您的位置:控制工程论坛网论坛 » 产品供求 » Xilinx下载线 Xilinx cable Xilinx USB下载线
huanor
huanor   |   当前状态:在线
总积分:1111  2025年可用积分:0
最后登录时间: 2012-06-11
huanor  发表于 2011/2/28 14:00:24      1129 查看 0 回复  [上一主题]  [下一主题]
开发板中心网址:http://www.huanor.com
开发板中心论坛:http://www.huanor.com/bbs
淘宝网址:http://shop36289907.taobao.com
QQ: 1060087047或者871001268
手机:13466617480或者15801405586
座机:010-82534219
Email:huanor_sales@hotmail.com
地址:北京市海淀区中关村大街28-1号中海园电子市场地下一层BF-198
世界唯一的XILINX CABLE  终身质保产品
XILINX_CABLE_Introduction
The Platform Cable USB II provides integrated firmware to deliver high-performance, reliable and user-friendly configuration of Xilinx FPGAs and programming of Xilinx PROM and CPLD devices. Platform Cable USB II is a cost effective tool for debugging embedded software and firmware when used with Xilinx applications such as the Embedded Development Kit and ChipScope? Pro Analyzer.
SUPPORT  DECVICE :
Virtex-6                              Spartan-II
Virtex-5 FX                           Spartan-IIE
Virtex-5 LX                           Spartan
Virtex-5 SX                           CoolRunner-II
Virtex-4                              CoolRunner XPLA3
Virtex-II Pro                          Platform FLASH
Virtex-II                              XC18Vxx Series
Virtex-E                              XC9500
Virtex                                XC9500XL
Spartan-6                             XC9500 XV
Spartan-3A
Spartan-3A DSP
Spartan-3AN
Spartan-3E
Spartan-3
Requirements :
Windows XP Professional (32 and 64-bit)
Windows Vista (32 and 64-bit)
Windows 2000 Professional
Red Hat Enterprise Linux WS 3.0 (32 and 64-bit)
Red Hat Enterprise Linux WS 4.0 (32 and 64-bit)
Red Hat Enterprise Linux WS 5.0 (32 and 64-bit)
SUSE Linux Enterprise Linux 10.0 (32 and 64-bit)
High-performance FPGA configuration and PROM/CPLD programming .
Supports JTAG and Slave-Serial programming topologies
Firmware downloadable over cable
Fully integrated and optimized for use with Xilinx iMPACT software
Intuitive multiple cable management from a single application
Compatible with Windows and Linux operating systems
Automatically senses and adapts to target I/O voltage
Interfaces to devices operating at 5V (TTL), 3.3V (LVCMOS), 2.5V,     1.8V and 1.5V
Bus-powered USB device (no power supply required)
Flyleads compatible
Target power status LED
Firmware updates are transparent to the user
Compatible with Full-Speed and Hi-Speed USB ports
ChipScope Pro Analyzer(逻辑分析仪)
对于XC6SLX150T-3FGG676 ,ROCE进行2.5Gbps 的MGT传输测试,通过ISE 12(包括以下版本)的逻辑分析仪进行数据误码测试。现已有50多套应用于IC验证,通信系统编解码验证,软件无线电测试等高端科研领域。
EDK Debug TEST      (EDK运行测试)
对于EDK 12(包括以下版本),ROCE在线Debug XC6VLX240T-1FFG1156 、XC5VLX50T-1FF1136主芯片的microblaze软核,以及配置测试。
Hardware Test        (硬件可靠性测试)
对于可靠性能,以及电路保护。ROCE对于Spartan-3 FPGA、XC9500 CPLD系列进行上百次的带电热插拔测试,电缆不禁可以自适应不同的下载配置电压,而且没有发生过主芯片或者电缆的电路烧毁问题。
产品特点:
Features:
1. 高性能下载灵活配置
2.完全支持XLINX的配置模式(SPI /BPI / M OR S Serial and Etc )
3. 下载线内部固件软件支持未来ISE版本长期可更新
4. 支持多版本IMPACT全功能
5. 自适应配置电压5V (TTL), 3.3V (LVCMOS), 2.5V, 1.8V and 1.5V
6. 通过USB供电方案简化电路设计
7. 更新固件红灯指示,正常运行绿灯指示
8. 固件更新对用户终身透明
9. 支持全速标准USB接口 是普通下载线的两倍速率
接口定义:
14pin 2.54针,完全和下载包装定义一致。本产品接口只统一ROCE公司14 pin 2.54接口。如客户接口不同,完全可以依照接口定义自行引线,如解决困难可像ROCE申请解决。
Interface Definition:
To 14pin 2.54 pin, complete and consistent definition of download packages. This product is only the unity of ROCE company Interface Interface 14 2.54. If the customer interface, different, can lead in accordance with its own interface definition, such as to resolve difficulties can apply for settlement as ROCE.
Attention!
经过无数的测试,以及客户对ROCE 公司关于XILINX产品质量的认可,我们主动承担的责任如下:
Fpga we have to promote enthusiasm for learning, we download cable for life-long warranty, please rest assured that use. If any problem, please contact the company or agency。
为推动大家学习可编程逻辑器件的热情,ROCE对于下载线进行终身质保,请大家放心使用。如出现问题请与公司或者代理联系。我们在一周内给予解决。
套件清单:
1、XILINX 下载盒       1 块
2、USB主从便携线       1条
3、USB迷你连接器       1 只
4、保修卡              1张
座机:010-82534219
