您的位置:控制工程论坛网论坛 » 产品供求 » 销售/回收/维修信号发生器SG-1501B/SG-5150/SG-8150S,肖小姐:13728736358
xnt888
xnt888   |   当前状态:在线
总积分:1162  2025年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/26 10:57:48      541 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">
SG-5150 FM-STEREO/FM-AM SIGNAL GENERATOR 频率 范围 100KHz?150MHz(75?110MHZ,FM立体声) 分辨率 100Hz 精确度 ±5PPm 输出 范围 ?133dBm~?13dBm ,?20~100dBu 分辨率 0.1dB, 1dB 精确度 ±1dB在100dBu 衰减器 ±1dB,20~100dBu,±2dB,?20~20dBu 阻抗 50欧,VSWR<1.2 谐波 <?30dB 残留调制 FM部分:≥70dB AM部分:≥50dB ---------------------------------------- ---------------------------------------- SG-1501B FM-STEREO/FM-AM SIGNAL GENERATOR 频率 范围 100KHz?150MHz(60?110MHZ,FM立体声) 分辨率 100Hz 精确度 ±5PPm 输出 范围 ?133dBm~+13dBm ,?20~126dBu 分辨率 0.1dB, 1dB 精确度 ±1dB在126dBu 衰减器 ±1dB,20~126dBu,±2dB,?20~20dBu 阻抗 50欧,VSWR<1.2 谐波 <?30dB 残留调制 FM部分:≥70dB AM部分:≥50dB 调制 内调制 频率 400Hz或1KHz±2% 外调制 输入阻抗: 10K欧 输入电平 3Vp-p±2% FM 范围 0~100KHz在1到150MHz 精确度 ±10%的最大频偏 失真 <0.06%在10.7MHz,76~110MHz <0.1%在其它范围 AM 范围 0~60% 分辨率 0.1% 精确度 ±0.5%(100KHz~110MHz) ±10%(100KHz~150MHz) 失真 <0.5%在200KHz~30MHz <1.5%在其它范围 立体声 分离度 >50dB 400Hz~1KHz >35dB 100Hz~10KHz >30dB 50Hz~15KHz 导频 频率 19KHz±2Hz 范围 0~15% 失真 1% 精确度 ±10%在10.7MHz,76~110MHz 记存 预设键 AM: 30%, FM: 3.5KHz, 22.5KHz, 75KHz FM STEREO:30%,100% 记忆 100组 其它 电源 AC115V,230V±10% 尺寸 115(H)×430(W)×310(D)mm 附件 电源线,BNC线,保险丝,操作说明书 选件 GPIB,遥控,TCXO1ppm
现金收购二手频谱分析仪,网络分析仪, 无线电综合测试仪,电子负载, 示波器,音频分析仪, 信号发生器,美国NI GPIB卡, 安捷伦GPIB卡等!
