您的位置:控制工程论坛网论坛 » 产品供求 » 销售/维修可程式恒温恒湿机/恒温恒湿箱XNT-831,张先生:13652350058
xnt002
xnt002   |   当前状态:在线
总积分:468  2025年可用积分:0
最后登录时间: 2014-09-12
xnt002  发表于 2012/2/10 13:35:01      372 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1780114589
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt008@126.com<SPAN .="mso-spacerun: yes">
<P align=left .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">张先生:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">13652350058
<P .="MsoNormal">
主要技术指标
<TABLE .="BORDER-RIGHT: #d4eff7 1px solid; BORDER-TOP: #d4eff7 1px solid; BORDER-LEFT: #d4eff7 1px solid; WIDTH: 98%; BORDER-BOTTOM: #d4eff7 1px solid">
<TR .="tr3">
项目
说明
<TR .="tr3">
产品名称
可程式恒温恒湿试验箱
<TR .="tr3">
型号
TOS-831(可根据客户要求订制合适尺寸)
<TR .="tr3">
工作室尺寸(mm)
400×500×500(深×宽×高)(可根据客户要求订制合适尺寸)
<TR .="tr3">
外形尺寸(mm)
以实际尺寸为准
<TR .="tr3">
测试范围
温度范围
0℃/-20℃/-40℃/-60℃~+70℃/+100℃/+130℃/+150℃
(可根据客户要求订制)
<TR .="tr3">
湿度范围
20%/30%~95%RH/98%RH (相对湿度)
<TR .="tr3">
升降温速率
升温速率
+20℃~+70℃ 约30min内
<TR .="tr3">
降温速率
+20℃~―50℃ 约70min内
<TR .="tr3">
温度波动度
±2℃
<TR .="tr3">
湿度波动度
±2%R·H
<TR .="tr3">
温度均匀度
±2℃
<TR .="tr3">
湿度均匀度
±2%R·H
<TR .="tr3">
注:以上性能指标是在室温为+25℃,无试样条件下测得的数值。
<TR .="tr3">
内箱材质
SUS304# 镜面不锈钢板
<TR .="tr3">
外箱材质
SUS304# 拉丝不锈钢板或A3板喷塑或烤漆
<TR .="tr3">
保温材质
聚氨酯发泡或耐高温保温棉
<TR .="tr3">
风路机件
离心风机;风口可调试风量大小、高低及回风量
<TR .="tr3">
单开门,采用双层耐高低温不锈钢板及硅橡胶二层密封以确保测试区之密闭
<TR .="tr3">
测试视窗
门上设有1个导电膜防爆钢化保温玻璃观察窗
(具有防凝露功能)
<TR .="tr3">
风机
长轴离心风机
<TR .="tr3">
样品架
内置不锈钢可调式活动盘架两只
<TR .="tr3">
叶轮
采用台湾进口叶轮
<TR .="tr3">
加热器
镍铬合金电加热器
<TR .="tr3">
制冷压缩机
采用进口冷冻压缩机
<TR .="tr3">
蒸发器
翅片式换蒸发器
<TR .="tr3">
制冷方式
机械压缩机单级制冷
<TR .="tr3">
冷却方式
风 冷
<TR .="tr3">
控温仪表
880智能彩色液晶屏触摸式可编程控制器单点按健编程控制器
<TR .="tr3">
引线孔
机器左侧Φ60mm或根据客户要求定制。
<TR .="tr3">
使用环境:工作环境温度5℃-30℃内使用
2 加热、制冷、加湿系统及其工作原理
<TR .="tr3">
项目
原理说明
<TR .="tr3">
加热系统
不锈钢管套式防干烧加热管内置镍铬合金加热丝
<TR .="tr3">
采用U型鳍片式不锈钢高速加温电热器加热
<TR .="tr3">
完全独立系统,不影响控制线路
<TR .="tr3">
加湿系统
采用自动控制水位,箱体自动补水系统
<TR .="tr3">
采用宽带式强迫气流循环(表面蒸发式)加湿
<TR .="tr3">
加湿管全不锈钢套管,具有防干烧功能
<TR .="tr3">
水质:电阻率>500Ω·M
<TR .="tr3">
冷冻压缩机
采用进口冷冻压缩机,使用环保冷剂
<TR .="tr3">
冷媒铜管
内螺旋式K—TYPE冷媒铜管
<TR .="tr3">
冷凝器
波浪状鳍片型风冷冷凝器
<TR .="tr3">
蒸发器
斜率式FIN—TUBE蒸发器
<TR .="tr3">
冷冻元件
原装进口电磁阀、干燥过漉器等。
<TR .="tr3">
特点
全系统管路均作通气加压22kg检漏测试。
<TR .="tr3">
加温、降温系统完全独立
<TR .="tr3">
配有本公司专业技术特点,防高温高压气流回流开冷机损坏系统
<TR .="tr3">
所有冷冻系统动作程序,完全由微电脑控制器控制
3 调节系统
<TR .="tr3">
项目
说明
<TR .="tr3">
调节方式
强制循环通风,平衡调温法。控制系统根据系统设定的温度点通过PID自动运算输出的结果去控制加热器的输出量,最终达到一种动态的平衡。
<TR .="tr3">
循环装置
内置空调间、循环风道及长轴流式通风机,通过改善空气的鼓动气流,提高了空气的流量和加热的能力,大幅改善了试验箱的温度均匀性。 4 安全保护措施
<TR .="tr3">
项目
说明
<TR .="tr3">
1
电源用漏电保护;
<TR .="tr3">
2
极限高低温保护;温度偏差报警;
<TR .="tr3">
3
防干烧装置,水路系统保护
<TR .="tr3">
4
压缩机过热、过载、过流、超压保护
<TR .="tr3">
5
相序缺相保护;
5 程序控制器介绍
<TR .="tr3">
项目
说明
<TR .="tr3">
控制器
880液晶触摸式可编程控制器,界面118.18×89.38mm
<TR .="tr3">
触摸式高析度荧幕
可任意设定固定条件程序条件,可中文画面,并可设定固化试验名称、序号等。
<TR .="tr3">
可设定时间范围
0—999H59min。
<TR .="tr3">
可程式模式
同时设定120组不同条件之程式,任一组程序中,可分120段进行工作,可任意截取部分段数来执行循环,或作任意段、组的周期循环工作。
<TR .="tr3">
每组程序内,最多可设定120段不同之温度及时间(每段最大可设定999h59min)120组程式又可任意作串接,最大段数循环周期可达999次。
<TR .="tr3">
安全
具有断电记忆装置,复电时可继续执行剩余之程式,并且可作机器预约执行启动及机器运转时间。
<TR .="tr3">
控制
升、降温可作斜率控制、曲线控制,并且具有自行校正温度、湿度基准点之功能。具有PID自动演算之功能,可减少人为设定时所带来之便。
<TR .="tr3">
设置
触摸式设定、安位直接显示、所有条件完全由微电脑自动锁定
<TR .="tr3">
报警
在设定或运转中如发生错误时,会提供警示讯号
<TR .="tr3">
输出
控制器具有记录讯号端口输出,可连接温湿度记录仪
<TR .="tr3">
接口
具备标准RS—232通讯界面,传输距离长,可连线PC作控制及记录。
