您的位置:控制工程论坛网论坛 » 产品供求 » 盐雾试验机/盐雾试验箱/盐水喷雾试验机XNT-952,肖小姐:13728736358
xnt888
xnt888   |   当前状态:在线
总积分:1162  2025年可用积分:0
最后登录时间: 2016-03-10
xnt888  发表于 2012/3/26 16:18:05      573 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">肖小姐<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13728736358
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1635851451
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt888@126.com<SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">盐雾试验机JT-952
XNT-952C 600*400*450 XNT-952B 900*600*500 XNT-952A 1200*800*500 XNT-952AL 1600*1000*500
产品型号
XNT-60 型
内部尺寸
600×450×400(L×W×H)mm
外部尺寸
1075×630×1185(L×W×H)mm
试验室温度
NSS ACSS 35℃±1℃/ CASS 50℃±1℃
压力桶温度
NSS ACSS 47℃±1℃/ CASS 63℃±1℃
试验室容积
110L
盐水箱容积
15L
压缩空气压力
1.00±0.01kgf/cm2
喷 雾 量
1.0-2.0ml/80cm2.h
试验室相对湿度
85%以上
喷 雾 方 式
连续式喷雾
产品简介:
盐水喷雾试验乃针对各种材质之表面经电镀、阳极处理、喷涂、防锈油防腐蚀处理后,测试其?品之耐蚀性。
特 性:
1:整一PVC板制,内部采用先进环带产立体补强技术、结构强实,永不变形,并耐酸碱、耐高温永不老化,适用於盐雾、醋酸铜等各种测试规格。
2:控制仪均在同一面板操作简便,且一目了然。
3:采用自动/手动加水系统,具有水位不足时能自动补充水位之功能,试验不中断。水位不足警示确保使用安全。
4:精密玻璃喷嘴(PYREX)由特种玻璃制成,雾气扩散均匀并自然落于试片,连续使用4000小时并保证无结晶盐阻塞。
5: 附双重超温保护功能,超温时警示显示,并切断加热器电源,确保使用安全。
6:进口温度控制器使用数字显示,PID控制,误差±0.1℃。
7:试验室采用蒸气直接加温方式,升温速度快且均匀,减少待机时间,加热管采用高耐腐蚀?管制成。
8:喷雾塔附锥形分散器,具导向雾气,调节雾量及均匀落雾量等功能。
9:饱合空气桶采用享利定律,予以加热加湿,并提供试验室所需之湿度。其材质为SUS#304不锈钢保温效果最佳,附有可视连通器及排水开关,以便可视饱和空气桶内水位及清洗。
10:具有自动除雾装置,可清淅观测试验室内之试品。
11:雾气密封水槽,利用水密封方式,防止雾气外泄。
12:试验室密封盖材质为欧洲进口A级亚克力耐冲击板,厚度5mm,操作方便安全可靠。
13:进口计时器采用数字显示,计时准确,可分段设定时H.分M.秒S.任意所需试验时间,可调节时间范围从0.01秒~9999小时.
14:试药补充瓶采用隐藏式附水位透视窗,清洗容易,不宜破裂。
15:试验室篮架采用平面分度架,可任意调整角度,四面落雾及受雾方向完全一致,试验片放置数量多。
型号规格 工作室尺寸 XNT-952C 600*400*450 XNT-952B 900*600*500 XNT-952A 1200*800*500 XNT-952AL 1600*1000*500
