luqiong1983 | 当前状态:在线
总积分:412 2025年可用积分:0
最后登录时间: 2012-01-16
供应/收购54754A 差分和单端TDR/TDT模块13929231880何生
luqiong1983 发表于 2011/10/27 15:59:44 646 查看 0 回复 [上一主题] [下一主题]
东莞市宏达电子仪器有限公司
联系人:何经理/罗S(特助):13549469921
手 机:13929231880/13553856562
客 服QQ:1528273024/153462353
电 话: 0769-84970591 81283426
传 真: 0769-82553292
邮 箱:wsktjhxk@126.com/wm1221@126.com
网 址:http://www.dghd18.com
MSN:wsktjhxk@126.com
贸易通帐户:wsktjhxk
地址:东莞市塘厦镇塘厦大道120号
62.5-fs Resolution
10-ps Accuracy
TDR/TDT测量
存储深度:4k/CH
数据传输率:550Kbytes/s typical
配:Agilent 54753A Single Ended TDR/TDT Plug-In Module
The Agilent 54753A TDR/TDT plug-in modules provide you with TDR and TDT measurement features. In addition to the TDR and TDT measurement features, the TDR plug-ins provide two accurate oscilloscope measurement channels with user selectable bandwidths of 12.4 or 18 GHz. The lower bandwidth mode provides excellent oscilloscope noise performance for accurate measurement of small signals. The high bandwidth mode provides high-fidelity display and measurement of very high-speed waveforms.
通道数:2 CH
用户可选择带宽:12.4 or 18 GHz (Channel 1)
用户可选择带宽:12.4 or 20 GHz (Channel 2)
2.5 GHz 触发通道
带宽:TDR/垂直通道上为20-GHz、18-GHz
垂直精度:0.4%
垂直分辨率:12位(平均值为15)
最大噪声:< 1 mVrms
Automatic and manual single-ended TDR and TDT measurement capability
Automatic and manual waveform, histogram, FFT, waveform math, eye pattern measurements, statistical measurements, and limit testing capabilities
54754A 差分和单端 TDR/TDT 模块
带有3.5 mm(阳性)连接器的两个18 GHz电通道
典型均方根噪声:0.25 mV(12.4 GHz带宽)、0.5 mV(18 GHz带宽)
最大输入信号: ± 2 Vdc
两个内置步进发生器可配置用于1端口、2端口共模或2端口差模TDR或TDT测量。
内置TDR/TDT校准、用户可选的边沿速度、S参数(需要A.06.01或更高版本的主机固件。S参数需要选件202)
