您的位置:控制工程论坛网论坛 » 产品供求 » 销售/回收音频分析仪VA-2230A/VP-7721A/VP-7722A/VP-7723A
xnt888
xnt888   |   当前状态:在线
总积分:1162  2025年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/23 16:16:11      530 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">
产品中文名称: 音频分析仪 VP-7723A 振荡部:5Hz~110kHz, 14.0~-85.9dB,0.1dB分辨能力 ?分析功能:直流电压0.316mV~100V/交流电压 0.316mV~100V/失真范围0.01000~100%/S/NO~ 130dB/频带5Hz~110KHz/失调范围(附设)3K,3.15KHz ?备有通过/不通过测试判断功能和100点存储功能 ?宽426×深400×高133mm ?重量约12kg VA-2230音频分析仪是多功能,高精度,高速度,可遥控音频分析仪 此仪器综合了低频信号发生器,电子电压表,失真表,频率计,直流电压表的功能于一身.中央微处理器控制意味著可靠性更高,操作更简便,将众多的功能汇集在一个小型,高速,高精度的单元中,其价格比起分立单元更具有竞争性. .使用DSP技术,通过FFT计算获得真RMS值 .使用DDS技术的高速,高稳定度信号发生器 .宽大的LCD提供了清晰精确的显示 .配备GPIB接口 .为通讯应用提供了SINAD测量 .双通道输入/输出可进行通道互扰,分离及L/R率测量 .频率计及AC电平频率范围扩展至210KHz .具THD的失真表及谐波分析功能 .操作简便,测试功能丰富 信号发生器 频率范围 5Hz~20.09KHz(使用DDS),,20.1KHz~110.0KHz(使用CR震荡器) 精度 ± 0.005%(5Hz~20.09KHz) 输出通道 2通道变换 阻抗 600Ω(不平衡) 电平范围 14.0~-85.9dBV,16.2~-83.7dBm 分辨率 0.1dB 电平精度 ±0.5dB(≥-40dBV),±0.8dB(<-40dBV),1KHz,600Ω负载 失真(THD+N) ≤0.005%(20Hz~20KHz,80KBW),≤0.01%(满刻度以上) Spot 震荡器1 20Hz(0.001%THD+N,80KBW) Spot 震荡器2 1KHz(0.001%THD+N,80KBW) Spot 震荡器3 20Hz(0.001%THD,80KBW) AC电平测量 测量范围 12档(100V/30V/10V/3V/1V/300mV/100mv/30mV/10mV/3mV/1mV/0.3mV) 精度 满刻度±2%(1KHz) 相对测量范围 0~±130dB 瓦特显示 在AC电平测量及实际负载(RL)基础上进行能量计算 失真测量规格 基本频率范围 10Hz~110KHz 测量范围 9档(100%/30%/10%/3%/1%/0.3%/0.1%/0.03%/0.01%) 输入范围 10档(100V/30V/10V/3V/1V/300mV/100mV/30mV/10mV/3mV) 共同规格 输入通道 AC 2通道变换(在平衡与不平衡间转换) 输入阻抗 AC 10KΩ,100KΩ±2%,≤200pF 最大输入电压 150V(DC+AC峰值) 接地 在浮动及非浮动间转换 平均倍数 2,4,8,16,关闭 滤波器(标准) HPF(100Hz/200Hz/OPT(可选),LPF(15KHz/20KHz/80KHz/OPT(可选),PSOPHO(IHF-A/CCIR-ARM/DIN-AUDIO/OPT(可选) 可选滤波器 带通1KHz/3KHz/315KHz,CCITT P53 TEL,C-MESSAGE,IEC-C 电源电压 AC 100/120/220/240V ±10%(最大250V) 电源消耗 约48W 尺寸/重量 426x99x400mm/约10kg
现金收购二手频谱分析仪,网络分析仪, 无线电综合测试仪,电子负载, 示波器,音频分析仪, 信号发生器,美国NI GPIB卡, 安捷伦GPIB卡等!
