您的位置:控制工程论坛网论坛 » 产品供求 » !@@ HP8591EM HP8591频谱分析仪|HP8591
dglt2008
dglt2008   |   当前状态:在线
总积分:170  2025年可用积分:0
最后登录时间: 2014-03-04
dglt2008  发表于 2011/5/10 15:39:09      1008 查看 0 回复  [上一主题]  [下一主题]
!出售/回收!@@ HP8591EM  HP8591频谱分析仪|HP8591
东莞精通电子有限公司
联系人:刘先生
手机:18676986680
QQ:891434127
公司邮箱:dglt2008@163.com
AD:东莞塘厦镇塘龙东路
本公司长期现货租售/回收:频谱分析仪、网络分析仪、信号源、无线电综合测试仪、手机综合测试仪、蓝牙测试仪、电视信号发生器、TV信号发生器、数字示波器、LCR测试仪、数字万用表、OTDR、光纤熔接机、噪声分析仪、逻辑分析仪、功率计、辉度计/亮度计、等;并承接高频仪器维修!
HP / Agilent 8591EM EMC Analyzer, 9 kHz to 1.8 GHz
The HP / Agilent 8591EM EMC Analyzer, 9 kHz to 1.8 GHz is a stand-alone, automated EMC precompliance analyzer that reduces the time it takes to find, measure and document radiated and conducted EMI emissions.  With an upper frequency of 1.8 GHz, the 8591EM can perform precompliance tests on products with clock frequencies up to 108 MHz.  The 8591 EM has two modes of operation: EMI analysis and spectrum analysis.  With the press of a key, this analyzer converts from EMC analyzer to full-function spectrum analyzer for use in a wide variety of non-EMC applications.
Features
■Setup keys link predefined CISPR bands with correct video and CISPR resolution bandwidths
■Built-in amplitude correction automatically corrects for antenna, amplifier, and cable losses
■Limit-line displays simultaneously compare device signals with up to two regulatory limits and a specified measurement margin
■Predefined routines automatically measure all signals over a specified frequency range
■Measure, store, and report up to 239 signals automatically
Frequency Specifications
■Frequency Range: 9 kHz to 1.8 GHz
■Frequency Sweep Time: Span 0 Hz, >1 kHz: 20 μs to 100 s
■Resolution Bandwidths: 30 Hz to 3 MHz (1, 3, 10 sequence)
200 Hz, 9 kHz, 120 kHz and 1 MHz (6 dB) EMI bandwidths
■Video Bandwidth Range: 1 Hz to 1 MHz in 1, 3, 10 sequence
Amplitude Specifications
■Amplitude Range: Displayed average noise level to +137 dBμV
■Maximum Safe Input Level (Input attenuator set at ≥ 10 dB)
* Average Continuous Power: +30 dBm
* Peak Pulse Power: +30 dBm
* DC: 25 Vdc
?Displayed Average Noise Level: 400 kHz to 1 GHz 30 Hz RBW 1 kHz RBW
 -23 dBμV -8 dBμV
■Frequency Response: 9 kHz to 1 GHz: ±1.5 dB
Input / Output
Front Panel Connectors
■Input: 50W type N
■Cal Output: 50W BNC -20 dBm 300 MHz
Rear Panel Connector
■Earphone: 1/8" monaural jack
■Interface: GPIB
■High Sweep In/Out: BNC, high TTL = sweep
■Aux Video Out: 50W BNC, 0-1 V
■Aux IF Output: 50W BNC, -10 to 60 DBM, 21.4MHz
■Ext. Trigger Input: BNC TTL levels, positive edge trigger
■Ext. Ref. In: 50W BNC, 10 MHz, -2 to +10 dBm
■10 MHz Ref. Output: 50W BNC, 10 MHz, 0 dBm
■Aux Interface: 9 pin "D" subminiature
■Monitor Out: 50W BNC, NTSC, 15.75 kHz, 60 Hz
Weight: 14.5 kg (32 lbs)
