您的位置:控制工程论坛网论坛 » 产品供求 » 全功能线材测试机CT-8681N/CT-8681F/CT-8681FA,张先生:13652350058
xnt002
xnt002   |   当前状态:在线
总积分:468  2025年可用积分:0
最后登录时间: 2014-09-12
xnt002  发表于 2012/2/10 13:24:42      373 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1780114589
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt008@126.com<SPAN .="mso-spacerun: yes">                            <SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
CT-8681精密線材測試機
產品型號:CT-8681
.最高1000Vdc/500Vac 測試
.自動掃描找點
.單邊線材測試
.瞬間短段路測試
.大型 320x240 LCD 顯示
.可程式化測試設定
.統計及列印功能
CT-8681 功能
測試項目 符號 測試範圍
電阻 R 0.1Ω~1MΩ
電容 C 10pF~500μF
二極體測試 D 0.0V~7.0V
導通 COND 0.1Ω~50Ω
絕緣 IR 1MΩ~500MΩ
高壓 (漏電流) HIPOT 0.1mA~5mA
斷/短 路 O/S 2kΩ~50kΩ
單邊測試
斷短路端點判斷
CT-8681.規格
進階功能 可程式連續測試
自動學習自動找點
自我診\斷
自我校正歸零
基本精準度 ±1%
測試掃描模式 自動/手動 可切換
量測頻率與訊號/電壓
低電壓量測訊號
高壓(絕緣)測試
100~100kHz, 1Vac
5Vdc / 50mA max. ±5%
200~1000Vac. ±5%
100~500Vac. ±5% (FA機種)
量測接點 128量測接點 (可選購256/512點)
Hipot Calibration +/- Output
Auto Pin Search Jack
面板按鍵 Syskey / Fastkey / Editkey
I/O 介面 RS-232 Port
Printer Port
Remote Control Port
記憶體 最多可儲存56組設定
電源輸入 115/230Vac 60/50Hz ± 10% Switchable
配件 自動找點探針
治具排線
使用手冊
電源線
Remote Control Cable (選購)
RS-232 Cable (選購)
操作環境 溫溼度 15°C~35°C. RH≦75%
尺寸 (WxHxD) 425 x 190 x 350mm
重量 14kgs
線材規格要求 1μF Max.
訂購代號
CT-8681N Cable Tester (700Vdc)
CT-8681F Cable Tester (1000Vdc)
CT-8681FA Cable Tester (700Vdc/500Vac)
/C2 256測試點
/C3 512測試點
<IMG id=paperPicArea1 src="http://ctc.qzs.qq.com/ac/b.gif" .="DISPLAY: none; POSITION: relative; TOP: auto">
