您的位置:控制工程论坛网论坛 » 产品供求 » Agilent 86062C 光开关
dongcekj
dongcekj   |   当前状态:在线
总积分:1033  2025年可用积分:0
最后登录时间: 2020-08-31
Agilent 86062C 光开关
dongcekj  发表于 2012/7/13 11:18:55      1549 查看 1 回复  [上一主题]  [下一主题]
Agilent 86062C 光开关
The Agilent 86062C is a full-width instrument with 20 to
100 output channels. It is designed for automated production and
evaluation testing of large numbers of devices.
The Agilent 86060 Series Lightwave Switches are designed
for 9/125 μm single-mode, as well as 62.5/125 and 50/125 μm multi-mode
operation. Switching is bi-directional. The 1xN switching module is
built around a precision stepper motor.
Features
Improved performance due to temperature stabilization
Visual signal path display with easy-to-use manual interface
Repeatable switching with 10 million cycle minimum life
GPIB and RS-232 control
SCPI-compatible commands
