您的位置:控制工程论坛网论坛 » 产品供求 » 美国福禄克数字万用表FLUKE177 F177,肖小姐:13728736358
xnt888
xnt888   |   当前状态:在线
总积分:1162  2025年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/26 11:56:10      495 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">                            Fluke 45是全5位,100000字高性能双显示多功能测试仪表.两个多功能显示和16个测量能力能广泛地用于生产测试,现场维护、定点修理、科研开发和教学等场合. 真空荧光管双显示屏 真有效值电压,电流,包括交流,直流 标准配置RS-232接口,GPIB/IEEE 488可选频率测量到1MHz 可选择参考阻抗的分贝测量功能,阻抗2W到8000W,音频功率2W/16W 比较功能可进行快速误差分选,有高/低/通过指示 0.05%的直流电流精度的测量用于4-20mA电流环故障诊断 接触保持,相对值和最大/最小值 通断蜂鸣和二极管测试 不开盖校准 Quick start 45软件包可选,用于Fluke 45与PC之间的快速设置和通 讯,可以方便地编制,存贮和调用自定义测试程序. 技术指标 显示:3000字, 30,000字,100,000字 读数速率:快(20次/秒),中(5次/秒),慢(2.5次/秒) 功 能 量 程 最好准确度(中速读数) 分辨率 VDC 0V~1000V ±0.025%+2 1μV~0.01V VAC 真有效值,AC耦合 频率 20Hz~100kHz 0V~750V ±(0.2%+10) 1μV~0.01V dB 600Ω参数 -34~+60 ±0.08 dB 0.01dB~0.1dB 参数Z2Ω~8000Ω ADC 0mA~10A ±0.05%+2 0.1μA~10mA AAC 真有效值, AC耦合 频率 20Hz~20kHz15μA~10A ±0.5%+10 0.1μA~10mA 电阻 0Ω~100MΩ ±0.05%+2 0.001Ω~100kΩ 频率 5Hz->1MHz ±0.05%+1 0.01Hz~1kHz 尺寸:216mm宽×93mm高×286mm深 重量:净重2.4kg,带电池3.2k
