您的位置:控制工程论坛网论坛 » 产品供求 » 销售/回收/维修函数信号发生器AGILENT33120a HP33120A HP 33120A
xnt002
xnt002   |   当前状态:在线
总积分:468  2025年可用积分:0
最后登录时间: 2014-09-12
xnt002  发表于 2012/2/9 13:46:14      513 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1780114589
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt008@126.com<SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
产品名称: HP33120A任意波形发生器
型 号:
HP33120A
厂 商:
美国惠普/安捷伦
●10种标准波形,正弦波和方波可达15MHz
●可用40MSaYs的速度和4个16,000点的波形存储 构建任意波形
●纯净的信号HD<0.04%,平坦度低至±0.1dB
内置16K深度的任意波形发生器处理你所需要的自定义波形.
内部AM,FM,FSK和脉冲串调制功能使你不需要第2个调制源.
HPBenchLinkArb软件可使用简单的图形工具,或从其它程序输入的数据构建波形.
HP33120A函数/任意波形发生器能以令你财务部门都满意的价格提供高度稳定的数字合成信号.
你得到的不仅是更好的性能,而且这是你第一次在这一价位上得到任意波形.你可用它构建复杂的自定义波形(具有12bit分辩率),包括模拟心律波和测试电路的振荡波形.而过去在这一价位上是不可能实现的.
低价并不意味着混有杂乱的谐波和其它多余成分,把这一价位上的其它函数/任意波形发生器与HP33120A的谐波失真指标作一比较吧.
扫描和调制扩展了你的测试能力而并没有增加你的测试设备.此外,标准HP-IB和RS-232接口通过可编程仪器的标准命令(SCPl)使你得到全部编程能力.
选件001相位锁定/时基选件增加了HP33120A的频率稳定度,为系统提供了新的能力.它可产生精密相位偏置信号,锁定2台HP33120A的相位,或把信号发生器与10MHz频标同步,甚至可把整套ATE系统锁定于一个主时钟.
HP33120A函数/任意波形发生器
波形:正弦波,方波,三角波,斜波,噪声,SIN(x)/x,
标准波形:指数上升和下降,心律波,直流电压
任意波形
波形长度-16,000点
非易失性存储器:4个波形(每一个波形8-16,000点)
幅度分辨率:12bit
采样率 40MSa/s
频率特性
正弦波 100μHz~15MHz
100μHz~15MHz
100μHz~100KHz
100μHz~100KHz 白噪声
分辨率
准确度 10MHz带宽
10μHz或10字
10ppm,90天
(18-28℃)
正弦波
谐波失真
dc~20KHz -70dBc
20KHz~100KHz -60dBc
100KHz~1MHz -45dBc
1MHz~15MHz -35dBc
THD dc至20KHz<0.04%
其它指标
幅度
(至50Ω) 50mVpp-10Vpp
(至开路) 100mVpp-20Vpp
准确度(1KHz) 设定输出的±1%
平坦度(相对于1KHz正弦波,50Ω)
<100KHz ±1%(0.1dB)
100KHz~1MHz ±1.5%(0.15dB)
1MHz~15MHz ±2%(0.2dB)
调制
AM
载波-3dB频率
调制
频率
深度
FM
调制
频率
偏移
FSK
15MHz(典型值)
任何内部波形
包括任意波形
10mHz~20KHz
0%~120%
内部/外部
任何内部波形
包括任意波形
10mHz~10KHz
10mHz~15MHz
仅内部使用
内部速率
偏移
脉冲群(Burst)
载波频率
计数
起始相位
内部速率
闸门源
触发源
10mHz~50KHz
10mHz~15MHz
内部/外部
(最大1MHz)
最大5MHz
1~50,000或无穷多
-360°~+360°
10mHz~50KHz,±1%
内部/外部闸门
单次,外部或内部速率
001相位锁定/TCXO时基选件
时期准确度
稳定率:±1ppm 0℃~50℃
老化率:<2ppm,在最初30天中(连续工作)
0.1ppm/月(第一个月后)
外部基准/输入
锁定范围 10MHz±50Hz
内部基准/输出
频率 10MHz
电源 100V/120V/220V/240V
重量: 4kg
尺寸: 103.6mmHx254.4mmWx374mmD
