您的位置:控制工程论坛网论坛 » 现场总线 » 工业现场总线比较
wqshand
wqshand   |   当前状态:在线
总积分:5732  2025年可用积分:0
最后登录时间: 2019-07-01
工业现场总线比较
wqshand  发表于 2007/12/8 17:00:06      1550 查看 1 回复  [上一主题]  [下一主题]
PHYSICAL CHARACTERISTICS
    Network Topology    Physical Media    Max. Devices (nodes)    Max. Distance
PROFIBUS DP/PA    Line, star & ring    Twisted-pair or fiber    127 nodes    24 Km (fiber)
INTERBUS-S    Segmented with "T" drops    Twisted-pair, fiber, and slip-ring    256 nodes    400 m/segment, 12.8 Km total
DeviceNet    Trunkline/dropline with branching    Twisted-pair for signal & power    64 nodes    500m
ARCNET    Bus, multidrop, star    Twisted-pair coax fiber    255 nodes    5 miles
AS-I    Bus, ring, tree star, of al    Two wire cable    31 slaves    100 meters, 300 with repeater
Fieldbus Foundation    Multidrop with bus powered devices    Twisted-pair    240/segment, 65,000 segments    1900m @ 31.25K
500m @ 2.5M
IEC/ISA SP50
Fieldbus    Star or bus    Twisted-pair fiber, and radio    IS 3-7
non IS 128    1700m @ 31.25K
500M @ 5Mbps
Seriplex    Tree, loop, ring, multi-drop, star    4-wire shrolded cable    500+ devices    500+ ft
WorldFIP    Bus    Twisted-pair, fiber    256 nodes    up to 40 Km
LonWorks    Bus, ring, loop, star    Twisted-pair, fiber, power line    32,000/domain    2000m @ 78 kbps
SDS    Trunkline/Dropline    Twisted-pair for signal & power    64 nodes,
126 addresses    500m
Modbus Plus    Multidrop Network segment with bridge capibilitites    RS485, Transformer isolated    32, 64 max. pcr segment with bridge capibilitites    1500 feet (450 meters) repeater CAN extend to 6000 ft (1800m)
Industrial Ethernet    STAR, BUS    LOBASE-T, 10-Base-FL (FIBER) 100 Base TX    48 bit address
TRANSPORT MECHANISM
     Communication Methods    Transmission Properties    Data Transfer Size    Arbitration Method    Error Checking    Diagnostics
PROFIBUS DP/PA    Master/slave
peer to peer    DP up to 12 Mbps
PA 31.25 kbps    244 bytes    Token passing    HD4 CRC    Station, module & channel diagnostics
INTERBUS-S    Master/slave with total frame transfer    500kBits/s,
full duplex    512 bytes h.s.,
unlimited block    None    16-bit CRC    Segment location of CRC error and cable break
DeviceNet    Master/slave, multi-master, others    500 kbps,
250 kbps,
125 kbps    8-byte variable message    Carrier-Sonac Multiple Access    CRC check    Bus monitoring
ARCNET    Peer to peer    31.25K to 10M    508 bytes    Token    16-bit CRC    Built in
AS-I    Master/slave with cyclic polling    Data and power, EMI resistant    31 slaves with 4 in and 4 out    Master/slave with cyclic polling    Manchester Code, hamming-2, partly    Slave fault, device fault
Fieldbus Foundation    Client/server publisher/ subscriber, Event notification    31.25 kbps 1 Mbps 2.5Mbps    16.6 M objects/device    Deterministic centralized scheduler, multiple backup    16-bit CRC    Remote diagnostics, network monitors, parameter status
IEC/ISA SP50
Fieldbus    Client/server Publisher/ subscriber    31.25 kbps IS+1, 2.6, 5 Mbps    64 octets high & 256 low priority    Scheduler, tokens, or master    16-bit CRC    Configurable on network management
Seriplex    Master/slave
peer to peer    200 Mbps    7680/transfer    Sonal multiplexing    End of frame & echo check    Cabling problems
WorldFIP    Peer to peer    31.25 kbps, 1 & 2.5 Mbps, 6 Mbps fiber    No limit, variables 128 bytes    Central arbitration    16-bit CRC, data "freshness" indicator    Device message time-out, redundant cabling
LonWorks    Master/slave
peer to peer    1.25 Mbs full duplex    228 bytes    Carrier Sense, Multiple Access    16-bit CRC    Database of CRC errors and device errors
SDS    Master/slave,
peer to peer,
multi-cast,
multi-master    1Mbps,
500 kbps,
250 kbps,
125 kbps    8-byte variable message    Carrier-Sonac Multiple Access    CRC check    Bus monitoring,
Diagnostic slave
Modbus Plus    Token Passing    1 MBPS    256 bytes data + header    peer to peer, token passing    16-bit CRC    Local Chip and Software
Industrial Ethernet    CSMA/CD    10MBPs, 100 MBPs    1500 Bytes Data.    Collision Detection    32 bit CRC.    CD, Network Management
PERFORMANCE
     Cycle Time: 256 Discrete
16 nodes with 16 I/Os    Cycle Time: 128 Analog
16 nodes with 8 I/Os    Block transfer of 128 bytes
1 node
PROFIBUS DP/PA    Configuration dependent
typ <2ms    Configuration dependent
typ <2ms    not available
INTERBUS-S    1.8 ms    7.4 ms    140 ms
DeviceNet    2.0 ms Master-slave polling    10 ms Master-slave polling    4.2 ms
ARCNET    <2 ms @ 2.5M    <2 ms @ 2.5M    <2 ms @ 2.5M
AS-I    4.7 ms    not possible    not possible
Fieldbus Foundation    100 ms @ 31.25k
<1 ms @ 2.5M    600 ms @ 31.25k
<8 ms @ 2.5M    36 ms @ 31.25k
0.45 ms @ 2.5M
IEC/ISA SP50    Configuration dependent    Configuration dependent    0.2 ms @ 5 Mbps
1.0 ms @ 1 Mbps
Seriplex    1.32 ms @ 200 kbps, m/s    10.4 ms    10.4 ms
WorldFIP    2 ms @ 1 Mbps    5 ms @ 1 Mbps    5 ms @ 1 Mbps
LonWorks    20 ms    5 ms @ 1 Mbps    5 ms @ 1 Mbps
SDS    <1 ms, event driven    <1 ms per event    2 ms @ 1 Mbps
