您的位置:控制工程论坛网论坛 » 自动化软件 » VB与台达PLC监控通讯软件
Chennousstar
Chennousstar   |   当前状态:离线
总积分:304  2026年可用积分:0
最后登录时间: 2016-05-24
VB与台达PLC监控通讯软件
Chennousstar  发表于 2008/10/13 14:28:48      4041 查看 9 回复  [上一主题]  [下一主题]
       点击看大图
   今天恰好开博一个月,承蒙各位技术界网友的厚爱,访问量已过千.
为答谢各位网友的支持,也算是一个小小的礼物吧,特将我以VB写的
一个工控通讯程序源码奉上,以资感谢.
 这个程序是VB同台达PLC的通讯调试程序,其于台达系列PLC
MODBUS ASCII协议,涉及IO及寄存器的读写,稍加改动即可用于
工控项目中.我在写这个程序时,也参考了<<基于VB 的台达PLC
监控计算机的串口通讯>>一文,在此也向作者表示感谢.
Dim plc As Byte
Dim y0flag As Byte
Dim y1flag As Byte
Dim str As String
Dim n, S
Private Sub Command1_Click()
Dim strout As String
Dim QQ As String
Timer1.Enabled = False
QQ = Text1.Text
If Len(QQ) = 3 Then
        QQ = "0" & QQ
    ElseIf Len(QQ) = 2 Then
        QQ = "00" & QQ
    ElseIf Len(QQ) = 1 Then
        QQ = "000" & QQ
End If
str = "01061000" + QQ
LRCC = LRC(str)   '计算 str的lrc校验码。
strout = ":" + str + LRCC + Chr$(13) + Chr$(10) '欲传送之数据。13为D,10为A
MSComm1.InBufferCount = 0
MSComm1.Output = strout
Timer1.Enabled = True
End Sub
Private Sub Command2_Click()
End Sub
Private Sub Form_Load()
    Dim s1 As String
    Dim s2 As String
    Dim s22 As String
    Dim s3 As String
    Dim s4 As String
    Picture1.Move 0, 0, 5600, 280   '长度可随意改
    n = -(Me.TextWidth(Now)) - 10
    MSComm1.PortOpen = True
    s2 = "01010C300001"
    s22 = LRC(s2)
    s1 = ":" + s2 + s22 + Chr$(13) + Chr$(10)
    MSComm1.Output = s1
    TimeDelay (500)
    s3 = MSComm1.Input
    s4 = Mid$(s3, 8, 2)
    If s4 = "31" Then
        plc = 1
    Else: If s4 = "30" Then plc = 0
    End If
    If plc = 1 Then
        Label2.Caption = "PLC Running"
        Shape1.FillColor = RGB(0, 255, 0) 'green
    Else
        Label2.Caption = "PLC Stopped!"
        Shape1.FillColor = RGB(255, 0, 0) 'red
    End If
End Sub
 Public Function LRC(str As String) As String
    c = 0
    l = Len(str)
    For c = c + 1 To l
        c_data = Mid$(str, c, 2)
        d_lrc = d_lrc + Val("&H" + c_data)
        c = c + 1
    Next c
    If d_lrc > &HFF Then
        d_lrc = d_lrc Mod &H100
    End If
    h_lrc = Hex(&HFF - d_lrc + 1)
    If Len(h_lrc) > 2 Then
        h_lrc = Mid(h_lrc, Len(h_lrc) - 1, 2)
    End If
        LRC = h_lrc
    End Function
Private Sub start_Click()
str = "01050C30FF00"  'M1072 为PLC起动停止标志位。查地址表,M1072为OC30.FF00为置
                      '   ON,0000为置OFF。
End Sub
Private Sub stop_Click()
str = "01050C300000"
LRCC = LRC(str)
End Sub
Private Sub Text1_KeyPress(KeyAscii As Integer)
'判断输入的是否为数字或是 Enter
    If (KeyAscii >= 48 And KeyAscii <= 57) Or KeyAscii = 13 Or (KeyAscii >= 65 And KeyAscii <= 70) Then
    Else
      KeyAscii = 0
      Exit Sub
    End If
End Sub
Private Sub Timer1_Timer()
Dim s1, s22, s3, s4, s5 As String
Dim s2 As String
Dim counter As Integer
  Picture1.AutoRedraw = True
  Picture1.Cls
  n = n + 10
  If Picture1.ScaleWidth <= S Then
  End If
  Picture1.CurrentX = n
  S = n
  Picture1.CurrentY = 0
  Picture1.Print Now & "  Chennousstar@sina.com"
  Picture1.AutoRedraw = False
s2 = "01010C300001"          'M1072 Start/Stop Flag
s22 = LRC(s2)
MSComm1.Output = s1
'TimeDelay (200)
s3 = WaitRS(MSComm1, vbCrLf, 200)
s4 = Mid$(s3, 8, 2)
If s4 = "31" Then
    plc = 1
End If
If plc = 1 Then
Else
End If
s2 = "010108000002"          'Read Y0 Flag
s3 = ""
s22 = LRC(s2)
MSComm1.Output = s1
'TimeDelay (200)
If s3 = "" Then Exit Sub
s4 = Mid$(s3, 8, 2) And &H1
s5 = Mid$(s3, 8, 2) And &H2
If s4 = "1" Then
    y0flag = 1
Else: If s4 = "0" Then y0flag = 0
End If
If y0flag = 1 Then
    Shape2.FillColor = RGB(0, 255, 0) 'green
Else
    Shape2.FillColor = RGB(255, 0, 0) 'red
End If
If s5 = "2" Then
    y1flag = 1
Else: If s5 = "0" Then y1flag = 0
End If
If y1flag = 1 Then
    Shape3.FillColor = RGB(0, 255, 0) 'green
Else
    Shape3.FillColor = RGB(255, 0, 0) 'red
End If
's2 = "010310000001"          'Read D512 value
's3 = ""
's22 = LRC(s2)
's1 = ":" + s2 + s22 + Chr$(13) + Chr$(10)
'MSComm1.InBufferCount = 0
'MSComm1.Output = s1
'TimeDelay (200)
's3 = WaitRS(MSComm1, vbCrLf, 200)
's4 = Mid$(s3, 8, 4)
'Text1.Text = s4
s2 = "010310000001"          'Read D0 value
s3 = ""
s22 = LRC(s2)
MSComm1.Output = s1
'TimeDelay (200)
s4 = Mid$(s3, 8, 4)
Text2.Text = s4
End Sub
Private Sub Y1_Click()
    If y1flag = 0 Then
        str = "01050801FF00"
    Else
        str = "010508010000"
    End If
End Sub
Private Sub YO_Click()
    If y0flag = 0 Then
        str = "01050800FF00"
    Else
        str = "010508000000"
    End If
End Sub
VB源代码rar
  • 匿名
    匿名   |   当前状态:离线
    总积分:0  2026年可用积分:0
    匿名   发表于 2007/3/15 23:45:45
    希望今后还能看到您更多的作品
    引用 匿名 2007/3/15 23:45:45 发表于2楼的内容
  • JNZHLF
    JNZHLF   |   当前状态:在线
    总积分:2642  2026年可用积分:0
    最后登录时间: 2012-12-29
    JNZHLF   发表于 2007/3/16 1:32:09
    引用 JNZHLF 2007/3/16 1:32:09 发表于3楼的内容
  • YTZIDONGHUA
    YTZIDONGHUA   |   当前状态:在线
    总积分:11263  2026年可用积分:0
    最后登录时间: 2024-08-02
    YTZIDONGHUA   发表于 2007/3/17 15:49:24
    不错!
    引用 YTZIDONGHUA 2007/3/17 15:49:24 发表于4楼的内容
  • havt
    havt   |   当前状态:离线
    总积分:56  2026年可用积分:0
    最后登录时间: 2007-05-16
    havt   发表于 2007/5/16 23:36:56
    代码怎么下?
    引用 havt 2007/5/16 23:36:56 发表于5楼的内容
  • wqeaz
    wqeaz   |   当前状态:离线
    总积分:58  2026年可用积分:0
    最后登录时间: 2007-06-15
    wqeaz   发表于 2007/6/15 1:26:05
    kankan
    6楼 回复本楼
    引用 wqeaz 2007/6/15 1:26:05 发表于6楼的内容
  • Chennousstar
    总积分:304  2026年可用积分:0
    最后登录时间: 2016-05-24
    Chennousstar   发表于 2007/6/26 14:48:21
    经过一段时间的努力,通过侦听解析,西门子PPI协议终于被攻克了.
    现以此协议做了个上位机调试软件,欢迎大家试用.
    Email: Chennousstar@sina.com
    一.基本功能
         1.  读写出寄存器的数值(字节、字、双字)
         2、进行元件(V、M、S、Q、I)的置、复位操作
         3.  读取C,T当前值
         4、可以读取元件(V、M、S、Q、I)的ON/OFF状态。
         5、可以登录并控制PLC的运行、停止。
         6.   图形曲线监控方式
         7.   图表添加监控方式
    二. 主画面
    点击看大图
    三.图形及曲线监控方式
    点击看大图
    四.图表监控方式
    点击看大图
    (点击图形可看清细节).
    本软件有偿转让源码.不同于市面上已出现
    的所谓源码,实际上是封装控件,获取者只是
    做简单调用,并不能理解PPI协议的实质,更
    谈不上灵活运用或更复杂应用.本软件是真
    正的源代码开放,不含任何自封装控件,用户
    可快速掌握PPI协议通讯,可极大缩短项目的
    开发时间及提高项目质量.rarrarrar
    7楼 回复本楼
    引用 Chennousstar 2007/6/26 14:48:21 发表于7楼的内容
  • nicholaseen
    nicholaseen   |   当前状态:离线
    总积分:67  2026年可用积分:0
    最后登录时间: 2008-06-11
    nicholaseen   发表于 2008/6/7 11:05:04
    谢谢了,非常感谢,呵呵,
    8楼 回复本楼
    引用 nicholaseen 2008/6/7 11:05:04 发表于8楼的内容
  • 匿名
    匿名   |   当前状态:离线
    总积分:0  2026年可用积分:0
    匿名   发表于 2008/10/11 16:56:40
    很  感谢LZ的无私
    9楼 回复本楼
    引用 匿名 2008/10/11 16:56:40 发表于9楼的内容
  • tony_k
    tony_k   |   当前状态:离线
    总积分:917  2026年可用积分:0
    最后登录时间: 2008-11-28
    tony_k   发表于 2008/10/13 14:28:48
    非常感谢版主,,以后还有很多问题需要请教你;;;
    10楼 回复本楼
    引用 tony_k 2008/10/13 14:28:48 发表于10楼的内容
