您的位置:控制工程论坛网论坛 » 产品供求 » 二手电子负载 PLZ150W 电源测试仪(曾S13713875417)
szmtyq
szmtyq   |   当前状态:在线
总积分:238  2025年可用积分:0
最后登录时间: 2011-07-16
szmtyq  发表于 2011/7/16 14:04:41      587 查看 0 回复  [上一主题]  [下一主题]
Performance Characteristics of the PLZ150W
Form Factor Benchtop
Type AC
Maximum Power 150 Watts
Minimum Voltage 4 V
Maximum Voltage 60 V
Maximum Current 30 A
Current Ripple and Noise 4 mArms
Constant Current Mode Yes
Constant Voltage Mode Yes
Constant Power Mode No
Constant Resistance Mode Yes
Transient Generator No
Programmability/Connectivity of the PLZ150W
User Interface Proprietary
Ports to Peripheral Devices GPIB
PLZ150W Compliance
CE Compliance Not on file
UL Compliance Not compliant
PLZ150W Power Requirements
Input Power Universal (Auto Sense and Switch)
PLZ150W Physical Dimensions
  • Width: (N/A)
  • Height: 140 mm(5.51 in)
  • Length: 350 mm(13.77 in)
  • Weight: 8 kg(17.63 lb)
