您的位置:控制工程论坛网论坛 » 产品供求 » 汽车引擎转速表CIE-8088
website
website   |   当前状态:在线
总积分:197  2025年可用积分:0
最后登录时间: 2011-05-10
汽车引擎转速表CIE-8088
website  发表于 2011/5/9 9:46:37      1061 查看 0 回复  [上一主题]  [下一主题]
商品说明
☆ 3 3/4;4000数字液晶显示
☆ 交流直流(DC/AC)、电压、频率及电容、自动换文件功能
☆ DC电压文件:400mV, 4V, 40V, 400V, 1000V +/-( 0.5%+1 dgt)
☆ AC电压文件:400mV,4V, 40V, 400V, 750V +/-(2.0% + 5 dgt)
☆ DC/AC电流档:400mA 及20A
电阻档:400, 4K, 40K, 400K, 4000K, 40M Ohm
☆ 转速600~ 12000 RPM
☆  读值、脉波周期循环(Pulse Duty Cycle)、白金闭角(DWELL角度)4~8 Cylinders可测量电子油料投入反应、及点火系统(Carburetors and Ignition)
☆ 附电感RPM钩钳(HP-01标准配备)
☆ 毫秒脉冲宽度(Milliseconds Pulse Width)测量及时油料注入、闲置的空气控制马达, 及电子传输控制
☆  温度量测:-50 至 1100 ℃ +/-(1.0 % + 2 ℃)
☆  最大值、最小值、读值锁定、归零(相对读值)之功能
☆ 所有文件位皆有过载保护功能
规  格 :
DC Voltage Ranges:
400mV,4V,40V,400V,1000V ±(0.5%+1dgt)
AC Voltage Ranges:
400mV,4V,40V,400V,750V ±(2.0%+5dgt)
DC Current Ranges:
400mA ±(1.0%+1dgt), 20A ±(1.5%+1dgt)
AC Current Ranges:
400mA±(1.5%+3dgts), 20A ±(2.0%+3dgts)
Resistance Ranges:
(Auto-ranging) 400Ω,4kΩ,40 kΩ,400 kΩ,4000kΩ,40MΩ. ±(2.0%+4dgts)
Capacitance Ranges:
(Auto-ranging) 4nF,40nF,400nF,4uF,40uF. ±(2.0~5.0%+4dgts)
Frequency Ranges:
(Auto-ranging) 100Hz,1kHz,10kHz,100kHz,400kHz. ±(0.1%+4dgts)
Temperature Ranges:
-50 to 1100℃ ±(1.0%+2℃);-50 to 2000℃±(1.0%+4℃)
Frequency Ranges:
(Auto-ranging) 100Hz,1kHz,10kHz,100kHz,400kHz.±(0.1%+4dgts)
RPM Ranges:
600 to 4000 low; 1000 to 12000 high
RPM (TACHO) manual ranging ±(2%+1dgt)
Dwell Angle:
4,5,6,8 Cylinders ±(2.0%+5dgts)
Duty Cycle:
0.0 to 90.0% ±(2.0%+5dgts)
ms Pulse Width:
0.1ms to 10.0ms ±(2%+0.2ms)
Diode Test
0.6mA typical ±(2.0%+4dgts)
Audible Continuity
Open circuit voltage:0.4V DC, Audible threshold:<40Ω
Overload protection:
1000VDC or 750VAC RMS for DC/AC Voltage;
0.5A,20A/600V Fused for DC/AC Current
60VDC or 24VAC RMS for temperature
500VDC or AC RMS for other ranges
General
Power Requirement:
One 9V battery
Dimensions:
2"x3.8"x7.9" (52x96x200mm)
Weight:
17.5oz(495g)
Accessories:
Test Leads,holster, battery, owners manual,K-type
Thermocouple probe,Inductive RPM pickup probe.
Optional Accessories:
CA-600 DC/AC current Clamp, 400Amp.
標準配備 : HP-01
