hu597709756 | 当前状态:在线
总积分:5837 2025年可用积分:0
最后登录时间: 2012-04-16
供应HP83640A 信号源 10MHz to 40GHz HP83640A谭艳飞13543805887/胡S
hu597709756 发表于 2012/3/15 15:38:25 607 查看 0 回复 [上一主题] [下一主题]
中山市华仪通电子仪器有限公司
联系人:谭艳飞(经理)/胡S
手机: 13543805887/13415387172
电话: 15362151491/0760-22782886
传真:0760-22782889
客服QQ:954605954/ 837477829
地址:广东省中山市东凤镇逸湖半岛
描述
The Agilent 83640A synthesized sweeper is the standard of excellence for applications requiring the high performance and accuracy of a synthesized source and the speed and versatility of a sweep oscillator. Synthesized broadband frequency coverage and precise 1 Hz frequency resolution (Opt 008) are generated by indirect synthesis, enabling the Agilent 83640A to achieve low single-sideband phase noise performance. It delivers excellent harmonic performance with harmonics at least 50 dB below the carrier from 2.0 to 26.5 GHz, and at least 40 dB below the carrier above 26.5 GHz.
? Scan modulation to simulate antenna scan patterns
? Accurate fixed and swept frequency offset for two-tone measurement
? User flatness correction for leveling at remote points in the test system
? General purpose source for use in component test, receiver test and for frequency conversion
? Frequency range: 10 MHz to 40 GHz
? Sweep modes: Step, List, Ramp
? Maximum power: < 26.5 GHz: +10 dBm
? Maximum power: > 26.5 GHz: +6.0 dBm
? Power sweep range: -20 dBm to maximum power
? Phase noise (38 GHz at 10 KHz): -70 dBc
? Max FM deviation (locked): +/- 8 MHz
