销售/回收LCR电桥Chroma 11022/CHROMA 11025 ,张先生:13652350058
<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1780114589
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt008@126.com<SPAN .="mso-spacerun: yes">
直流电阻 (DCR) 互感 (M) 圈数比 (Turns Ratio) 等变压器测量参数之量测功能(11025)
测试频率:50Hz,60Hz,100Hz,120Hz,1kHz,10 kHz,20kHz,40kHz,50kHz,100kHz
基本量测准确度:0.1%
高速量测:21ms (测试频率?100Hz)
可与HP 4263B LCR表IEEE-488控制介面相容
4 种输出阻抗模式选择,量测结果可比对各知名厂牌之LCR表
具重叠比较器
0.01mΩ高解析度及0.3%高准确度达到100mΩ的测试范围,提供大容量、低电感等低阻抗零件之的精准量测
可调整直流重叠电流至最大200mA(固定输出阻抗25Ω),适用于各式通讯变压器及小功率电感器之直流重叠电流电感检测(11025)
大型LCD显示(240x64点矩阵),容易操作
0.01mΩ~ 99.99MΩ及4 1/2位数的解析度
具分类计数功能
具比较良品/不良品警示声响判定功能
50组内部仪器设定可供储存及呼叫
可设定HANDLER介面触发端(正缘/负缘)
测试位准监视器功能
标准的GPIB (IEEE-488),HANDLER介面
开路归零、短路归零、载入校正功能
11022/11025 LCR表是被动元件量测仪器,适用于被动元件自动化制造工厂或电子工厂进料检验.11022 LCR表21ms的高速量测及0.1%的准确度,符合高速生产的要求;8级分类计数功能、不良品判定及50组内部仪器设定储存及呼叫功能,完全符合生产线操作简易的要求;四种阻抗输出模式选择,量测结果比对各家LCR表,取得一致性的量测标准;低阻抗之快速精准量测能力更是大容量、低电感等低阻抗零件自动化生产设备之最佳选择;11025并可调整直流重叠电流,适用于各式通讯变压器及小功率电感器之直流重叠电流电感检测.
11025 LCR表另具有直流电阻(DCR)、互感(M)、圈数比(Turns Ratio)等变压器测量参数之量测功能,适用于变压器综合测试之自动化设备.
