您的位置:控制工程论坛网论坛 » 产品供求 » 美国福禄克万用表FLUKE179 F179,肖小姐:13728736358
xnt888
xnt888   |   当前状态:在线
总积分:1162  2025年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/26 11:07:15      511 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">                            坚固耐用的Fluke 170系列万用表,完全适应工业现场应用的数字万用表. 恶劣的环境和高压很容易损伤万用表,但对Fluke 170系列数字万用表来说却是微不足道的事.这两种万用表内外设计坚固,一体化的保护套和符合人体工程学的流线型外壳,使现场应用更加舒适、方便且具有以下特性: 过压保护装置可抗高达6千伏冲击电压,并有IEC61010-1过压安全等级认证. 输入保护确保万用表在欧姆档时,仪器不会由于误接入高压而损坏. 福禄克专利的接触保持TouchHold模式,可以锁定读数,使阅读更加方便. 79Ⅲ型具有真有效值测量功能,即使有谐波也可得到正确结果. 179随机附带温度探头. 所有型号享受终身保修服务. 产品参数 技术指标交流电流 量程 0.01mA-10.00A(20A过载30秒) 精度 ±1.5%+3 峰值因子 ≤3 AC响应 45Hz-1kHz 直流电流 量程 0.01A-10.00A(20A过载30秒) 精度 ±1%+3 交流电压 量程 0.1mV-1000V 精度 45-500Hz1%+3 500-1kHz2%+3 AC响应 45Hz-1kHz 直流电压 量程 0.1mV-1000V 精度 ±0.9%+2 电阻 量程 0.1Ω-50.00MΩ 最高分辨率 ±0.9%+1 电容 量程 1nF-9999μF 最高分辨率 ±1.2%+2 连续性 <25Ω报警;在250ms内或更长时间探测开路或者短路 Hz 量程 输入电压:2Hz-100kHz 输入电流:2Hz-30kHz 精度 ±0.1%+1 温度 量程 -40℃~+400℃ -40?~+752? 精度 1%+1.0℃ 1%+1.8? 可选附件仪表悬挂 ToolPak磁体以及索带组件 仪表箱 C510革制仪表箱 C50衬垫仪表箱 C20硬质仪表箱 测试引线 全部的Fluke附件引线 电流夹钳 全部的Fluke电流夹钳附件 温度 80TK热电偶模块 80T-150U通用温度探头 80AK热电偶适配器(仅适用于179) 80T-IR/80PK-IR温度探头 特殊附件 80K-6、80K-40高电压探头 PV350压力模块 POM光纤仪表 特征 175 177 179 6000个计数的显示器 ? ? ? 自动显示保留和手动显示保留 ? ? ? IEC1010等级:CAT IV600V/CAT III 1000V ? ? ? 用于能见度低的环境下测量背景灯 ? ? 测量摄氏温度和华氏温度,包含热电偶 ? 电池盖的设计使得不需要破坏校准封就可以够及电池 ? ? ? 与Fluke ToolPakTM仪表悬挂组件兼容 ? ? ? 现金收购二手频谱分析仪,网络分析仪, 无线电综合测试仪,电子负载, 示波器,音频分析仪, 信号发生器,美国NI GPIB卡, 安捷伦GPIB卡等!
