sk82609286 | 当前状态:在线
总积分:129 2025年可用积分:0
最后登录时间: 2016-05-16
DVI-I 转 usb 转换器(艾普飞系列)
sk82609286 发表于 2012/2/6 17:36:17 551 查看 0 回复 [上一主题] [下一主题]
Interface 接口 |
USB 2.0, USB 1.1 | |
Dimensions 尺寸 |
6.7" x 4.3" x 1.2" | |
Connectors 接口 |
DVI-I (integrated, digital & analog) | |
Input 输入端 |
VGA and DVI | |
Video Sampling |
24 bits per pixel, 8:8:8 format | |
Integrated Board Features |
On-board loss-less image compression (proprietary) | |
Video mode support 支持模式 |
720x400, 640x480, 800x600, 1024x768, 1152x864, 1152x900, 1280x960, 1280x1024, 1600x1200, 1920x1080, 1920x1200 | |
Frame rate 帧率 |
Frame rate varies depending on content | |
Resolution |
Frame rate | |
640 x 480 |
30.0 - 60 fps | |
800 x 600 |
22.6 - 60 fps | |
1024 x 768 |
15.0 - 60 fps | |
1280 x 1024 |
10.0 - 52 fps | |
1600 x 1200 |
8.0 - 34 fps | |
1920 x 1200 |
5.2 - 32 fps | |
LEDs 指示灯 |
Three LEDs to indicate the status of the DVI2USB (power, readiness, and operation in progress) | |
OS Support 支持系统 |
Windows 2000, XP, Vista, Windows 7 (i386, x64) |
中国大陆:宋先生
010-82609286-811 13718749903 (9:00-17:30)
联络网址:www.exntech.com
