您的位置:控制工程论坛网论坛 » 产品供求 » 现金回收综合测试仪HP8920A HP8921A HP8920B HP8753C,肖小姐:13728736358
xnt888
xnt888   |   当前状态:在线
总积分:1162  2025年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/23 16:53:23      588 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">
基站测试仪HP8921A HP 8921A基站测试装置 HP 8921A基站测试装置十分轻便,是AMPS及TACS蜂窝区安装及维护的综合解决办法。并可升级为测试CDPD、CDMA和TDMA系统。HP 8921A把不少于20种功能的仪器装入一个紧凑的、38磅的装置中。HP 8921A中的主I-BASIC控制器运行HP 11807B基站测试软件,从而使基站的测试和调整步骤完全自动化。自动装置加上精确的测量提高了技术人员的效率,从而加速了安装和维护的过程。 HP 8921A特性概要 AM/FM 信号发生器 AM/FM 调制分析仪双工补偿发生器 RF功率计 RF频率计/频率误差计音频频率计和功率计 AC/DC 电压表 SINAD/SNR/失真仪两个可变频率AF发生器数字示波器内装IBASIC控制器带跟踪发生器的频谱分析仪邻近信道功率计信令编/解码器高稳定度时基 DC电流表 GPIB/RS-232/并行远程接口可升级到TDMA、CDMA、CDPD或PCS测试功能可选蜂窝基站测试软件可选蜂窝电话测试软件可选无线接口卡可选Ericsson PCM基准 升级至新制式 HP 8921A除测试模拟的AMPS和TACS基站外,还为您进行数字蜂窝系统所需的测量作好升级的准备,包括: TDMA CDMA CDPD 高性能频谱分析仪 HP 8921A频谱分析仪具有很宽的动态范围和很高的合成频率精度,这些特点在以前只有昂贵的独立频谱分析仪才能作到。宽动态范围使HP 8921A在强功率发射机环境中可以定位低电平信号。合成频率的高精度表示您定位的校正信号有很高的置信度。频率间距范围可从宽为1GHz至狭为5kHz,HP 8921A可方便地显示整个RF频谱,也可对指定信号进行缩放。标记功能可显示任何信号的频率和幅度。标志移至峰值功能将显示屏幕上最大信号的频率和幅度,只需简单地击键即可完成。 内置跟踪发生器 HP 8921A频谱分析仪还包括一个内置跟踪发生器,用来调谐基站双工器。跟踪发生器的+13dBm功率输出作为双工器的模拟输入。频谱分析仪的校准电平确保双工器准确调节。利用频谱分析仪的标志功能,在滤波器响应的任何一点都可测量双工器的抑制度。天线回波损耗可以由HP 8921A跟踪发生器很快地准确测量。利用跟踪发生器,通过一个外接SWR电桥驱动天线,HP 8921A能测量反射功率。用跟踪发生器可实现其它测量有滤波器、电缆或衰耗器的插入损耗和频率响应。跟踪发生器的校正输出电平从-137到+7dBm还具备IF至RF变换测量用可变频率偏置。频谱分析仪刻度范围为每格1、2和10dB,且具备归一化及标记功能,因此,跟踪发生器使HP 8921A能适合于所有类型的测量和调整。 自动基站维护对复杂的基站维护,通过HP 8921A内部控制器运行的HP 11807B基站测试软件,指导用户进行每步操作。显示连接图及需要时予以加亮显示的关键调整点。技术人员能很快学会操作,节省更多时间用于测试。另一种软件包为HP 11807B选项120,它提供AMPS系统信息,软件使用HP 8921A搜索并解码本地控制信道,显示系统数据,测量主要的发射机参数。 HP8921A 选件600、602、603 CDMA/CDPD基站测试系统 HP 8921A的选件600把HP 83205A CDMA蜂窝适配器添加在基站测试装置后,可以对CDMA(IS-95A 和 IS-97A)的基站设备进行测试。此系统可产生QPSK/OQPSK 的信号并进行分析。该系统测量每个Walsh编码信号的功率、编码信道定时和相对于导频的编码信道相位。 HP 83205A CDPD测试选件迅速而准确地测试前向能道发射机和后向通道接收机上的主要射频参数。CDPD软件(包括所有CDPD硬件)使发射机、接收机和系统的测试自动化,易于标准化的系统维护,且使测试过程又快又准。 HP 8921A选件600性能概要除具备 HP 8921A所有的标准性能外,并增加了:波形质量ρ、频率误差、时间偏移和载波馈漏的测量码域功率、定时和相位分析平均功率及CDMA信道功率测量带有数据缓存及IS-95反向链路编码的CDMA QPSK/OQPSK射频信号源内置校准Eb/No设置的AWGN(附加高斯白噪声) HP 83205A CDMA/CDPD蜂窝适配器对于那些已经拥有HP 8921A的用户,可以将HP 83205A选件003 CDMA/CDPD蜂窝适配器附加到8921A,使它升级为能完成上述8921A CDMA/CDPD测试的装置。注:为具备完整的CDMA测试功能,较老的HP 8921A需要升级。 HP 83204A TDMA/CDPD蜂窝适配器对于那些已拥有HP 8921A的用户,可以将HP 83204A选件003 TDMA/CDPD蜂窝适配器附加到HP 8921A,使它升级为能完成基站设备上的TDMA(IS-136)和CDPD测试的装置。一旦增加后,上述所有TDMA测试功能都可以用手动操作以及HP 11807B软件控制获得。 HP 83202A基站连接配件包选件 032 Ericsson RBS 884连接配件包选件 040 Motorola 连接配件包选件 043 AT&T 连接配件包选件 044 GE 和Nortel 连接配件包 HP 83236B PCS接口 HP 83236B PCS接口将HP 8921A CDMA和TDMA测量功能扩展到国际和美国PCS频段HP 83236B通过HP-IB从外部控制器或从HP 8921A内部IBASIC控制器进行控制。HP 83236B硬件可以同现场中已有的HP 8921A系统组合使用。 基站自动维护的HP 11807B软件按照制造商建议的维护步骤开发的HP 11807B蜂窝区测试软件可确保蜂窝区全面的测试和调整。用HP 8921A和HP 11807B软件进行标准化系统维护,增加了系统集成性,加快了测试速度,缩短了维护工作中收发两用机的脱机时间。所有蜂窝区都采用相同步骤进行一致性测试,因此易于发现问题。 惠普可对下列制造商的产品提供自动测试: *Motorola HDⅡ,HDⅡ/NAMPS、LD系列、TACS、ETACS、 UTACS、EUTACS和MicroCITEAMPS/NAMPS *GE标准、扩展频率和小型RCU系列 *Ericsson882和882M模拟,Microcell、882D DTRM和883、883M TACS/ETACS和884 *Lucent Autoplex系列Ⅱ模拟、LMT Microcell和TDMA/CDMA *Nortel DRU和P系列 *Hughes GMH 2000 AMPS 除了自动维护程序外,HP 1187选件120提供AMPS蜂窝网络的详细分析。自动应用场合是使用HP8921A接受机和解码器,显示大量AMPS系统数据的软件包。系统可以寻找本地AMPS控制信道和显示已解码前向控制信道数据。其它模式解码后向控制信道数据,跟踪呼叫,并完成基地和移动台的测量。 订货信息 AMPS/TACS和CDMA蜂窝区测试 HP 8921A 蜂窝区测试装置选件 011 CCITT加权滤波器选件 020 射频接口适配器选件 042 Ericsson PCM 选件 500 TDMA蜂窝区测试系统选件 502 CDPD MABS蜂窝区测试系统选件 503 TDMA/CDPD MDBS蜂窝区测试系统选件 600 CDMA蜂窝区测试系统选件 602 CDPD MDBS蜂窝区测试系统选件 603 CDMA/CDPD MDBS蜂窝区测试系统 HP 83204A TDMA蜂窝适配器 HP 83205A CDMA蜂窝适配器 HP 83205A PCS接口
现金收购二手频谱分析仪,网络分析仪, 无线电综合测试仪,电子负载, 示波器,音频分析仪, 信号发生器,美国NI GPIB卡, 安捷伦GPIB卡等!
