您的位置:控制工程论坛网论坛 » 产品供求 » 现金收购/销售/CMD55手机综合测试仪,肖小姐:13728736358
xnt888
xnt888   |   当前状态:在线
总积分:1162  2025年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/23 17:19:16      510 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">
CMD55产品特点: 是测量GSM及GSM1800移动电话的紧缩式单元通过RS232,IEC/IEEE远控前面板有多功能连接器话音编码器/解码器可被集成可选择安培表和伏特表高敏感度二级RF输入可改进为GSM、GSM1800及GSM1900测试 Characteristics The CMD52 is a compact unit for testing GSM900 mobiles. The CMD55 is furthermore capable of testing GSM1800 (formerly named PCN orDCS1800) and GSM1900 (formerly named PCS or DCS1900) mobile phones. Both models are favourably priced and combine small dimensions with high measurement accuracy and speed. The testers range of capabilities includes all signalling, generator and measurement functions required for verifying the correct operation of the DUT (Device Under Test). Thanks to its fast go/nogo tests and accurate analysis using optional extensions, CMD52 and CMD55 are equally well suited for R&D, production and high-end service and production. Based on the wide-range know-how of Rohde & Schwarz in digital radiocommunication testing, which not least was obtained in developing type-approval test systems such as the GSM900 and GSM1800 system simulators, both CMD models are top-grade testers for present and future measurement applications. Test capabilities To test mobile phones, the CMD simulates a GSM900, 1800 or 1900 base station. One of the two RF synthesizers available for this purpose delivers a continuous BCCH signal while the other one provides all 8 timeslots for TCH signals. The major test functions are: Mobile synchronization Location update Incoming call setup Outgoing call setup Mobile power level control Handover (channel change, timeslot change) Peak power measurement High dynamic range burst analyzer (option CMD-B4 and CMD-B42) Spectrum due to Switching measurement (option CMD-B4 and CMD?B43) Spectrum due to Modulation measurement (option CMD-B4 and CMD?B43 Timing Advance measurement SACCH measurement (eg RxLev, RxQual, power level) Echo test Call clearing by mobile phone Call clearing by CMD DC current/voltage measurements Phase and frequency error measurement (option CMD-B4) Measurement of power ramping as a function of time (option CMD-B4) Bit-error rate (BER) and Fast BER measurement (option CMD-B4) Operation Operation of the CMDis extremely user-friendly and requires no detailed GSM/PCN knowledge. The high-contrast, backlit LCD provided with softkeys on both sides allows convenient callup of test routines under menu control. Various network-specific parameters are preset and permit direct testing without any operator control. In addition, it is of course possible to modify all parameters individually in the configuration menus. Autotest The autotest function enables complete measurement routines to be started at a keystroke without any further intervention by the operator being required. The test results in tabular form are displayed on the screen. Remote control The CMD is remote-controlled via the RS-232 or IEEE/IEC-bus interface using SCPI-compatible commands. In the remote-control mode the CMD is designed for fast speed to yield high throughputs in production. Echo test The echo test allows very rapid go/nogo analysis covering all essential parts of the mobile. Words spoken into the microphone of the mobile are sent to the CMD, stored in buffer memory and sent back to the phone. In this way it is possible to check the whole signal path from the microphone via the RF transmitter section, RF receiver section, modulator, demodulator, signalling section, speech coder/decoder, analog audio components through to the loudspeaker. Testing handhelds In addition to the normal RF input/output, the CMD has a high-sensitivity input and a high-level output which enable tests on modules or on handhelds with built-in antenna by using couplers like the CMD-Z10. Module testing Fault localization in mobile telephones requires various measurement functions that can also be used without signalling so that defective units can be tested down to modular level. The basic model of CMD already provides some of these functions, eg signal generation with or without modulation or power measurements, other functions being available as optional extensions.
现金收购二手频谱分析仪,网络分析仪, 无线电综合测试仪,电子负载, 示波器,音频分析仪, 信号发生器,美国NI GPIB卡, 安捷伦GPIB卡等!
