您的位置:控制工程论坛网论坛 » 产品供求 » 3259变压器综合测试仪(中文机), 张先生:13652350058
xnt002
xnt002   |   当前状态:在线
总积分:468  2025年可用积分:0
最后登录时间: 2014-09-12
xnt002  发表于 2012/2/10 14:43:03      468 查看 0 回复  [上一主题]  [下一主题]
<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1780114589
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt008@126.com<SPAN .="mso-spacerun: yes">
3259(中文版)变压器综合测试仪
主要特点:
Meter: 3259(中文版)变压器综合测试仪,主要用于变压器生产线或品管做进出货检验,也可用于实验室作产品分析研究的测试,是一款高稳定、高可靠性的精密测试仪器。技术上采用当前最新型的嵌入式微处理器,集成度高,数据处理能力强,测试速度快,测量结果更加准确、稳定。
主要特征:
■ 测试频率20Hz~300KHz/1MHz,精确度0.01%
■ 基本量测准确度:0.1%
■ 三大测试系统(输出阻抗模式)任意可选,测试结果与知名LCR表完全比对
■ 增强式圈数比准确量测,适用于低磁导率的磁芯
■ 高速LCR量测,最快100次/秒
■ 高速DCR量测,最快75次/秒
■ 直流偏置控制功能,0.1mA~1000.0mA
■ 320×240点矩阵大型LCD显示器,5~7位读数分辨率
■ 独特的测试技术,低频漏感、直流电阻测试稳定可靠
■ 漏感平衡、系统杂散电容扣除、不良品锁定功能
■ 独立分组测试功能
■ 出厂校验数据的备份及自动恢复功能
■ 50组内部仪器设定可供储存及呼叫
■ 引导式中文菜单,操作使用方便快捷
■ RS-422串口通讯管理功能,强大的PC机管理软件可直接监视控制若干台网内在线测试的3259仪器
■ Rs-232标准通讯接口,与计算器连接
技术参数:
型号
3259
测试参数
变压器扫描测试
圈数比(Turn Ratio),相位(Phase),圈数(Turn),电感(L),漏电感(Q),漏电感(LK),平衡(Balance),交流电阻(ACR), 电容(Cp),直流电阻(DCR),接脚短路(Pin Short)
测试信号
测试电压
Turn
10mV-10V,±10%, 10mV/step
其他
10mV-2V,±10%, 10mV/step
测试频率
Turn
1KHz~300KHz, ±0.01%
其他
20KHz~3000KHz, ±0.01%
输出阻抗
Turn
10Ω,当测试位准≤2V 50Ω,当测试位准>2V
其他
Constant=OFF;依电阻范围不同而定
Constant=320X:100Ω ±0.5%
Constant=106X:50Ω 100mA ±0.5%(1V设定)
电感负载小于己于10Ω,10Ω±10%,阻抗≥10Ω
测量显示范围
L.LK/C/Q.D/
L,LK:0.00001uH-9999.9H C:0.00001pF999.999mf Q.D:0.00001-99999
Z.X.R/Y/θ
Z.X.P:0.00001Ω-99.9999MΩ Y:0.01Ns-99.9999S ⊙:-90.00-+90.00
DCR/Turn
DCR:0.01mΩ-99.999MΩ Turn:0.01-99999.99圈(次电压小于100Vrms)
Pin-Short
10组,接地与接脚之间
基本准确度
L.LK.C.Z.X.Y.R.DCR
0.1%(若为AC参数1KHZ)
Q.D/θ/Turn
Q.D:0.0005(1KHz) ⊙:0.03°(1KHz) Turn:0.5%(1KHz)
测量速度(最快速度)
L.LK.C.Z.X.Y.R.Q.D.θ
100meas./sec
DCR
75meas./sec
Turn
30meas./sec
判定方式
显示器
320X240点矩阵LCD液晶显示器5~7位读数分辨率,开路(open)、短路(short)归零,负载修正
记忆体
50组测量数据内部保存
等效电路模式
串联. 并联
触发
内部 手动 外部
一般规格
环境条件
温度:10℃~40℃ 湿度:10%~90%RH
消耗功率
最大140VA
电源需求
190-250V AC或190-250V AC 或 48Hz-62Hz
重量
约8.5Kg
尺寸(长×宽×高)
420x300x175
