Chennousstar | 当前状态:离线
总积分:304 2025年可用积分:0
最后登录时间: 2016-05-24
带有CRC校验的DS18B20程序
Chennousstar 发表于 2007/3/22 12:47:08 3655 查看 2 回复 [上一主题] [下一主题]
近期花了不少时间研究DS18B20-一线制温度传感器,
陆续会贴些总结心得及其不错的程序及其算法.
*18B20驱动程序,DQ为数据口,接于P2.1
*11.0592M晶振,上拉4.7k电阻
*Author:fyb
*2005-3-25 11:23,OK!
#include
#include
#define uchar unsigned char
#define uint unsigned int
sbit dq = P1^7;
bit flag;
uint Temperature;
uchar temp_buff[9]; //存储读取的字节,read scratchpad为9字节,read rom ID为8字节
uchar id_buff[8];
uchar *p;
uchar crc_data;
uchar code CrcTable [256]={
0, 94, 188, 226, 97, 63, 221, 131, 194, 156, 126, 32, 163, 253, 31, 65,
157, 195, 33, 127, 252, 162, 64, 30, 95, 1, 227, 189, 62, 96, 130, 220,
35, 125, 159, 193, 66, 28, 254, 160, 225, 191, 93, 3, 128, 222, 60, 98,
190, 224, 2, 92, 223, 129, 99, 61, 124, 34, 192, 158, 29, 67, 161, 255,
70, 24, 250, 164, 39, 121, 155, 197, 132, 218, 56, 102, 229, 187, 89, 7,
219, 133, 103, 57, 186, 228, 6, 88, 25, 71, 165, 251, 120, 38, 196, 154,
101, 59, 217, 135, 4, 90, 184, 230, 167, 249, 27, 69, 198, 152, 122, 36,
248, 166, 68, 26, 153, 199, 37, 123, 58, 100, 134, 216, 91, 5, 231, 185,
140, 210, 48, 110, 237, 179, 81, 15, 78, 16, 242, 172, 47, 113, 147, 205,
17, 79, 173, 243, 112, 46, 204, 146, 211, 141, 111, 49, 178, 236, 14, 80,
175, 241, 19, 77, 206, 144, 114, 44, 109, 51, 209, 143, 12, 82, 176, 238,
50, 108, 142, 208, 83, 13, 239, 177, 240, 174, 76, 18, 145, 207, 45, 115,
202, 148, 118, 40, 171, 245, 23, 73, 8, 86, 180, 234, 105, 55, 213, 139,
87, 9, 235, 181, 54, 104, 138, 212, 149, 203, 41, 119, 244, 170, 72, 22,
233, 183, 85, 11, 136, 214, 52, 106, 43, 117, 151, 201, 74, 20, 246, 168,
116, 42, 200, 150, 21, 75, 169, 247, 182, 232, 10, 84, 215, 137, 107, 53};
*Function:延时处理
*parameter:
*Return:
*Modify:
void TempDelay (uchar us)
while(us--);
*Function:18B20初始化
*parameter:
*Return:
*Modify:
void Init18b20 (void)
dq=1;
_nop_();
dq=0;
TempDelay(86); //delay 530 uS//80
_nop_();
dq=1;
TempDelay(14); //delay 100 uS//14
_nop_();
_nop_();
_nop_();
if(dq==0)
flag = 1; //detect 1820 success!
else
flag = 0; //detect 1820 fail!
TempDelay(20); //20
_nop_();
_nop_();
dq = 1;
*Function:向18B20写入一个字节
*parameter:
*Return:
*Modify:
void WriteByte (uchar wr) //单字节写入
uchar i;
for (i=0;i<8;i++)
dq = 0;
_nop_();
dq="wr"&0x01;
TempDelay(5); //delay 45 uS //5
_nop_();
_nop_();
dq="1";
wr >>= 1;
*Function:读18B20的一个字节
*parameter:
*Return:
*Modify:
uchar ReadByte (void) //读取单字节
uchar i,u=0;
for(i=0;i<8;i++)
dq = 0;
u >>= 1;
dq = 1;
if(dq==1)
u |= 0x80;
TempDelay (4);
_nop_();
return(u);
*Function:读18B20
*parameter:
*Return:
*Modify:
void read_bytes (uchar j)
uchar i;
for(i=0;i {
*p = ReadByte();
p++;
*Function:CRC校验
*parameter:
*Return:
*Modify:
uchar CRC (uchar j)
uchar i,crc_data=0;
for(i=0;i crc_data = CrcTable[crc_data^temp_buff[i]];
return (crc_data);
*Function:读取温度
*parameter:
*Return:
*Modify:
void GemTemp (void)
read_bytes (9);
if (CRC(9)==0) //校验正确
Temperature = temp_buff[1]*0x100 + temp_buff[0];
// Temperature *= 0.625;
Temperature /= 16;
TempDelay(1);
*Function:内部配置
*parameter:
*Return:
*Modify:
void Config18b20 (void) //重新配置报警限定值和分辨率
Init18b20();
WriteByte(0xcc); //skip rom
WriteByte(0x4e); //write scratchpad
WriteByte(0x19); //上限
WriteByte(0x1a); //下限
WriteByte(0x7f); //set 11 bit (0.125)
Init18b20();
WriteByte(0x48); //保存设定值
Init18b20();
WriteByte(0xb8); //回调设定值
*Function:读18B20ID
*parameter:
*Return:
*Modify:
void ReadID (void)//读取器件 id
Init18b20();
WriteByte(0x33); //read rom
read_bytes(8);
*Function:18B20ID全处理
*parameter:
*Return:
*Modify:
void TemperatuerResult(void)
p = id_buff;
ReadID();
Config18b20();
Init18b20 ();
WriteByte(0x44); //Temperature convert
Init18b20 ();
WriteByte(0xbe); //read Temperature
p = temp_buff;
GemTemp();
void main ()
TemperatuerResult ();
