标准的机组数据显示 (Standard Measurement And Display Data) 负载电流百分比显示 Percentage of Current load(%) 单相/三相电压 Voltage by One/Three Phase (Volt.) 每相电流 Current by Phase (AMP) 千伏安 Apparent Power (KVA) 中线电流 Neutral Current (N Amp) 功率因数 Power Factor (PF) 频率 Frequency(HZ) 千瓦 Active Power (KW) 千阀 Reactive Power (KVAr) 最高/低电压及电流 Max/Min. Current and Voltage 输出千瓦/兆瓦小时 Output kWh/MWh 运行转速 Running RPM 机组运行正常 Normal Running 超速故障停机 Overspeed Shutdowns 低油压故障停机 Low Oil Pressure Shutdowns 高水温故障停机 High Coolant Temperature Shutdowns 起动失败停机 Fail to Start Shutdowns 冷却水温度表 Coolant Temperature Gauge 机油油压表 Oil Pressure Gauge 电瓶电压表 Battery Voltage Meter 机组运行小时表 Genset Running Hour Meter 怠速-快速运行选择键 Idle Run – Normal Run Selector Switch 运行-停机-摇控启动选择键 Local Run-Stop-Remote Starting Selector Switch 其它故障显示及输入 Other Common Fault Alarm Display and 电力行波词汇 行波travelling wave 模糊神经网络fuzzy-neural network 神经网络neural network 模糊控制fuzzy control 研究方向 research direction 副教授associate professor 电力系统the electrical power system 大容量发电机组large capacity generating set 输电距离electricity transmission 超高压输电线supervltage transmission power line 投运commissioning 行波保护Traveling wave protection 自适应控制方法adaptive control process 动作速度speed of action 行波信号travelling wave signal 测量信号measurement signal 暂态分量transient state component 非线性系统nonlinear system 高精度high accuracy 自学习功能selflearning function 抗干扰能力antijamming capability 自适应系统adaptive system 行波继电器travelling wave relay 输电线路故障transmission line malfunction 仿真simulation 算法algorithm 电位electric potential 短路故障short trouble 子系统subsystem 大小相等,方向相反equal and opposite in direction 电压源voltage source 故障点trouble spot 等效于equivalent 暂态行波transient state travelling wave 偏移量side-play mount 电压electric voltage 附加系统add-ons system 波形waveform 工频power frequency 延迟变换delayed transformation 延迟时间delay time 减法运算subtraction 相减运算additive operation 求和器summator 模糊规则fuzzy rule 参数值parameter values 可靠动作action message 等值波阻抗equivalent value wave impedance 附加网络additional network 修改的modified 反传算法backpropagation algorithm 隶属函数membership function 模糊规则fuzzy rule 模糊推理fuzzy reasoning 样本集合 sample set 给定的given 模糊推理矩阵fuzzy reasoning matrix 采样周期sampling period 三角形隶属度函数Triangle-shape grade of membership function 负荷状态load conditions 区内故障troubles inside the sample space 门槛值threshold level 采样频率sampling frequency 全面地all sidedly 样本空间sample space 误动作malfunction 保护特性protection feature 仿真数据simulation data 灵敏性sensitivity 小波变换wavelet transformation 神经元neuron 谐波电流harmonic current 电力系统自动化power system automation 继电保护relaying protection 中国电力 China Power 学报 journal 初探primary exploration (1) 元件设备 三绕组变压器:three-column transformer ThrClnTrans 双绕组变压器:double-column transformer DblClmnTrans 电容器:Capacitor 并联电容器:shunt capacitor 电抗器:Reactor 母线:Busbar 输电线:TransmissionLine 发电厂:power plant 断路器:Breaker 刀闸(隔离开关):Isolator 分接头:tap 电动机:motor (2) 状态参数 有功:active power 无功:reactive power 电流:current 容量:capacity 电压:voltage 档位:tap position 有功损耗:reactive loss 无功损耗:active loss 功率因数:power-factor 功率:power 功角:power-angle 电压等级:voltage grade 空载损耗:no-load loss 铁损:iron loss 铜损:copper loss 空载电流:no-load current 阻抗:impedance 正序阻抗:positive sequence impedance 负序阻抗:negative sequence impedance 零序阻抗:zero sequence impedance 电阻:resistor 电抗:reactance 电导:conductance 电纳:susceptance 无功负载:reactive load 或者QLoad 有功负载: active load PLoad 遥测:YC(telemetering) 遥信:YX 励磁电流(转子电流):magnetizing current 定子:stator 功角:power-angle 上限:upper limit 下限:lower limit 并列的:apposable 高压: high voltage 低压:low voltage 中压:middle voltage 电力系统 power system 发电机 generator 励磁 excitation 励磁器 excitor 电压 voltage 电流 current 母线 bus 变压器 transformer 升压变压器 step-up transformer 高压侧 high side 输电系统 power transmission system 输电线 transmission line 固定串联电容补偿fixed series capacitor compensation 稳定 stability 电压稳定 voltage stability 功角稳定 angle stability 暂态稳定 transient stability 电厂 power plant 能量输送 power transfer 交流 AC 装机容量 installed capacity 电网 power system 落点 drop point 开关站 switch station 双回同杆并架 double-circuit lines on the same tower 变电站 transformer substation 补偿度 degree of compensation 高抗 high voltage shunt reactor 无功补偿 reactive power compensation 故障 fault 调节 regulation 裕度 magin 三相故障 three phase fault 故障切除时间 fault clearing time 极限切除时间 critical clearing time 切机 generator triping 高顶值 high limited value 强行励磁 reinforced excitation 线路补偿器 LDC(line drop compensation) 机端 generator terminal 静态 static (state) 动态 dynamic (state) 单机无穷大系统 one machine - infinity bus system 机端电压控制 AVR 电抗 reactance 电阻 resistance 功角 power angle 有功(功率) active power 无功(功率) reactive power 功率因数 power factor 无功电流 reactive current 下降特性 droop characteristics 斜率 slope 额定 rating 变比 ratio 参考值 reference value 电压互感器 PT 分接头 tap 下降率 droop rate 仿真分析 simulation analysis 传递函数 transfer function 框图 block diagram 受端 receive-side 裕度 margin 同步 synchronization 失去同步 loss of synchronization 阻尼 damping 摇摆 swing 保护断路器 circuit breaker 电阻:resistance 电抗:reactance 阻抗:impedance 电导:conductance 电纳:susceptance 导纳:admittance 电感:inductance 电容: capacitance |
szzunzheng | 当前状态:离线
总积分:180 2025年可用积分:0
最后登录时间: 2009-10-12
szzunzheng 发表于 2007/7/23 12:04:33
引用 szzunzheng 2007/7/23 12:04:33 发表于2楼的内容
qugd 发表于 2007/7/24 13:07:15
3楼 回复本楼不知道是不是楼主自己翻译的,总之专业水平太差了,就连我这个不是学仪器仪表的人,对于楼主的一些中文解释,感觉实在是太外行了。这种水平也拿出来晒。
引用 qugd 2007/7/24 13:07:15 发表于3楼的内容
