您的位置:控制工程论坛网论坛 » 产品供求 » 销售/回收频率计HP-53181A/HP-53131A/HP-53132A,肖小姐:13728736358
xnt888
xnt888   |   当前状态:在线
总积分:1162  2025年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/23 15:53:22      551 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">
高精度频率测量到225MHz (通过选件可达1.5,3,5,12.4GHZ) HP53131A和53132A高精度的时间间隔测量具有菜单结构的直观的用户界面标准的GPIB,具有每秒200个全格式化测量数据传送速率:RS-232(只讲) 极限测试能力 HP 53131A/132A/181A高性能计数器提供十分优越的价格和性能,结构牢固,重量轻、使用方便,具有完整的测量装置,广泛的分析功能,良好的可靠性,高的测量速率和数据传送速率. 强大的分析能力 HP 53131A/132A/181A计数器都具有内置的统计和数学功能,所以,你可以给测量定标,同时测量和跟踪平均值、最大和最小值和标准偏差.自动的极限测试使您能够设置任何一种测量的上限和下限. 当测量结果因超出此范围而失败时,计数器就记录了超出范围的状态,提醒操作者并产生一输出信号来触发外部设备或停止测试,模拟显示方式一步即完成极限测试,它让您一目了然地观察通过/失败的极限中的测量结果是否失败了. HP 53181A射频计数器最适合射频场合应用的单通道HP 53181A能以高达每秒10位数字的频率分辨率进行频率、周期和峰值电压测量.HP 53181A是最低价位的计数器,对工作台和系统的射频和模拟应用是理想的仪器. 数字消稳功能使你想要快速读取测量数据时,能够方便地消除不需要的数位.对于较高频率的测量,选用的第二个通道提供1.5, HP 53131A和HP 53132通用计数器 双通道HP 53131A计数器在高达225MHz频率上提供每秒10位的频率分辨率.单次时间间隔分辨率指标规定为500ps,通过平均可进一步降低.测量包括频率、周期、时间间隔、比值、相位角、总和、峰值电压、脉冲参数等等.为了更快访问频繁使用的测试,可单键调用多达20个不同的已存面板设置.选择53131A用于一般的工作台或系统测试,这种场合下你需要一台价格合适的高性能计数器. 对于要求较高分辨率的应用场合,HP 53132A提供与53131A相同的性能,但频率分辨率可高达12位,单次时间间隔分辨率指标规定为150ps.当您需要最佳的精度和分辨率时,或是在自动系统中速度要求苛刻时,可选择53132A. 简明的测量指标和特性 53131A频率计测量 频率,频率比,时间间隔,周期,上升/下降时间,正/负脉冲宽度,占空比,相位(CH1对CH2),总和,峰值电压,时间间隔平均,时间间隔延迟 频率、频率比(带可选的CH2),周期,峰值电压 分析 自动极限测试,数学运算(定标和偏置),统计(最小,最大,平均值,标准偏差)统计可对所有测量结果或对仅在极限范围内的测量结果进行. 测量特性 频率范围 CH1和2:dc-225 MHz CH1和2:dc-225 MHz CH1:dc-225 MHz 频率分辨率 10位/秒 12位/秒 10位/秒 时间间隔分辨率(LSD) 500ps 150ps N/A 测量速度 可达200次测量/秒在GPIB上 可达200次测量/秒在GPIB上 可达200次测量/秒在GPIB上 电压范围和灵敏度(正弦) DC- 100 MHz: 20mVrms-± 5Vac+dc 20mVrms-± 5Vac+dc 20mVrms-± 5Vac+dc 100 MHz-b200 MHz: 30mVrms-±5Vac+dc 30mVrms-±5Vac+dc 30mVrms-±5Vac+dc 200 MHz-225 MHz: 40mVrms-±5Vac+dc 40mVrms-±5Vac+dc 40mVrms-±5Vac+dc 输入调节 (CH1和CH2独立选择) (CH1和CH2独立选择) (CH1选择) 阻抗,耦合 1MΩ或50Ω,ac或dc 1MΩ或50Ω,ac或dc 1MΩ或50Ω,ac或dc 低通滤波器 100 kHz,可切换 100 kHz,可切换 100 kHz,可切换 衰减 ×1或×10 ×1或×10 ×1或×10 外部时基参考输入 1,5,10MHz 10MHz 1,5,10MHz 触发 CH1和CH2 CH1和CH2 CH1 对上升/下降沿触发,用信号电平的百分数或绝对电压设置电平,设置灵敏度至低,中或高 闸门和启动 自动,手动(设置闸门时间或分辨率位数);外部,延迟 接口 标准GP-IB(IEEE488.1和488.2),带SCPI兼容语言;只讲RS-232
现金收购二手频谱分析仪,网络分析仪, 无线电综合测试仪,电子负载, 示波器,音频分析仪, 信号发生器,美国NI GPIB卡, 安捷伦GPIB卡等!
