您的位置:控制工程论坛网论坛 » 教程与手册 » linux 守护程序 !!!
dqfxm2003
dqfxm2003   |   当前状态:离线
总积分:3995  2025年可用积分:0
最后登录时间: 2011-01-14
linux 守护程序 !!!
dqfxm2003  发表于 2006/3/1 9:12:59      1516 查看 1 回复  [上一主题]  [下一主题]
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <dirent.h>
#include <errno.h>
#include <fcntl.h>
#include <ctype.h>
#include <string.h>
#include <sys/ioctl.h>
#include <sys/wait.h>
#define PROC_NAME     "mymail"
#define EXEC_NAME     "/root/dev_mobile/source/MyMail/src/mymail"
#define   LOCKFILE "/root/mytest.lock"
#define  DEBUG
int daemon_init()
    struct sigaction act;
    int i, maxfd;
    int lock_fd;
    int ret;
    char buf[100];
    lock_fd=open(LOCKFILE,O_RDWR|O_CREAT,0640);
    if(lock_fd<0){
        printf("lockfile failed :\n");
            exit(-1);
    ret=flock(lock_fd,LOCK_EX|LOCK_NB);//因为下面关闭了,所以起不到作用
    if(ret<0){
        printf("can't obtaion the file lock:\n");
        exit(0);
    if (fork() != 0)
        exit(0);
    if (setsid() < 0)
        return -1;
    act.sa_handler = SIG_IGN;
    sigemptyset(&act.sa_mask);
    act.sa_flags = 0;
    sigaction(SIGHUP, &act, 0);
    if (fork() != 0)
        exit(0);
    chdir("/");
    umask(0);
    setpgrp();
    maxfd = sysconf(_SC_OPEN_MAX);
    for (i = 0; i < maxfd; i++)
        //close(i);
    sprintf(buf,"%6d\n",getpid());
    write(lock_fd,buf,strlen(buf));
    open("/dev/null", O_RDWR);
    dup(0);
    dup(1);
    dup(2);
    return 0;
static int file2str(char *filename, char *ret, int cap)
    int fd, num_read;
    if ((fd = open(filename, O_RDONLY, 0)) == -1)
        return -1;
    if ((num_read = read(fd, ret, cap - 1)) <= 0)
        return -1;
    ret[num_read] = 0;
    close(fd);
    return num_read;
static int parse_proc_status(char*p_name,char *S)
    char *tmp;
    unsigned char p_id[10];
    memset(p_id, 0x00, sizeof(p_id));
    sscanf(S, "Name:\t%15c", p_id);
    tmp = strchr(p_id, '\n');
    if (tmp)
        *tmp = '\0';
    //printf("%s\n",p_id);
    if(strcmp(p_name,p_id)==0)
        return 0;
    else
         return -1;
    return -1;
static int proc_exist(char *p_name)
  DIR *dir;
  FILE *file;
  struct dirent *entry;
  char path[32], sbuf[512];
  int id;
    dir = opendir("/proc");
    if (!dir){
        perror("Can't open /proc");
        exit(-1);
        while ((entry = readdir(dir)) != NULL) {
        if (!isdigit(*entry->d_name))
            continue;
        sprintf(path, "/proc/%s/status", entry->d_name);
        if ((file2str(path, sbuf, sizeof sbuf)) != -1) {
            if(parse_proc_status(p_name,sbuf)==0){
                id=atol(entry->d_name);
                printf("id=%d\n",id);
                closedir(dir);
                return 0;
closedir(dir);
return -1;
static int proc_fork(char*p_path)
 char * argv[ ]={PROC_NAME,(char*)0 };
 pid_t pid;
 pid=fork();
 if(pid==0){
 execv(p_path,argv);
 if(pid>0)
    printf("fork  succeed:\n");
void handler()
  char uidName[30];
  char exec_path[50];
    memset(uidName,0x00,sizeof(uidName));
    memset(exec_path,0x00,sizeof(exec_path));
    strcpy(uidName,PROC_NAME);
    strcpy(exec_path,EXEC_NAME);
    printf("one\n");
    if (proc_exist(uidName)==0)
        printf("进程存在\n");
    else
        proc_fork(exec_path);
    alarm(10);
int main(int argc, char **argv)
#ifdef DEBUG
   if (daemon_init() < 0) {
        printf("daemon failed\n");
        return 1;
#endif
   signal(SIGALRM,handler);
   alarm(15);
   while (1){
   while ( waitpid(-1,NULL,WNOHANG) > 0)
        printf("test:\n");
 网上的unix比较多,前几天做了一个linux下的,监控某一程序,如果不存在,就启动。
