您的位置:控制工程论坛网论坛 » 产品供求 » HP 8656B HP 8657A HP 8657B HP8657B经济型射频信号源
xnt002
xnt002   |   当前状态:在线
总积分:468  2025年可用积分:0
最后登录时间: 2014-09-12
xnt002  发表于 2012/2/10 13:43:49      609 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1780114589
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt008@126.com<SPAN .="mso-spacerun: yes">
<P align=left .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">张先生:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana; mso-font-kerning: 0pt; mso-bidi-font-family: 宋体">13652350058
★频率范围:从100kHz直到2060MHz
★HP8657A上设有电子衰减器
★±1.0dB的电平精度(对于HP8657A,典型精度为±0.5dB)
★HP8657A/B上设有50W的反向功率防护
★调幅、调频和可选用的脉冲调制
HP8656B合成信号发生器
HP8656B是性能稳定、质量高和价格低廉的可编程合成信号发生器,覆盖0.1~990MHz的频率范围.
精确的输出控制
HP8656B具有±0.1dB的绝对电平精度和0.1dB的分辨率,功率电平在+13~-127dBm范围经校准.输出电平可以调节,以补偿发生器之外的损耗.射频泄漏经良好屏蔽,其值<0.1μV,25W的反向功率保护用来防止偶然损坏.
多种调制方式
HP8656B能同时进行AM和FM调制.仪器提供了1kHz和400Hz的内部信号源,同时也能接受外部源调制.AM为交流耦合,而FM既可以是交流耦合,也可以是直流耦合.直流耦合格外稳定(1小时内的漂移<10Hz)和精确(中心频率的精度为±500Hz).
HP8657A/B合成信号发生器
HP8657A和8657B以易于接受的价格提供了卓越的性能.HP8657A覆盖100kHz~1040MHz的频率范围,而HP8657B则覆盖100kHz~2060MHz的频率范围.
高性能的频谱纯度和输出功率
这类信号源的低剩余调频(在1040MHz频率上<4Hz)和优良的相位噪声性能,使它特别适用于要求测试信号处于在邻近通道偏移或带外偏移上的几乎所有测量.诸如载波相位调节这样的特点,使你能利用对于另一个信号源有1°的精密相位偏移来精确表征相敏装置,如相位检波器或相位干涉仪.
显示消隐和非易失存储器的消除还可用于保密环境下的工作. 这些信号发生器提供+13~-143.5dBm的宽动态输出范围,并具有± 1.0dB的空前高精度.HP8657A中的固态电子衰减器十分可靠,并提供5年故障保修期.HP8657A/B的辐射发射非常小,适于对接收机进行灵敏度测量或设计极其灵敏的电路.提供了反向功率保护,正常保护范围直至50W.
高性能的多种调制方式
HP8657A和8657B能由内部和外部调制源两者组合成AM/AM、FM/FM和AM/FM几种调制方式.AM为交流耦合,而FM既可以为交流耦合,也可以为直流耦合.已获专利的直流偶合技术提供了卓越的长期稳定性(1小时的漂移<10Hz)和中心频率精度(最坏情况下为±500Hz).当启动直流FM时,单边带(SSB)相位噪声和剩余FM性能不象其它发生器那样会出现性能下降.
脉冲调制可以利用HP8657B选件003提供.这个选件提供了快速上升时间和良好的隔离.上升时间为35~50ns(典型值为10~18ns),通/断比为70~95dB.对仅只覆盖到1040MHz的脉冲调制,应订购HP8657B选件H60.
便于操作,有利于提高工作效率
多达100个完整的前面板设定可以储存到信号发生器的存储器中,供测试期间调用.这些设定可按动一个面板或利用后面板的SEQ端口按顺序访问.SEQ端口可以连接到脚踏开关或其它由操作者控制的装置上.
HP8656A/B, 8657A/B技术指标一缆表
技术指标 HP8656B HP8657A HP8657B
频率
范围 100kHz~990MHz 100kHz~1040MHz 100kHz~2060MHz
分辨率 10Hz 10Hz 1Hz
时基老化 ±2ppm/年(典型值) ±2ppm/年(典型值) ±2ppm/年(典型值)
选件001 10天之后,1.5×10-8/日(典型值) 10天之后,1.5×10-8/日(典型值) 45天之后,1×10-8/日(典型值)
转换速度(W/i,100Hz) <35ms(25℃时的典型值25ms) <35ms(25℃时的典型值30ms) <35ms(25℃时的典型值30ms)
频谱纯度
单边带(SSB)相位噪声(fc=500MHz,20kHz偏移) <-114dBc/Hz <-130dBc/Hz <-130dBc/Hz
非谐波含量(>5kHz偏移,CW) <-60dBc <-60dBc <-60dBc,<1030MHz
<-54dBc,≥1030MHz
谐波(在≤+7dBm的电平上) <-30dBc <-30dBc <-30dBc,<1030MHz
<-25dBc,≥1030MHz
分谐波 无 无 无,100kHz~1030MHz
<-35dBc,1030~2060MHz
剩余调频
(0.3~3kHz,fc=500MHz,CW) <7Hz(有效值) <4Hz(有效值) <2Hz(有效值)(<6Hz>1040mHz)
输出电平
范围 +13~-127dBm(50Ω) +12~-143.5dBm(50Ω)
+10dBm,100kHz~1MHz +13~-143.5dBm(50Ω)
+10dBm,<1030MHz,带选件003
分辨率 0.1dB 0.1dB 0.1dB
绝对精度 <±1dB≥123MHz,+7~-124dBm
<±1.5dB,<123.5MHz
<-124dBm或>+7dBm <±1dB,≥127MHz,
<±1.5dB,>+7dBm <±1dB≥-127dBm
<±1.5dB≥+3.5dBm
反向功率保护 25W 50W 50W
幅度调制
深度(输出≤+7dBm) 0~99% 0~99%,fc≥400kHz 0~100%,fc≥400kHz
分辨率 1% 1% 1%
带宽(1dB) 20Hz~40kHz 20Hz~40kHz 20Hz~40kHz
精度(内部速率)
(<90%AM,<+7dBm) <±(2%+设定值的4%) <±(2%+设定值的6%) <±(2%+设定值的6%)
失真(内部速率)
(0~30%AM,<+7dBm) <1.5%总谐波失真+噪声 <1.5%总谐波失真+噪声 <1.5%,<1030MHz
<4%,>1030MHz
频率调制
最大峰值频偏 99kHz,fc<123.5和>247MHz
50kHz,fc:123.5~247MHz 99kHz,fc<130和>260MHz
50kHz,fc:130~260MHz 50kHz~200kHz,fc<1040MHz
400kHz,fc:1040~2060MHz
分辨率 100Hz,频偏<10kHz
1kHz,频偏≥10kHz 100Hz,频偏<10kHz
1kHz,频偏≥10kHz 100Hz,<1040MHz,频偏<20kHz
200Hz,>1040MHz,频偏<20kHz
带宽(1dB) dc/20Hz~50kHz dc/20Hz~50kHz dc/20Hz~50kHz
指示器精度 <设定值的±5% <设定值的±5% <设定值的±5%
失真(内部速率,频偏≥3kHz) 0.5%总谐波失真+噪声 0.5%总谐波失真+噪声 <0.5%总谐波失真+噪声
(fc≥1040MHz时,频偏≥6kHz)
脉冲调制 不用 不用 选件003
通/断比 >70dB(>95dB,fc≥1030MHz)
上升/下降时间,10%~90% <35ns(<50ns,fc≥1030MHz)
重复频率 dc~30MHz(典型值)
占空比 0%~100%
远程编程
接口 HP-IB(HP公司对IEEE-488的实施)
IEEE-488功能 SH0、AH1、T0、L2、SR0、RL1、PP0、DC1、DT0、C0、E1
一般指标
储存/调用/顺序寄存器 100个非易失性寄存器用来储存前面板设定值
工作温度 0℃~55℃
电源要求 220V或240V(+5,-10%),48~440Hz
HP8656B:125VA,最大值;HP8657A:175VA,最大值;HP8657B:220VA,最大值
尺寸 HP8656B/57A:133mm(高)×425mm(宽)×520mm(长)
HP8657B:133mm(高)×425mm(宽)×574mm(长)
重量 HP8656B:18.1kg;HP8657A:18.2kg;HP8657B:20.5kg
1低速率调制时,频偏减小,未对fc-(fpk)<100kHz的情况作规定
订货信息
选件
001高稳定度时基
002只用在后面板上的射频连接器
003脉冲调制 H60脉冲调制,频率可达1040MHz
