您的位置:控制工程论坛网论坛 » 工业以太网 » 求助!linux下拨号上网的问题!!
jun997
jun997   |   当前状态:离线
总积分:58  2025年可用积分:0
最后登录时间: 2007-01-25
求助!linux下拨号上网的问题!!
jun997  发表于 2007/1/3 11:28:45      2955 查看 3 回复  [上一主题]  [下一主题]
各位大侠:
有谁做过在linux下利用pppoe进行拨号上网的啊!
请指导一下!
我的环境:  rehat9.0+.rp-pppoe3.7+北京网通宽带
我一直怀疑是设置的问题!但知道怎么去设置!自己是个新手!
出现的问题:
root@localhost etc]# pppoe-start
................TIMED OUT
/usr/sbin/pppoe-start: line 191: 5648 Terminated $CONNECT "$@" >/dev/null 2>&1
[root@localhost etc]# pppoe-status
pppoe-status: Link is down (can't read pppoe PID file /var/run/pppoe.conf-pppoe.pid.pppoe)
/var/log/messages:
27 09:53:17 localhost pppoe-connect: PPPoE connection lost; attempting
re-connection.
Dec 27 09:53:17 localhost /etc/hotplug/net.agent: NET unregister event not
supported
Dec 27 09:53:17 localhost /etc/hotplug/net.agent: assuming ppp0 is already up
Dec 27 09:53:22 localhost pppd[7578]: pppd 2.4.1 started by root, uid 0
Dec 27 09:53:22 localhost pppd[7578]: ioctl(PPPIOCGFLAGS): Inappropriate ioctl
for device
Dec 27 09:53:22 localhost pppd[7578]: Exit.
Dec 27 09:53:22 localhost pppoe-connect: PPPoE connection lost; attempting
re-connection.
Dec 27 09:53:22 localhost /etc/hotplug/net.agent: assuming ppp0 is already up
Dec 27 09:53:22 localhost /etc/hotplug/net.agent: NET unregister event not
supported
Dec 27 09:53:27 localhost pppd[7612]: pppd 2.4.1 started by root, uid 0
Dec 27 09:53:27 localhost pppd[7612]: Using interface ppp0
Dec 27 09:53:27 localhost pppd[7612]: Connect: ppp0 <--> /dev/pts/1
Dec 27 09:53:27 localhost pppd[7612]: Modem hangup
Dec 27 09:53:27 localhost pppd[7612]: Connection terminated.
Dec 27 09:53:27 localhost pppd[7612]: Exit.
  • blue520
    blue520   |   当前状态:在线
    总积分:1506  2025年可用积分:0
    最后登录时间: 2013-11-26
    blue520   发表于 2006/12/30 20:05:22
    不太清楚,但帮你顶一下,让更多的人看到
    引用 blue520 2006/12/30 20:05:22 发表于2楼的内容
  • jun997
    jun997   |   当前状态:离线
    总积分:58  2025年可用积分:0
    最后登录时间: 2007-01-25
    jun997   发表于 2006/12/31 10:22:44
    怎么就没有人知道啊!
    版主!
    求救啊
    引用 jun997 2006/12/31 10:22:44 发表于3楼的内容
  • henry_lin
    henry_lin   |   当前状态:离线
    总积分:60  2025年可用积分:0
    最后登录时间: 2007-01-25
    henry_lin   发表于 2007/1/3 11:28:45
    可以参考下:http://www.xmlenz.com/bbs/forum_posts.asp?TID=150
    引用 henry_lin 2007/1/3 11:28:45 发表于4楼的内容
