您的位置:控制工程论坛网论坛 » 产品供求 » 代理 韩国HTC中国区代理 电源管理芯片可代替TI、PHI、ST、AD、ON、等品牌
Bingyindzsensor
Bingyindzsensor   |   当前状态:在线
总积分:140  2025年可用积分:0
最后登录时间: 2011-05-12
Bingyindzsensor  发表于 2011/2/22 11:18:06      1534 查看 0 回复  [上一主题]  [下一主题]
TL432A(1%)/TL432ASF
TL432C(0.5%)/TL432CSF
HTC TO-92/SOT-23 LMV321(National)/TL432(ST)/RC431A(Fairchild)/TL431A,B(ON-Semi)/TLV431,TL432(TI)/AP432(Etc.) HTC调压器TL432
LM317L HTC TO-92 LM317(National)/LM317LZ(ST)/KA317L(Fairchild)/LM317LB(ON-Semi)/TL317(TI) HTC调压器LM317L
LM317T HTC TO-220 LM317T(National)/LM317T(ST)/KA317T(Fairchild)/LM317T(ON-Semi)/TL317AB(TI) HTC调压器LM317T
LM2950-XX HTC TO-92 LM2950ACZ(National)/LM2950ACZ(ON-Semi) HTC低压差调压器LM2950
LM1117S-XX/RS-XX HTC SOT-223/TO-252 LM1117(National)/LD1117xx(ST)/FAN1117A(Fairchild)/NCP1117(ON-Semi)/REG1117(TI)/RT9164,AME1117(Etc.) HTC低压差调压器LM1117
LM1084 HTC TO-263 LM1084(National)/KD1084Axx(ST)/FAN1084(Fairchild)/CS5204,CS5205(ON-Semi)/AME1084,AP1084(Etc.) HTC低压差调压器LM1084
LM1085 HTC TO-263 LM1085(National)/LD1085xx(ST)/CS5203(On-Smei)/AME1085
(Etc.)
HTC低压差调压器LM1085
LM1086 HTC TO-263 LM1086(National)/FAN1086(Fairchild)/CS52015(ON-Semi)/RT9176,AME1117(Etc.) HTC低压差调压器LM1086
R-XX/LM2576T-XX HTC TO-263/TO-220 MIC276(Micrel)/LM2576(National)/LM2576(ON-Semi)/SI-80xxS/SD(Etc.) HTC降压调压器LM2576
LM2596R-XX/LM2596T-XX HTC TO-263/TO-220 LM2596(National)/AP1501(Etc.) HTC降压调压器LM2596
LM29150/LM29151/LM29152 HTC TO-252/TO-263
/TO-220
MIC29150,MIC29151,MIC29152(Micrel)/LD29150xx(ST)/SPX29150(Etc.) HTC极低压差调节器LM29150/LM29151/29152
LM39100-XX/LM39102-XX HTC SOT-223/SOP-8 CS5171(ON-Semi)/LT1373,AMC3202(TI)(Etc.) HTC极低压差调节器LM39100/LM39101/LM39102
LM39300-XX/LM39302-XX HTC TO-220/TO-263 MIC39300,MIC39302(Micrel)/LP3966(National)/TPS757xx(TI)/SPX29300(Etc.) HTC极低压差调节器LM39300/LM39301/LM39302
LM39500-XX/LM39502-XX HTC TO-220/TO-263 MIC39500,MIC39502(Micrel)/TPS755xx(TI)/SPX29500(Etc.) HTC极低压差调节器LM39500/LM39501/LM39502
TJ3965-XX HTC TO-220/TO-263
/SOT-223/SOP-8
MIC37139(Micrel)/LP3965(National)/FAN1581(Fairchild)/TPS78630(TI)/RT9183,AME8815,AME8816(Etc.) HTCCOMS超低压差调节器TJ3965
TJ1509A HTC SOP-8 AP1509(Etc.) HTC降压调压器TJ1509
TJ2995 HTC SOP-8 LP2995(National)/G2995(Etc.) HTCDDR供电调压器TJ2995
TJ2996D/TJ2996DP HTC SOP-8/SOP-8PP LP2996(National)/NE57814,SC2596(Etc.) HTCDDR供电调压器TJ2996
TJ49300R-XX HTC TO-263 MIC49300(Micrel)/LP38843(National)/LD49300(ST) HTCCOMS超低压差调节器TJ49300
LM5171D HTC SOP-8 CS5171(ON-Semi)/LT1373,AMC3202(TI)(Etc.) HTC升压调节器LM5171D
TJ1051 HTC SOT-26/SOP-8 TSM1051(ST) HTC电流电压控制器TJ1051
TJ7660 HTC SOP-8/DIP-8 ICL7660,HT7660(Etc.) HTC电压转换器TJ7660
