您的位置:控制工程论坛网论坛 » 嵌入式系统 » c51写的24c02的读写程序
zhd
zhd   |   当前状态:离线
总积分:639  2025年可用积分:0
最后登录时间: 2017-07-06
c51写的24c02的读写程序
zhd  发表于 2007/3/14 22:10:10      1326 查看 1 回复  [上一主题]  [下一主题]
#include <reg51.h>
// 对24C02的读、写
// extern void DelayMs(unsigned int);
// extern void Read24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes);
// extern void Write24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes);
#define WriteDeviceAddress 0xa0
#define ReadDviceAddress 0xa1
sbit SCL=P1^4;
sbit SDA=P1^3;
sbit DOG=P3^7;
void DelayMs(unsigned int number) {
 unsigned char temp;
 for(;number!=0;number--,DOG=!DOG) {
  for(temp=112;temp!=0;temp--) {
void Start() {
 SDA=1;
 SCL=1;
 SDA=0;
 SCL=0;
void Stop() {
 SCL=0;
 SDA=0;
 SCL=1;
 SDA=1;
void Ack() {
 SDA=0;
 SCL=1;
 SCL=0;
 SDA=1;
void NoAck() {
 SDA=1;
 SCL=1;
 SCL=0;
bit TestAck() {
 bit ErrorBit;
 SDA=1;
 SCL=1;
 ErrorBit=SDA;
 SCL=0;
 return(ErrorBit);
bit Write8Bit(unsigned char input) {
 unsigned char temp;
 for(temp=8;temp!=0;temp--) {
  SDA=(bit)(input&0x80);
  SCL=1;
  SCL=0;
  input=input<<1;
void Write24c02(unsigned char *Wdata,unsigned char RomAddress,unsigned char number) {
 Start();
 Write8Bit(WriteDeviceAddress);
 TestAck();
 Write8Bit(RomAddress);
 TestAck();
 for(;number!=0;number--) {
  Write8Bit(*Wdata);
  TestAck();
  Wdata++;
 Stop();
 DelayMs(10);
unsigned char Read8Bit() {
 unsigned char temp,rbyte=0;
  SCL=1;
  rbyte=rbyte<<1;
  rbyte=rbyte|((unsigned char)(SDA));
  SCL=0;
 return(rbyte);
void Read24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes) {
 unsigned char temp,rbyte;
 Start();
 TestAck();
 TestAck();
 Start();
 Write8Bit(ReadDviceAddress);
 TestAck();
 while(bytes!=1) {
 *RamAddress=Read8Bit();
 Ack();
 RamAddress++;
 bytes--;
 NoAck();
 Stop();
