您的位置:控制工程论坛网论坛 » 产品供求 » GSM综合测试仪) HP8922M HP-8922M,张先生:13652350058
xnt002
xnt002   |   当前状态:在线
总积分:468  2025年可用积分:0
最后登录时间: 2014-09-12
xnt002  发表于 2012/2/10 13:38:00      428 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1780114589
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt008@126.com<SPAN .="mso-spacerun: yes">
详细资料:
特征:
完整的GSM/DCS/PCS移动台测试装置
为最大的限度降低生产/使用费用而设计
各种仪器的内置工具套件
E-GSM和双频段能力
迅速并易于使用
HSCSD测试方案
准确和可重复的GSM测量
内置IBASIC控制器,易于自动测试
HP 8922M GSM测试装置
HP 8922 GSM测试装置可以理想地用于R&D、高层维护服务和生产制造方面,易于使用、丰富而灵活的功能特性使它成为实验台工作选择的仪器。HP 8922的速度、准确度和重复度使它能够理想地用于来货输入检验和大量生产方面。HP 8922包括一个GSM基站仿真器及所有信令和测量的能力,能够全面地测试移动台而无需任何附加设备。
GSM无线电测试解决方案
HP 8922是一套完整的测试GSM无线台射频部分的测量仪器。除了频率易变的0.3 GMSK射频发生器外,RF分析仪还有灵活的本地振荡器、相干数据解调器、脉冲解调器、调频解调器、用于分析相位和频率误差的综合方法分析仪、合成频谱分析仪和脉冲功率计。HP 8922增加了一个用于完成GSM接收机测量、信道CODEC和呼叫控制协议的误码率测试仪(BERT),以便在进行测量的同时建立电话呼叫并保持链路。通过用于移动台功能测试的声频CODEC简化了回波模式,并且利用电气人机接口(EMMI)来控制移动台和支持数字音频接口(DAI)。HP 8922中的快速存储器易于升级。
GSM数据和HSCSD测试解决方案
HP 8922支持测试GSM单时隙数据和高速电路交换数(HSCSD)移动台的能力。用在R&D、生产和维修方面,选择K09、K17和K18能够测试单时隙、2×1、2×2、96Kb/s和14.4Kb/s移动数据装置。
完整的成套工具
除了完整配套的GSM测量之外,HP 8922还包括对于模块测试、排除故障以及调谐作业等有效的通用工具。这些工具包括一台数字示波器、CW RF合成器、频谱分析仪、CW RF频率计数器、CW和峰值RF功率计、交流电压表、直流电压表、1kHz失真/SINAD(信号对噪声和失真比)测试仪、音频频率计和合成声源。这些功能的组合使HP 8922对于GSM无线设备的选造和修理都是极为有效的工具。
HP 8922H性能指标
射频发生器
频率范围:10MHz~1000MHz
频率分辨率:1Hz
切换速度:557μS
0.3GMSK调制:外总时钟和数据
脉冲调制:标称和30dB
输出功率:-16~-127dBm
射频分析仪
频率范围:10MHz~1000MHz
频率分辨率:1Hz(跳跃模式中为100kHz)
转换速度:557μS
相关数据解调:0.3GMSK在270.833kb/s上,时隙/帧
模拟解调:调频和脉冲
综合方法:rms和峰值相位误差,频率误差
幅度包络:上升、下降和有用比特上的突发平整度损坏
发射机峰值功率:+10dBm~+45dBm,(-5dBm~41dBm,HP 8922F/H)
输出射频频谱测量:取决于调制和切换的瞬变过程
连续波频率计数计:10MHz~1000MHz
频谱分析仪
频率范围:10MHz~1000MHz
频率精确度和稳定度:与时基相同
显示范围:80dB 其它特性;外触发、标记
数字示波器
频率范围:2Hz~50kHz
扫描时间:10μS~100ms,以1、2、5、10步进
音频分析仪
频率范围:20Hz~400kHz
交流电压范围:0~30Vrms
直流电压范围:100mV~42V
THD+噪声:1kHz±5Hz SINAD:1kHz±5Hz
音频信号源
频率范围:DC~25kHz
输出电平范围:0.1mV tms~4Vrms
基准振荡器
外部参考输入频率:13、10、5、2或1MHz
外部参加输出:10和13MHz
远端编程
GPIB:IEEE-488.2
RS-232:300、1200、2400、4800、9600和19200波特
内部编程
编程语言:HP仪器BASIC
程序储存:32KB~512KB外部存储卡
一般规格
尺寸:426mm(宽)×574mm(长)×177mm(高)
重量:32kg
工用温度:0℃~+55℃
贮存温度:-40℃~+75℃
电源:220、240、Vac,48~440Hz,线电压的±10%
GSM 功能
广播信道功功能:BCCH+CCCH或BCCH+CCCH+SDCCH/4
控制信道:BCCH+CCCH、BCCH+CCCH+SDCCH/4 SDCCH/8(无跳跃)、SACCH/FACCH
话务信道:TCH(FS/EFS)
呼叫控制能力:BS始发呼叫(FS/EFS)),MS始发呼叫(FS/ EFS))、MS camp on、BS呼叫拆除,MS呼叫拆除
定时:自动、手动、正向-反向链路偏移测量
跳频:只是周期性、2个MA表格(带偏置)
数字音频接口:常态操作、声学器件和A/D&D/A测试
电气人机接口:通过GPIB控制
语音编码/解码:全速率语音(FS)
回波模式:HP 8922M:用户可选择延迟,0~5秒
比特/桢差错率测量:Ia、Ib和II类比特、已增加新的快速
BER测量 移动台功率输出电平控制:0~19、30、31,由RF分析仪自 动调整
测量调整:灵活控制突发、ARFCN和时隙
<IMG id=paperPicArea1 src="http://ctc.qzs.qq.com/ac/b.gif" .="DISPLAY: none; POSITION: relative; TOP: auto">
