北京普源精电RIGOL数字示波器 DS1102E DS1052E,肖小姐:13728736358
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes"> 设备型号 DS1052E 带宽 50MHZ DS1102E 带宽 1 00 MHz 存储深度 1 Mpts(单通道),512 kpts(双通道) 通道 双通道+外触发 实时采样率 400 MSa/s,200 MSa/s(逻辑分析仪) 时基范围 20 ns/div ~ 50 s/div 10 ns/div ~ 50 s/div 5 ns/div ~ 50 s/div 2 ns/div ~ 50 s/div 门限类型(逻辑分析仪) TTL = 1.4 V, CMOS = 2.5 V, ECL = - 1.3 V, USER = - 8.0 V 至 + 8.0 V 李沙育图形 带宽 50MHZ 100 MHz 相位差 ± 3° 触发模式 边沿、视频、脉宽、斜率、交替 触发源 CH1,CH2,Ext,Ext/5,AC Line 相同参数 输入阻抗 1 MΩ|| 15 pF 时基精度 50ppm 垂直灵敏度 2 mV/div ~ 5 V/div 垂直分辨率 8 bits 输入耦合 直流、交流、接地 最大输入电压 All Input 1MΩ||15pF 400V Max CATII 滚动范围 500 ms/div ~ 50 s/div 自动测量 峰峰值、幅值、最大值、最小值、顶端值、底端值、平均值、均方根值、过冲、预冲、频率、周期、上升时间、下降时间、正脉宽、负脉宽、正占空比、负占空比、延迟1→2 、延迟1→2 的测量 光标测量 手动模式、追踪模式和自动测量模式 数学运算 +,-,×,FFT 内部存储 10组波形、10组设置 U盘存储 位图存储、CSV存储、波形设置 接口 USB Device,USB Host,RS-232,P/F Out (Isolated) 显示 64 k色TFT彩色液晶,320 x 234分辨率 电源 AC 100 ? 240 V , 50 VA 最大值 重量 2.3 kg DS1102E 全新设计的小巧体积,大大减小桌面占用面积 5.7’64K色TFT彩色液晶屏,波形显示更加清晰自然 存储深度:1M采样点(单通道),512K采样点(双通道),512K采样点(逻辑分析仪) 丰富的触发功能:边沿、视频、脉宽、斜率、交替、码型和持续时间触发等 可调触发灵敏度:有效滤除有可能叠加在触发信号上的噪声,防止误触发 实时采样率400 MSa/s,等效采样率高达25 GSa/s;保证有效捕获实时瞬态信号,同时可观察重复信号的 微妙细节 20种自动测量功能 光标测量包括手动模式、追踪模式和自动测量模式 10组波形、10组设置存储、位图存储、CSV存储 加、减、乘、FFT、反相等多种波形运算功能 自动校准功能 独特的数字滤波器和波形录制功能 内置硬件频率计 双通道 + 外触发,根据带宽分为100 MHz,60 MHz,40 MHz,25 MHz 多种型号 标准配置接口:USB Device,RS-232;USB Host,支持U盘和USB接口打印机 标配 通过/失败 检测功能:采用“光电隔离”方式,有效避免电磁干扰 多种语言用户界面,嵌入式帮助系统
