您的位置:控制工程论坛网论坛 » 产品供求 » 销售/回收/维修AGILENT 34970A数据采集仪, 34901A/34902A数据采集卡
xnt888
xnt888   |   当前状态:在线
总积分:1162  2024年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/23 16:14:52      501 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">
Agilent/HP 34970A数据采集与控制器 品牌型号: Agilent/HP 34970A 库存状态:现货12台 类别: 数据采集与控制器 -> 数据采集控制器 相关技术文档: 34970A 用户使用手册 34970A 仪器用户手册 HP 34970A仪器说明书 详细资料: 重 量:3.6kg 厂家:美国惠普 含HP-34401A全部功能,可配置成20至120个通道,6位半分辨率,0.004%基本直流精度,250通道/秒扫描速率,50000个读数存贮,可测量交直流电流,电阻,频率和调期,以及由热电、热电阻和热敏电阻提供的温度直流和交流电压,标准HP-IB和RS232接口. 3槽的数据采集和开关主机 61/2(22比特)内置DMM 11种内部测量功能 8种开关和控制插入模块 包含Agilent 数据记录器软件 Agilent 34970A是一种高性能、低价位的数据采集和开关主机,十分适于数据记录、数据采集和一般的开关与控制应用.它是一种半机架宽的主机,内部有61/2位(22比特)的数字电压表,其背面有3个插槽,可以接受开关与控制的模块某块组合.无论你只需要少数几个简单的数据记录通道,还是上百个ATE性能的通道,Agilent34970A都能以合理的价格满足你的数据采集要求.可以依赖的测量 Agilent 34970A包括了我们销路最好的台式数字多用表(DMM)的功能特性,你将从已经证明了的Agilent性能、信号调节的通用输入、全部的低价位、紧凑的数据采集结构等方面获益.34970A具有61/2位的分辨率(22比特)、0.004%的基本直流电压精度和极低的读数噪声,加上高达250通道/s扫描速率,你可以得到为完成工作任务所需要的速度和精度.强有力的适应能力Agilent 34970A的独特设计允许逐通道进行配置,以求达到最大的灵活性及快速方便设置内部的自动量程转换.DMM有11种不同的直接测量功能,而不需要昂贵的外部信号调整.内部的温度转换程序可以C、F或(Kelvin)显示未处理过的热偶、RTD或热敏电阻的输入.利用定度可将线性传感器的输出直接转换到工程单位.你甚至可以设置高/低超出容限的情况.而改变配置 3个模块槽和8个开关与控制模块可配置Agilent 34970A来满足你的独特需要.你可以只买你当时需要的部分,以后随着你的应用发展,再添加更多的模块.用一个半机架单元便可测量多达120路输入.免费的Agilent 软件简化数据采集如果要求基于PC的数据记录能力,但又不想花费时间编程,Agilent 便可解决这个问题.利用这个软件可设置你的测试、采集与存档管理测量数据以及对所得到的数据进行实时显示和分析. 熟悉的电子表环境可方便地配置与控制测试,丰富的彩色图形为显示你的数据提供许多选项??全部都是方便的点击,可利用条图、直方图、X-Y散点图和警告灯等建立多种图形.此外,利用 Data Logger可以方便地将数据送到其它应用中以便进一步分析,或者将其包含到你的显示和报告中.应用 数据记录 当配置了Agilent 34901A 20路继电器多路复用器时,34970A便成为紧凑的、低价位的数据记录器,十分适于实验室或现场的快速测试.有自引导菜单的直观面板和明亮的、便于阅读的真空显示使独立的设置既快又方便.所有读数都自动加有时间标记并存入-50,000读数的存储器??足以保存一周内的有价值数据(每5分钟扫描20个通道).非易失性存储器可在断电后仍保存数据,这样便可利用34970A数据,以后再上载到PC机.系统配置也保存在非易失性存储器中,因此掉电又重新接通电源后可自动恢复扫描.此外,基本PC的测试时 Data Logger软件可简化测试配置、数据分析和数据管理.自动测试 对于自动测试和台式自动应用来说,Agilent 34970A的3个插槽和8个插入式开关与控制模块选择允许实现方便的配置.61/2位的内部DMM为你提供了世界应用DMM的性能与功能但占用空间和价格却只是其几分之一.提供支持和National Instruments Lab VIEW的软件驱动程序,从而可容易地将34970A集成到你的系统中,标准的RS-232和GPIB接口以及SCPI编程语言使得这种集成更加方便.三年保证期也是标准的,正如我们专有的继电器维护系统那样,自动地计算并贮存每次单独的开关闭合,以协助你预计继电器的寿命,避免出现生产线停机.开关 对于不要求34970A内部测量的测试应用,可以订购没有内部DMM的单元.这就提供了一个超低价位的解决方案,用来为测试信号进出被测通路和对各种仪器如外部的DMM、示波器、计数器、电源等进行分配.此外,如果你的需要有所变化,以后还可添加DMM.模块简介 最多可有3个任意组合的模块插入一个主机中,34970A的内部DMM连接只能通过34901、34902A和34908A多路转换器进行访问.34970A的精度指标已经包括了转接偏移和参考结点误差,如下表所示,这些误差单独列出,以便确定有外部测量装置的系统误差.34901A 20路多路复用器是用于一般目的扫描的用途最多的模块,它将具有60路/s扫描速率的密集的多功能转接结合起来,适于各种数据采集应用. 34902A 16路高速多路复用器是利用舌簧继电器实现了高达250路/s的扫描速率.这个模块理想地适用于高效自动测试应用以及高速数据记录与监测任务. 34908A 40路单端接多路复用器适用于最高密度的公共、例如电池测试、元件我测试和台式测试. 34903A 20路通用开关模块适用于为被测产品接通与断开电源、控制指示器和状态灯、激励外部要求大驱动信号的继电器以及建立常规的开关配置等. 34904A是一种双线的4*8全交叉矩阵,为被测件和测试设备之间提供最灵活的连接路径,允许不同仪器同时接到被测件上的多个点. 34905A和34906A射频多路复用器为直至2GHz的高频和脉冲信号提供宽带转接能力,利用它们可在被测件发生器、示波器、频谱分析仪、视频放大器或接收机之间构成测试信号通路. 34907A多功能模块为各种传感与控制应用提供了极大的灵活性,它将两个8位数字输入和输出口、100kHz两个±12V模拟输出??所有这些都集中在一个模块内. 一般性能电源:100V/120V/220V/240V 电源频率:45Hz~66Hz,自动检测 电源消耗:12W(25VA峰值) 工作环境: 全精度:在0℃~55℃ 全精度:在相对温度80%(在40℃下) 贮存温度:-40℃~70℃ 仪器保证: 我们的大多数设备在装运之前均经过严格的质量检测与校验.也可申请国家计量证书. 相关仪器: 数据采集/控制器(#3488A) 数据采集/控制器(#3497A) 数据采集/控制器(#34970A)
现金收购二手频谱分析仪,网络分析仪, 无线电综合测试仪,电子负载, 示波器,音频分析仪, 信号发生器,美国NI GPIB卡, 安捷伦GPIB卡等!
