您的位置:控制工程论坛网论坛 » 产品供求 » 销售/回收AGILENT8970B HP8970B HP 8970B噪声系数测试仪,肖小姐:13728736358
xnt888
xnt888   |   当前状态:在线
总积分:1162  2025年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/26 10:31:11      545 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">
HP8970B噪声系数测试仪: 10~1600 MHz(利用选件020时达2047MHz) 精确,简单,扫频或连接波测量 二级修正 同时显示噪声系数和增益 可在示波器、记录仪或绘图仪上显示校准后的数据 增强了功能强大的特殊功能 对下变频器测试的本振控制 HP 8970B噪声系数测试仪 使用HP 8970B噪声系数仪,可使噪声系数测量变得容易、精确且重复性好.自动二级修正即使对低增益器件也能得到精确的噪声系数读数.在不用外加放大或衰减的情况下,HP 8970B的动态围允许进行至少40dB(在某些情况下,还会更高)的增益测量,或达-20dB的损耗测量.HP 8970B可存储4个超噪比ENR(Excess Noise Radio)噪声源校准表.还可在每个测量频率上适当内插ENR值. 微处理器和控制器功能 HP 8970B使得噪声系数测量不再神秘化.为达到真正精确、方便和灵活的噪声系数测量,使用一个微处理器来进行计算和必要修正.此仪器还可控制外接本机振荡器(如HP 8370系列合成器,HP 8340或8360系列合成扫频源或HP 8350扫频振荡器)和HP 8971C噪声系数测试装置.这就使得微波频段的放大器、混频器、晶体管的精确、宽带测量如同射频测量一样简单. 所有HP 8970B的前面板各键和功能均可通过GPIB总线即I E E E -4 8 8总线来操作.本仪器还有一个独立的系统接口总线(SIB)来控制8971C及本机振荡器.当用于自动化测试装置中时,这个附加的总线使你不必编写计算机代码去控制SIB上的仪器(如本机振荡器).这种信号通过能力可使其他仪器控制器通过本仪器向SIB总线上的任何其他仪器发送信息. 前面板和特殊功能 HP8970B的前面板各键可控制数字输入、校准和测量.STORE,RECALL和SEQ键允许存储多达9个前面设置及自动或手动顺序执行,以便节省建立时间.平滑INCREASE和DECREASE键是用来在显示之前进行多达512个读数的平均,这就会提高精度和消除显示闪烁. 对于那些需要比HP 8970B简单面板所能提供的测量能力更强的操作人员来说,只要键入一数码和按特殊功能键就能选择超过200种以上的特殊功能.冷?热测量和自动补偿被测器件输入端的损耗就是两个实倒.特殊功能之一是一个一览表,它能迅速向你显示现行运用的特殊功能.三张可抽出的插卡可作为仪器使用的小型参考手册.它包括大部分特殊功能、GPIB总线格式和代码、错误信息、典型测量设置等. HP 8970B部分技术指标 (完整技术指标请参见技术资料p/n5091-6049E) 噪声系数(增益)测量范围:0~30dB(-20~至少40dB) 噪声系数(增益)仪表的不确定度:在0~55℃(±0.15dB)±0.1dB 噪声系数分辨率: 0.01dB (经GPIB控制时为0.001dB) 增益分辨率: 0.01dB (经GPIB控制时为0.001dB) 频率范围:可从10MHz调到1600MHz(用选件020时可调到2047MHz) 调谐精度(从10°到40℃):±(1MHz+频率的1%),最大±6MHz 频率分辨率:1MHz 噪声系数(对低于-60dBm的输入功率电平):<7dB+0.003dB/MHz (用选件020时为+0.002dB/MHz)输入驻波比SWR,50Ω参考阻抗; <1.7,10MHz~1600MHz (用选件020时,SWR<1. <2.0,1600MHz~2047MHz(只用选件020) 最大工作输入功率:-10dBm 最大外部净增益:>65dB(在噪声源与8970B RF输入之间) 噪声源驱动电压:28.0±0.1V 工作温度: 0°~55℃ 储藏温度: -55°~75℃ 电源:220或240V(+5%,-10%);48~66Hz,150VA(最大值) 尺寸:425mm(宽)×143mm(高)×476mm(长) 重量: 净重,15.5kg.
 现金收购二手频谱分析仪,网络分析仪, 无线电综合测试仪,电子负载, 示波器,音频分析仪, 信号发生器,美国NI GPIB卡, 安捷伦GPIB卡等!
