您的位置:控制工程论坛网论坛 » 产品供求 » 高价回收/销售频谱分析仪R3131 R3131A R-3131 R-3131A,肖小姐:13728736358
xnt888
xnt888   |   当前状态:在线
总积分:1162  2025年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/26 10:25:20      508 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">
产品概要 作为低成本和性能中档的标准频谱分析仪,R3131A可以被应用于广泛的领域. R3131A带有框架插槽式设计,操作键布局简单明了,可以简便地设计成为通用或专用系统. 特点 ■ 内置有数字无线电测试所要求的高精度OBW、ACP、Power测量功能? 采用合成方式的本机振荡,频率稳定性高? 采用直接数字合成方式,提高SPAN精度? 具有校正功能,提高电平精度 ■ AUTO TUNE功能,改善操作性能 ■ Auto CAL功能,保证总电平的精度 ■ 标准接口:GP-IB、RS232C、FD软盘驱动器 ■ Counter、Power测量时,采用大文字显示其结果 ■ 丰富的EMC测量功能 ■ 系统高速化:GP-IB转送速度、TRACE往返速度 ■ 充分重视操作/使用方便的操作键 ■ 整体设计小型、轻量,主机只有12kg ■ 高性能,低成本 ■ TG 3GHz(选件) 频率 频率范围 9kHz~3GHz 频率读取精度 ±(读取频率×频率基准精度+SPAN×SPAN精度+0.15×分辨率带宽+1kHz) 光标频率计数器精度 ±(光标频率×光标基准精度+1LSD) (S/N≥25dB,SPAN≤200MHz) 光标频率计数器分辨率 1Hz~1kHz 频率基准源精度 ±2ppm/year±5ppm/使用温度范围内 频率SPAN zero,50kHz~3GHz 频率SPAN精度 ≤±3% 频率稳定度 残留FM ≤100Hzp-p/100ms(zero span) 边带噪声 ≤-100dBc/Hz(20kHz offset) 分辨率带宽(30dB) 1kHz~1MHz 1-3step 带宽精度 ≤±20% 选择度(60dB:3dB) ≤15:1 6dB频带宽 9kHz ,120kHz 视频频带宽 10Hz~1MHz 1~10step 振幅 振幅测量范围 ±20dBm~平均显示噪音电平 最大输入电平 ±20dBm,50VDC 显示屏显示范围 对数 10dB/div 8div 1,2,5dB/div 10div 线性 基准电平的10%/div 基准电平显示范围 对数 -64dBm ~+40dBm 线性 +141.1Μv ~+22.36V 输入衰减范围 0~50dB 10dBstep 扫描 扫描时间 50ms ~500s 扫描时间精度 ≤3% 触发模式 FREE RUN,VIDEO,EXT,LINE 扫描模式 REPEAT,SINGLE 动态范围 平均噪声电平 -113dBm+2f(GHz)dB (RBW 1kHz,VBW 10Hz,INPUT ATT 0Db,频率1MHz以上) 1dB增益压缩 >-5dBm (混频输入电平,f≥20MHz) 2次高频失真 ≤-70dB (输入频率≥10MH,混频输入电平-30dBm) 2信号3次失真 ≤-70dB (输入频率≥109MHz,混频输入电平-30dBm,2信号的频率差>50kHz) 振幅精度 校准信号 30MHz,-20dBm±0.3dB 频率响应 ≤±0.5dB(100kHz~3GHz,ATT=10dB) ≤±1dB(100kHz~2GHz) ≤±2dB(9kHz~3GHz) (30Mhz基准,校正后) 刻度显示精度 对数 ≤±0.5dB(0~-20dB)(自动校正后) ≤±1.5dB/70dB(自动校正后) ≤±1.0dB/10dB(自动校正后) ≤±0.2dB/1dB(自动校正后) 线性 基准电平的±5%以内 输入ATT切换精度 ≤±0.3Db(以10dB为标准,30MHz) 分辨率带宽切换精度 ≤±0.5dB(自动校正后) IF增益偏差 ≤±0.5dB(自动校正后) 综合电平精度 ±1.5dB (REF=-50~0dBm,ATT=10Db,2dB/div,RBW=300kHz,f>100kHz自动校正后) 一般指标 使用温度范围 0℃~+50℃湿度85%以下(无霜时) 保存温度范围 -20℃~+60℃ AC电源输入 AC100V,200V自动转换 100VAC时 100V~120V,50Hz/60Hz 220VAC时 220V~240V,50Hz/60Hz 耗电 200VAC以下(AC100V) 重量 约12kg 尺寸 424mm(W)×177mm(H)×300mm(D)
现金收购二手频谱分析仪,网络分析仪, 无线电综合测试仪,电子负载, 示波器,音频分析仪, 信号发生器,美国NI GPIB卡, 安捷伦GPIB卡等!
