您的位置:控制工程论坛网论坛 » 产品供求 » 供应艾讯宏达G41芯片组ATX主板SYM76941VGGA
grantech
grantech   |   当前状态:在线
总积分:164  2025年可用积分:0
最后登录时间: 2013-09-17
grantech  发表于 2011/6/22 11:45:15      689 查看 0 回复  [上一主题]  [下一主题]
         艾讯宏达近期隆重推出一款支持英特尔G41芯片组的ATX主板SYM76941VGGA。SYM76941VGGA采用Socket   LGA775架构,支持英特尔酷睿4核/酷睿2双核/奔腾D/赛扬D处理器。采用英特尔G41+ICH7(或ICH7R)芯片组,最大支持8GB DDR3 内存。集成2个英特尔82574E PCI-E千兆网络控制器,6个串口,8个USB2.0接口;支持1 个 PCI-EX16, 1个 PCI-EX1, 5 个 PCI扩展槽。SYM76941VGGA主板具备高性价比特点,已隆重上市!
详细规格:
Processor                            Socket LGA775 Support Core 2 Quad Q9000 Series/Core 2 Duo/ Pentium D/Celeron D
Chipset                                Intel G41 + ICH7/ ICH7R(option by MOQ), FSB 800/1066/1333MHz
DRAM                                   2 x 240PIN DIMM DDR3 1066/1333 max up to 8GB
BIOS                                     8Mb AMI Flash ROM
Display                                 Intel GMA X4500, Max. shared system memory up to 1024MB
                                              VGA:2048 x 1536 maximum resolution;DVI:2048 x 1536 maximum resolution
LAN                                      2 x Intel 82574L PCI-E Gigabit LAN
USB                                      8 x USB2.0 (4 by onboard header)
HDD                                     4 x SATA-300 Interface, support RAID 0/1/5/10(ICH7R)
FDD                                      1 x FDD port
Serial Port                            5 x RS232 COM ports,1 x RS232 COM port
Parallel                                 1 x Parallel pin-header
Audio                                     Realtek ALC662 HD audio codec, support 5.1CH audio
Keyboard/Mouse                 2 x PS/2 for Keyboard and Mouse
Digital I/O                               4 input; 4 output
Expansion                             1 x PCI-E x 16, 1 x PCI-E x 1, 5 x PCI slots Expansion
Power Supply                        1 x 24Pin ATX power connector, support AT/ATX mode
Watchdog                                Watchdog timer function (Reset: 1~65535 level)
Operation Temperature        0°~60°C
Humidity                                 10~90%
Dimension                             305mm x 244mm
产品详情请登陆艾讯宏达网站 www.grantech.com.cn 或电话咨询。
