您的位置:控制工程论坛网论坛 » 产品供求 » !!!!Q8230|二手8230爱德万光功率计
boyzhou
boyzhou   |   当前状态:在线
总积分:4265  2025年可用积分:0
最后登录时间: 2012-11-03
boyzhou  发表于 2011/6/1 15:43:35      666 查看 0 回复  [上一主题]  [下一主题]
Q8230|二手8230爱德万光功率计
联系人:周壮
联系电话:15899787013
QQ:48394275
Email:boyzhouzhuang@163.com
地址:深圳市福田区福星大厦255
二手仪器回收!承接租赁,维修业务 欢迎来电来函!
Overview
The 8230 is a handheld optical power meter, which is most suitable for R&D and production of LDs, optical pickups, and drives for optical disks.
Nine kinds of optical sensors with various purpose (general-purpose/blue-violet/high-power/three-wavelength) and different shapes (thin-type/cylindrical-type) are available. The three-wavelength optical sensors 82314A, 82324A and 82314W are capable of measuring 405nm, 650nm, 780nm wavelength ranges. The blue-violet optical sensors 82312 and 82322 have realized a flat wavelength sensitivity characteristic and low dependency on an angle of incidence in the 405 nm range. The high-power optical sensors 82313 and 82323 enable high-power measurement of up to 200mW.
The main body that has 5 1/2 digits and 0.001dB resolution display can obtain measurement data easily by using the USB interface installed as standard.
Features
* Various sensors for next-generation optical disks
- Most suitable sensors for Blu-ray disks in the 400nm range (82312/82322/82314A/82314W/82324A)
- Flat wavelength sensitivity characteristic (400nm to 420nm: ±1%typ.) It is not necessary to correct the individual difference in the laser wavelength.
- Low incidence-angle-dependency for high NA pickup such as Blu-ray disk
- Low polarization-dependency; small difference due to polarization of incident angle dependency, and high repeatability in laser and pickup measurements
- Low reflection; less measurement deviation due to multi reflection between the sensor and the pickup
- High-power sensor of up to 200mW (82313/82323).
- Maximum light-receiving power of 200mW for pickup measurement of high-speed rewritable CD/DVD
- It is possible to measure high power density without saturation up to 200mW even at 0.1mmφ spot diameter.
- Low-price general-purpose optical sensor (82311/82321)
- Highly reliable sensor that minimizes sensitivity deviation over time in the 400nm range
- Both thin-type and cylindrical-type optical sensors are available. Manual measurement and system built-in measurement can be performed easily.
- Sensor power calibration wavelength: 405/650/780nm for BD/HD DVD/DVD/CD with high accuracy under actual use conditions
- Maximum three-wavelength power calibration is available on just one sensor by adding the calibration wavelength options. (405nm: OPT+21/650nm: OPT+22/780nm:OPT+23)
