您的位置:控制工程论坛网论坛 » 产品供求 » 数字万用表F287 FLUKE287 F289 FLUKE289,张先生:13652350058
xnt002
xnt002   |   当前状态:在线
总积分:468  2025年可用积分:0
最后登录时间: 2014-09-12
xnt002  发表于 2012/2/10 13:35:46      390 查看 0 回复  [上一主题]  [下一主题]
数字万用表F287 FLUKE287 F289 FLUKE289,<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">张先生:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">13652350058
<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1780114589
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt008@126.com<SPAN .="mso-spacerun: yes">
Fluke F287 真有效值数据存储型万用表
厂商名称: Fluke(福禄克)
商品名称: 真有效值数据存储型万用表
商品型号: F287
简单信息: 带有趋势捕获 (TrendCapture) 功能的 Fluke 287 真有效值数据存储型万用表可快速对设计性能进行归档,并以图形方式显示发生的事件。它具有独特的记录存储和图形绘制功能,这意味着您不再需要将记录的读数下载到 PC 上来查看趋势。Fluke 287 将更高的精度和操作方便性集中到一个手持式万用表中。
新功能? TrendCapture “趋势捕获”功能。用于在现场检测设计性能或进行无人看管的监视。用户无需 PC 即可查看记录的读数。
新功能? 按钮。用于测量功能的内置帮助屏幕。
新功能? 通过对测量值进行保存,您可以对现场进行的测量进行命名和调用。
新功能? 多语言界面
不用进行下载而实现多个记录进程
0.025 % 基本直流准确度
100 kHz 交流带宽
用于对保存的读数自动标记时间的实时时钟
真有效值交流电压和电流测量功能可对非线性负载上的负载信号进行精确测量。交流带宽可达 100 kHz。
测量最高10 A电流(20 A测量时间为 30 s)
100 mF 电容范围
温度测量功能
相对模式可在低电阻或电容测量中将测试线电阻扣除
峰值捕获功能可记录快至 250 祍 的瞬变
随附优质测试线和鳄鱼夹
通过可选的 FlukeView Forms 软件,可以对读数或一系列测量值进行归档、存储和分析,然后将他们转换为具有专业外观的文档
通过可选的磁性挂钩,可以将仪表悬挂,以便在双手集中于工作时进行查看
限使用期保修
技术参数
功能
量程和分辨率
基本准确度
直流电压
交流电压
50.000 mV,500.00 mV,5.0000 V,50.000 V,500.00 V,1000.0 V
0.025 %
0.4 %(真有效值)
直流电流
交流电流
500.00 礎,5000.0 礎,50.000 mA,400.00 mA,5.0000 A,10.000 A
0.15 %
0.7 %(真有效值)
温度
(不包括探头)
-200.0 °C至1090.0 °C(-328.0 °F至1994.0 °F)
1.0 %
电阻
500.00 Ω,5.0000 kΩ,50.000 kΩ,500.00 kΩ,5.0000 MΩ,50.00 MΩ,500.0 MΩ
0.05 %
电容
1.000 nF,10.00 nF,100.0 nF,1.000 礔,10.00 礔,100.0 礔,1000 礔,10.00 mF,100 mF
1.0 %
频率
99.999 Hz,999.99 Hz,9.9999 kHz,99.999 kHz,999.99 kHz
0.005 %
附加功能/特性
Fluke 287
多重屏幕显示
真有效值交流带宽
100 kHz
dBV/dBm
DC mV 分辨率
1 礦
兆欧量程
最高500 M
电导
50.00 nS
连续性蜂鸣器
电池/容电器
电池/熔断器
经过时间时钟
每日时间时钟
最小值/最大值/平均值
峰值
250 礢
占空比
0.01 % 至 99.99 %
脉冲宽度
0.025 ms,0.25 ms,2.5 ms,1250.0 ms
保持
隔离光学接口
自动/触摸保持
读数存储器
记录至 PC
间隔/事件记录
记录存储器
最多 10000 个读数
