您的位置:控制工程论坛网论坛 » 产品供求 » 供应欧陆690+系列交流变频器
cznjgk
cznjgk   |   当前状态:在线
总积分:119  2025年可用积分:0
最后登录时间: 2013-10-25
供应欧陆690+系列交流变频器
cznjgk  发表于 2011/3/15 14:51:26      1073 查看 0 回复  [上一主题]  [下一主题]
AC690+ Series  380-460V
Product Code
Type
690PB/0007/400/3/F/0011
0.75kW Three Phase IP20 with Filter (B)
690PB/0015/400/3/F/0011
1.5kW Three Phase IP20 with Filter (B)
690PB/0022/400/3/F/0011
   2.2kW Three Phase IP20 with Filter (B)
690PB/0040/400/3/F/0011
4.0kW Three Phase IP20 with Filter (B)
690PB/0055/400/3/F/0011
5.5kW Three Phase IP20 with Filter (B)
690PB/0007/400/3/0/0011
0.75kW Three Phase IP20 without Filter (B)
690PB/0015/400/3/0/0011
1.5kW Three Phase IP20 without Filter (B)
690PB/0022/400/3/0/0011
2.2kW Three Phase IP20 without Filter (B)
690PB/0040/400/3/0/0011
4.0kW Three Phase IP20 without Filter (B)
690PB/0055/400/3/0/0011
5.5kW Three Phase IP20 without Filter (B)
690PC/0075/400/0011..B0
7.5kW Three Phase IP20 with braking module (C)
690PC/0110/400/0011..B0
11.0kW Three Phase IP20 with braking module (C)
690PC/0150/400/0011..B0
15.0kW Three Phase IP20 with braking module (C)
690PD/0180/400/0011..B0
18.0kW Three Phase IP20 with braking module (D)
690PD/0220/400/0011..B0
22.0kW Three Phase IP20 with braking module (D)
690PD/0300/400/0011..B0
30.0kW Three Phase IP20 with braking module (D)
690PE/0370/400/0011..B0
37.0kW Three Phase IP20 with braking module (E)
690PE/0450/400/0011..B0
45.0kW Three Phase IP20 with braking module (E)
690PF/0550/400/0011..B0
55.0kW Three Phase IP20 with braking module (F)
690PF/0750/400/0011..B0
75.0kW Three Phase IP20 with braking module (F)
690PF/0900/400/0011..B0
90.0kW Three Phase IP20 with braking module (F)
690PG/1100/400/0011..B0
110.0kW Three Phase IP20 with braking module (G)
690PG/1320/400/0011..B0
132.0kW Three Phase IP20 with braking module (G)
690PG/1600/400/0011..B0
160.0kW Three Phase IP20 with braking module (G)
690PG/1800/400/0011..B0
180.0kW Three Phase IP20 with braking module (G)
690PH/2000/400/0011..B0
200.0kW Three Phase IP20 with braking module (H)
690PH/2200/400/0011..B0
220.0kW Three Phase IP20 with braking module (H)
690PH/2500/400/0011..B0
250.0kW Three Phase IP20 with braking module (H)
690PH/2800/400/0011..B0
280.0kW Three Phase IP20 with braking module (H)
690PJ/3150/400/0011..B0
315.0kW Three Phase IP20 with braking module (J)
690PD/0150/400/0011
15.0kW Three Phase IP20, no braking module (D)
690PD/0180/400/0011
18.0kW Three Phase IP20, no braking module (D)
690PD/0220/400/0011
22.0kW Three Phase IP20, no braking module (D)
690PD/0300/400/0011
30.0kW Three Phase IP20, no braking module (D)
690PE/0370/400/0011
37.0kW Three Phase IP20, no braking module (E)
690PE/0450/400/0011
45.0kW Three Phase IP20, no braking module (E)
690PF/0550/400/0011
55.0kW Three Phase IP20, no braking module (F)
690PF/0750/400/0011
75.0kW Three Phase IP20, no braking module (F)
690PF/0900/400/0011
90.0kW Three Phase IP20, no braking module (F)
690PG/1100/400/0011
110.0kW Three Phase IP20, no braking module (G)
690PG/1320/400/0011
132.0kW Three Phase IP20, no braking module (G)
690PG/1600/400/0011
160.0kW Three Phase IP20, no braking module (G)
690PG/1800/400/0011
180.0kW Three Phase IP20, no braking module (G)
690PH/2000/400/0011
200.0kW Three Phase IP20, no braking module (H)
690PH/2200/400/0011
220.0kW Three Phase IP20, no braking module (H)
690PH/2500/400/0011
250.0kW Three Phase IP20, no braking module (H)
690PH/2800/400/0011
280.0kW Three Phase IP20, no braking module (H)
690PJ/3150/400/0011
315.0kW Three Phase IP20, no braking module (J)
常州能杰工控设备有限公司大量供应欧陆SSD590+系列直流调速器、690+系列交流变频器,价格电议,量大从优!                   联系人:曹先生
联系电话:0519-83288456 (0)13606124926
传真:0519-83288256
邮箱:c_l19852004@163.com
QQ: 362168785
公司地址:江苏省常州市钟楼区白云路三号E座三楼
