1152x864, 1152x900, 1280x960, 1280x1024, 1600x1200, 1920x1080, 1920x1200
Frame rate 帧率
Frame rate varies depending on content
Resolution
Frame rate
640 x 480
30.0 - 60 fps
800 x 600
22.6 - 60 fps
1024 x 768
15.0 - 60 fps
1280 x 1024
10.0 - 52 fps
1600 x 1200
8.0 - 34 fps
1920 x 1200
5.2 - 32 fps
LEDs 指示灯
Three LEDs to indicate the status of the DVI2USB (power, readiness, and operation in progress)
OS Support 支持系统
Windows 2000, XP, Vista, Windows 7 (i386, x64)
Mac OS X 10.4 and up (ppc, i386, x86_64)
Linux (x86, x86_64)1
DirectShow (Windows), QuickTime (Mac OS X) and V4L (Linux) integration
中国大陆:宋先生
010-82609286-811  13718749903  (9:00-17:30)
联络网址:www.exntech.com
1楼 0 0 回复
