lingbai0401 | 当前状态:在线
总积分:94 2025年可用积分:0
最后登录时间: 2014-03-17
CMU200 CMU200 CMU200 CMU200综合测试仪 姚生15994778006
lingbai0401 发表于 2011/8/31 16:00:23 771 查看 0 回复 [上一主题] [下一主题]
深圳市凯特凯尔通讯有限公司
联系人:姚生15994778006
电话 :0755-83290924
传真 :0755-83290942
QQ :54718757
MSN :lingbai0401@live.cn
邮箱 :lingbai0401@163.com
All standards available in ONE software package
allows fast switching between the networks
Available mobile test applications:
☆ GPRS
☆ EDGE
☆ GSM
☆ Bluetooth
☆ TDMA (IS-136)
☆ AMPS
☆ WCDMA / HSDPA
☆ CDMA2000
Applications coming soon:
WCDMA signalling
CDMA2000 1xEV-DO
Application independent test functionalities
☆ Audio measurements
☆ IQ/IF Interface (R&S CMU-B17) allows measurements under fading conditions
☆ Audio generator and analyzer (R&S CMU-B41) available for comprehensive audio measurements
☆ Spectrum analyzer
☆ Power versus time measurement
☆ RF generator/analyzer
option
Type R&S
Option R&S GSM/GPRS/
EDGE/HSCSD TDMA AMPS cdma2000 WCDMA Bluetooth Order Number
CMU 200
Base unit with following accessories: power cord, operating manual, service manual for instrument + + + + + + 1100.0008.02
CMU-B11 1)
Reference OCXO, aging 2x10 -7 /year; ensures high absolute accuracy, minimum temperature-dependent drift and especially high long-term stability; used for measurements with exact frequency stability requirements o o o o o o 1100.5000.02
CMU-B12 1)
High-stability OCXO, aging 3.5x10 -8 /year. Oven crystal with highest long-term stability; ensures compliance with tolerances specified by GSM; used for highly demanding frequency stability requirements to GSM 11.20 o o o o o o 1100.5100.02
CMU-B17
Analog I/Q IF interface o o - o o - 1100.6906.02
CMU-B21
Versatile signalling unit; provides multistandard signalling hardware; required for WCDMA 3GPP FDD + + + - + + 1100.5200.14
CMU-B41
Audio generator and analyzer; includes audio frequency (AF) generator, voltmeter, distortion meter o o + o o o 1100.5300.02
CMU-B52
Internal versatile multimode speech coder/decoder; R&S CMU-B21 necessary o o - - o o 1100.5400.14
CMU-B53
Bluetooth extension; R&S CMU-B21 necessary - - - - - + 1100.5700.14
CMU-B54
Signalling module for AMPS, TDMA, GSM/GPRS/EGPRS; R&S CMU-B21 necessary + + + - - - 1150.2604.14
CMU-B56
WCDMA (3GPP FDD) signalling module; R&S CMU-B21 necessary - - - - + - 1150.1850.14
CMU-B66 2)
Versatile baseband board for WCDMA (3GPP FDD) Layer 1, DL, non-signalling - - - - + - 1149.9509.02
CMU-B68 2)
Versatile baseband board for WCDMA (3GPP FDD) Layer 1, DL and UL, non-signalling - - - - + - 1149.9809.02
CMU-B69
Option package WCDMA (3GPP/FDD) complete for band 1, signalling - - - - + - 1150.2304.02
CMU-B73
Analog telephone line interface - - o - - - 1150.2004.02
CMU-B83
cdma2000 1x signalling unit - - - + - - 1150.0301.12
CMU-B85
8k/13k QCELP, 8k EVRC speech codec for cdma2000 1x Signalling Unit R&S CMU-B83 - - - o - - 1100.7002.12
CMU-B87
Message monitor for cdma2000 1x Signalling Unit R&S CMU-B83 - - - o - - 1150.2404.02
CMU-B88
cdma2000 1xEV-DO (HDR) extension board for cdma2000 1x Signalling Unit R&S CMU-B83 - - - o - - 1158.9908.02
CMU-B95
2nd TX RF channel; BCCH always present with GSM/GPRS/EGPRS o - - - - - 1159.0504.02
CMU-B99
RF1 level range identical to RF2 o o o o o o 1150.1250.02
CMU-U65
3G measurement DSP and performance accelerator - - - + + - 1100.7402.02
CMU-U80
Trigger output connector for gpsOne - - - o - - 1150.1750.02
CMU-K20
GSM400 mobile station signalling/non-signalling test softwar + - - - - - 1115.5900.02
CMU-K21
GSM900, R-GSM and E-GSM mobile station signalling/non-signalling test software + - - - - - 1115.6007.02
CMU-K22
GSM1800 (DCS) mobile station signalling/non-signalling test software + - - - - - 1115.6107.02
CMU-K23
GSM1900 (PCS) mobile station signalling/non-signalling test software + - - - - - 1115.6207.02
CMU-K24
GSM850 mobile station signalling/non-signalling test software + - - - - - 1115.6307.02
CMU-K27
IS-136/cellular (800 MHz band) mobile station signalling/non-signalling test software - + - - - - 1115.6607.02
CMU-K28
IS-136/PCS (1900 MHz band) mobile station signalling/non-signalling test software - + - - - - 1115.6707.02
CMU-K29
AMPS mobile station signalling/non-signalling test software - - + - - - 1115.6807.02
CMU-K42
GPRS test software extension for all GSM test software packages o - - - - - 1115.4691.02
CMU-K43
EGPRS classic (EDGE) signalling test software for all GSM test software packages o - - - - - 1115.6907.02
CMU-K45
AMR test software extension for all GSM test software packages o - - - - - 1115.3100.02
CMU-K53
Bluetooth test software; R&S CMU-B53 necessary - - - - - + 1115.5000.02
CMU-K65 3)
WCDMA (3GPP/FDD) UL user equipment TX test, non-signalling test software - - - - + - 1115.4891.02
CMU-K66 3)
WCDMA (3GPP/FDD) DL generator, non-signalling test software; R&S CMU-U66 or R&S CMU-B66 necessary - - - - + - 1115.5100.02
CMU-K67
WCDMA (3GPP/FDD) band 3, UE test signalling software; R&S CMU-K65 and R&S CMU-K66 necessary - - - - + - 1150.3000.02
CMU-K68
WCDMA (3GPP/FDD) band 1, UE test signalling software; R&S CMU-K65 and R&S CMU-K66 necessary - - - - + - 1115.5300.02
CMU-K69
WCDMA (3GPP/FDD) band 2, UE test signalling software; R&S CMU-K65 and R&S CMU-K66 necessary - - - - + - 1115.5400.02
CMU-K83
cdma2000 1x (450 MHz band) mobile station signalling/non-signalling test software - - - + - - 1150.3500.02
CMU-K84
cdma2000 1x (cellular band) mobile station signalling/non-signalling test software - - - + - - 1150.3600.02
CMU-K85
cdma2000 1x (PCS band) mobile station signalling/non-signalling test software - - - + - - 1150.3700.02
CMU-K86
cdma2000 1x (IMT2000 band) mobile station signalling/non-signalling test software - - - + - - 1150.3800.02
CMU-K88
cdma2000 1xEV-DO (HDR) test software; R&S CMU-B88 necessary - - - o - - 1150.3900.02
CMU-DCV
Documentation of calibration values o o o o o o 0240.2193.08
CRT-Z2
GSM900/DCS1800 GSM/GPRS test SIM for loopback mode, required for BER and other applications o - - - - - 1039.9005.02
CRT-Z3
3G UICC/USIM test card for UMTS - - - - o - 1139.1005.02
CRT-Z12
GSM850/PCS1900 GSM/GPRS test SIM for loopback mode, required for BER and other applications o - - - - - 1139.1205.02
CMU-Z1
256 Mbyte memory card for use with PCMCIA interface; flash ATA formatted, also named PC Card ATA o o o o o o 1100.7490.04
CMU-Z6
Enhancement of wideband modulation (WCDMA 3GPP FDD) analyzer accuracy - - - - o - 1150.0001.02
CMU-Z10
Antenna coupler 900 MHz/1700 MHz to 2200 MHz o o o o o o 1150.0801.02
CMU-Z11
RF shielded cover for R&S CMU-Z10 o o o o o o 1150.1008.02
CMU-Z12
Bluetooth antenna extension for R&S CMU-Z10 - - - - - o 1150.1043.02
CMU-Z13
USB feed through for R&S CMU-Z10 o o o o o o 1159.1200.02
CMU-Z46
WCDMA (3GPP FDD) message analyzer and recorder for external PC (Win2000, XP) - - - - o - 1159.0804.02
CMU-Z49
GSM message viewer for external PC (Win2000, XP) o - - - - - 1150.2704.02
CMU-Z50
Handset for R&S CMU200 o o o o o o 1159.0104.02
ZZA-411
19" rack adapter o o o o o o 1069.3283.00
