您的位置:控制工程论坛网论坛 » 产品供求 » 代理分销美国CUI品牌蜂鸣期、连接器
panruidennis
panruidennis   |   当前状态:在线
总积分:271  2025年可用积分:0
最后登录时间: 2017-12-14
代理分销美国CUI品牌蜂鸣期、连接器
panruidennis  发表于 2017/11/30 16:55:21      1305 查看 0 回复  [上一主题]  [下一主题]
代理分销美国CUI品牌蜂鸣期、连接器  磐瑞国际贸易 www.panrui.cc
我公司为美国现货商,中、小批量国外订货可为广大OEM厂家提供工业级、军品级及偏冷门连接器、传感器 搜寻配套服务。欢迎新老客户来电来函。
CUI
{蜂鸣器}
   ---固态声频指示器
CS-3224 : 22.5 x 16.7 mm solid state audio indicator, 20 - 28 V dc, pc mount, 2 pin
CS-8406 :22.5 x 16.7 mm solid state audio indicator, 4 - 8 V dc, pc mount, 4 pin
CS-8412  :22.5 x 16.7 mm solid state audio indicator, 8 - 16 V dc, pc mount, 4 pin
CS-3212 :22.5 x 16.7 mm solid state audio indicator, 8 - 18 V dc, pc mount, 2 pin
CS-3603 :22.8 x 17.0 mm solid state audio indicator, 2 - 4 V dc, lead wires, mounting tabs
CS-3624 : 22.8 x 17.0 mm solid state audio indicator, 20 - 28 V dc, lead wires, mounting tabs
CS-3606:22.8 x 17.0 mm solid state audio indicator, 4 - 8 V dc, lead wires, mounting tabs
CS-3612:22.8 x 17.0 mm solid state audio indicator, 8 - 16 V dc, lead wires, mounting tabs
   ---磁换能器、声换能器
CX-0905C : 9.6mm magnetic sound transducer, 5V, pc mount, sealed, built-in driving circuit
CEM-1205C :12mm magnetic sound transducer, 5V, pc mount, sealed, built-in driving circuit
CEM-1212C :12mm magnetic sound transducer, 12V, pc mount, sealed, built-in driving circuit
CT-1205C  :12.8mm magnetic sound transducer, 5V, surface mount, built-in driving circuit
CT-1205CL :12.8mm magnetic sound transducer, 5V, surface mount, built-in driving circuit
CT-1212CL:12.8mm magnetic sound transducer , 12V, surface mount, built-in driving circuit
CX-1606C :16mm magnetic audio indicator, 6V, PCB Mount sealed
CX-1612C:16mm magnetic audio indicator, 12V, PCB Mount sealed
CC-0601 : 6.6mm magnetic sound transducer, 1.5V, pc mount, unsealed
CSS-73B16K:8.5mm magnetic sound transducer, 3.6V, surface mount
CSS-I4B20: 8.5mm magnetic sound transducer, 3.6V, surface mount
CSS-J4B20:8.5mm magnetic sound transducer, 3.6V, surface mount
CSS-J4D20:8.5mm magnetic sound transducer, 3.6V, surface mount
CST-911RP/A:9mm magnetic sound transducer w/ side port, 1.5V, PCB mount
CST-931RP/A :9mm magnetic sound transducer w/ side port, 3V, PCB mount
CST-951RP/A : 9mm magnetic sound transducer w/ side port, 5V, PCB mount
CST-911AP :9mm magnetic sound transducer, 1.5V, PCB mount
CST-931AP:9mm magnetic sound transducer, 3V, PCB mount
CST-934AS:9mm magnetic sound transducer, 3V, spring terminals
CST-951AP :9mm magnetic sound transducer, 5V, PCB mount
CEM-1201(42):12mm magnetic sound transducer, 1.5V, pc mount, unsealed
CEM-1201(50):12mm magnetic sound transducer, 1.5V, pc mount, unsealed
CEM-1201S:12mm magnetic sound transducer, 1.5V, pc mount, sealed
CEM-14R06CT:12mm magnetic sound transducer, 1.5V, pc mount, sealed
CSQ-601BP:12mm magnetic sound transducer, 1.5V, PCB Mount
CSQ-706BP:12mm magnetic sound transducer, 1.5V, PCB Mount
CSQ-RP/E :12mm magnetic sound transducer w/ side port, 1.5V, PCB Mount
CSQG703BP:12mm magnetic sound transducer, 3V, pc mount, unsealed - lead free
CEM-1203(42):12mm magnetic sound transducer, 3.5V, pc mount, unsealed
CCV-084B16:12mm magnetic sound transducer, 3.6V, SMT mount
CD-1206:12mm magnetic sound transducer, 5V, smt mount, sealed
CCG-1206:12mm magnetic sound transducer, 5V, pc mount, sealed - lead free
CEM-1206S:12mm magnetic sound transducer, 5V, pc mount, sealed
CEM-1212S:12mm magnetic sound transducer, 12V, pc mount, sealed
CT-1205:12.8mm magnetic sound transducer, 5V, surface mount
CT-1205H:12.8mm magnetic sound transducer , 5V, surface mount
CEM-160116mm magnetic sound transducer, 1.5V, pc mount, sealed
CEM-1606:16mm magnetic sound transducer, 6V, pc mount, sealed
CEM-1612:16mm magnetic sound transducer, 12V, pc mount, sealed
   ---声频指示器
CPE-222H :23.3 mm piezo audio indicator, 8 - 18 V dc, pc mount, 3.2 KHz
CPE-232H:23.3 mm piezo audio indicator, 8 - 18 V dc, pc mount, 3.2 KHz
CPE-200 :23.8 mm piezo audio indicator, 3 - 20 V dc, lead wires, 2.8 KHz, mounting tabs
CPE-223:23.8 mm piezo audio indicator, 3 - 20 V dc, pc mount, 3.3 KHz
CPE-220 :24 mm piezo audio indicator, 3 - 20 V dc, lead wires, 2.7 KHz, mounting tabs
CPE-522:24 mm piezo audio indicator, 3 - 20 V dc, pc mount, 3.2 KHz
CPE-203:24.5 mm piezo audio indicator, 3 - 20 V dc, pc mount, 3.4 KHz
CPE-251:28 mm piezo audio indicator, 4 - 28 V dc, lead wires, 3.5 KHz, mounting tabs, fast pulse
CPE-253: 32 mm piezo audio indicator, 8 - 18 V dc, lead wires, 3.5 KHz, mounting tabs
CPE-260H :32 mm piezo audio indicator, 8 - 18 V dc, lead wires, 3.5 KHz, mounting tabs
CPE-276H :32 mm piezo audio indicator, 8 - 18 V dc, pc mount, 3.0 KHz
CPE-270 :33.7 mm piezo audio indicator, 3 - 28 V dc, lead wires, 3.5 KHz, mounting tabs
CPE-270H :33.7 mm piezo audio indicator, 8 - 18 V dc, lead wires, 3.5 KHz, mounting tabs
CPE-750PA:36.5 mm piezo audio indicator, 0.7 - 15 V dc, panel mount, 3.6 KHz, pins
CPE-750P:36.5 mm piezo audio indicator, 4 - 28 V dc, panel mount, 3.6 KHz, pins
CPE-750:36.5 mm piezo audio indicator, 4 - 28 V dc, panel mount, 3.6 KHz, tabs www.panrui.cc
CPE-755P:36.5 mm piezo audio indicator, 6 - 28 V dc, panel mount, 3.6 KHz, fast pulse + continuous, pins
CPE-755:36.5 mm piezo audio indicator, 6 - 28 V dc, panel mount, 3.6 KHz, fast pulse + continuous, tabs
CPE-751:36.5 mm piezo audio indicator, 6 - 28 V dc, panel mount, 3.6 KHz, fast pulse, tabs
CPE-757:36.5 mm piezo audio indicator, 6 - 28 V dc, panel mount, 3.6 KHz, slow pulse + continuous, tabs
CPE-753:36.5 mm piezo audio indicator, 6 - 28 V dc, panel mount, 3.6 KHz, slow pulse, tabs
CPE-755S36.5 mm piezo audio indicator, 6 - 28 V dc, pnl mt, 3.6 KHz, fast pulse + continuous, screw terminal
CPE-420:41.8 mm piezo audio indicator, 3 - 16 V dc, lead wires, 2.8 KHz, mounting tabs
CPE-350A:41.8 mm piezo audio indicator, 3 - 20 V dc, lead wires, 2.8 KHz, mounting tabs
CPE-353A:41.8 mm piezo audio indicator, 3 - 20 V dc, lead wires, 2.8 KHz, mounting tabs, slow pulse
CPE-350:41.8 mm piezo audio indicator, 3 - 28 V dc, lead wires, 2.8 KHz, mounting tabs
CPE-351:41.8 mm piezo audio indicator, 3 - 28 V dc, lead wires, 2.8 KHz, mounting tabs, fast pulse
CPE-35341.8 mm piezo audio indicator, 3 - 28 V dc, lead wires, 2.8 KHz, mounting tabs, slow pulse
CPE-400AC:41.8 mm piezo audio indicator, 3 - 30 V ac or dc non-polar, lead wires, 3.1 KHz, mounting tabs
CPE-422AC:41.8 mm piezo audio indicator, 60 - 250 V ac or dc non-polar, lead wires, 3.0 KHz, mounting tabs
CPE-460:41.8 mm piezo audio indicator, 9 - 14 V dc, lead wires, 0.3 KHz, mounting tabs, low frequency
CPE-352:42 mm piezo audio indicator, 3 - 28 V dc, pc mount, 2.8 KHz  www.panrui.cc
CPE-960:50 mm piezo audio indicator, 3 - 16 V dc, lead wires, 2.5 KHz, mounting tabs, volume baffle
CEP-2242:13.7mm piezo audio indicator, 3-16V, pc mount, sealed
CMI-1240:16.9mm piezo audio indicator, 12V, surface mount
CEP-2224:24mm piezo audio indicator, 3-20V, pc mount, unsealed
CEP-2202A:24.2mm piezo audio indicator, 3-20V, pc mount, unsealed
CEP-2202AS :24.2mm piezo audio indicator, 3-20V, pc mount, sealed
CEP-2250:28mm piezo audio indicator, 3-28V, flange mount with lead wires
CEP-2272A:31.3mm piezo audio indicator, 3-20V, pc mount, unsealed
CEP-2260A:32mm piezo audio indicator, 30V, flange mount with lead wires
CEP-2280 :32mm piezo audio indicator, 3-18V, flange mount w/lead wires
CEP-4411AC:41.8mm piezo audio indicator, 30-120V, www.panrui.cc
   ---传感器、变频器、转换器
CEB-20D64:20mm piezo buzzer element, w/lead wires
CEB-20FD64 :20mm piezo buzzer element, w/feedback loop & lead wires
CEB-27D44:27mm piezo buzzer element, w/lead wires www.panrui.cc
CEB-27FD44 :27mm piezo buzzer element, w/feedback loop & lead wires
CEB-35D26 :35mm piezo buzzer element, w/lead wires
CEB-35FD29:35mm piezo buzzer element, w/feedback loop & lead wires
CEB-44D06:44mm piezo buzzer element , w/lead wires
   ---防水蜂鸣器
CPE-243:14mm waterproof piezo audio indicator, 12V, wire leads
CPE-244:14mm waterproof piezo audio indicator, 12V, PC mount
CPE-267:26mm waterproof piezo audio indicator, 12V, wire leads
   ---推进、巡回蜂鸣器
{连接器}
==2.5mm Audio Jacks
  *Right-Angle, 2.5mm
MJ-2502 :2.5mm right-angle mono jack, PCB mount
MJ1-2503A :2.5mm right-angle mono jack, PCB mount, non-threaded
MJ-2506:2.5mm right-angle mono jack,www.panrui.cc
MJ-2506N :2.5mm right-angle mono jack, PCB mount, non-threaded
MJ-2508:2.5mm right-angle mono jack, PCB mount
MJ-2508N:2.5mm right-angle mono jack, PCB mount, non-threaded
MJ-2509N:2.5mm right-angle mono jack , PCB mount, non-threaded
SJ1-2503A:2.5mm right-angle stereo jack, PCB mount, non-threaded
SJ-2504N:2.5mm right-angle stereo jack, PCB mount, non-threaded
SJ-2509N:2.5mm right-angle stereo jack, PCB mount, non-threaded
   *Vertical, 2.5mm www.panrui.cc
MJ-2505:2.5mm mono jack, panel mount w/switch
MJ-2507:2.5mm mono jack
MJ-2507N :2.5mm mono jack, non-threaded
   *Mono, 2.5mm
MJ-2502:2.5mm right-angle mono jack, PCB mount
MJ1-2503A:2.5mm right-angle mono jack, PCB mount, non-threaded
MJ-2506:2.5mm right-angle mono jack, PCB mount
MJ-2506N:2.5mm right-angle mono jack, PCB mount, non-threaded
MJ-2507 :2.5mm mono jack panrui.cc
MJ-2507N:2.5mm mono jack, non-threaded
MJ-2508N :2.5mm right-angle mono jack, PCB mount, non-threaded
   *Stereo, 2.5mm
SJ-2504N :2.5mm right-angle stereo jack, PCB mount, non-threaded
   *Threaded, 2.5mm
MJ-2505 :2.5mm mono jack, panel mount w/switch
MJ-2507:2.5mm mono jack panrui.cc
MJ-2508 :2.5mm right-angle mono jack, PCB mount
   *Non-Threaded, 2.5mm
MJ-2507N :2.5mm mono jack, non-threaded panrui.cc
SJ-2509N :2.5mm right-angle stereo jack, PCB mount, non-threaded
2.5mm SMT Audio Jacks
Mono, 2.5mm SMT
MJ1-2510-SMT:2.5mm surface mount mono jack, 3 pin right-angle
MJ-2523-SMT:2.5mm surface mount mono jack, 3 pin right-angle
MJ1-2533-SMT:2.5mm low profile surface mount mono jack, 3 pin right-angle
Stereo, 2.5mm SMTpanrui.cc
SJ-252X-SMT:2.5mm surface mount stereo jack
SJ1-251X-SMT :2.5mm surface mount stereo jack
SJ1-253X-SMT:2.5mm surface mount stereo jack
==3.5mm Audio Jacks
 Right-Angle, 3.5mm
 MJ-3502、MJ-3502N、MJ-3536、MJ-3536N、MJ-3536NG、SJ-3504、SJ-3505、SJ1-351X、SJ1-351XN、SJ1-352XN、SJ1-352XNG、SJ1-353X、SJ1-353XN、SJ1-353XNG、SJ-353XNGS、SJ1-354X、SJ1-354XN、SJ1-355XNG、SJ-356X、SJ-357X、SJ-358X
Vertical, 3.5mm
MJ-3507、MJ-3507N
Mono, 3.5mm  panrui.cc
 MJ-3502、MJ-3502N、MJ-3507、MJ-3507N、MJ-3536、MJ-3536N、MJ-3536NG、
Stereo, 3.5mm
 SJ-3504 SJ-3505 SJ1-351X SJ1-351XN SJ1-352XN SJ1-352XNG SJ1-353X SJ1-353XN SJ1-353XNG SJ1-353XNS SJ-353XNGS SJ1-354X SJ1-354XN SJ1-355XNG SJ-356X SJ-357X SJ-358X
Threaded, 3.5mm
 MJ-3502 MJ-3507 MJ-3536 SJ1-351X SJ1-353X SJ1-354X
Non-Threaded, 3.5mm
 MJ-3502N MJ-3507N MJ-3536N MJ-3536NG SJ-3504 SJ-3505 SJ1-351XN SJ1-352XN SJ1-352XNG SJ1-353XN SJ1-353XNG SJ1-353XNS SJ-353XNGS SJ1-354XN SJ1-355XNG SJ-356X SJ-357X SJ-358X
w/Isolated Switch, 3.5mm
Shielded, 3.5mm
 SJ1-353XNS、 SJ-353XNGS
==3.5mm SMT Audio Jacks
Mono, 3.5mm SMT
MJ1-3510-SMT、MJ-3523-SMT
Stereo, 3.5mm SMT
SJ1-351X-SMT、SJ-352X-SMT
Stereo, 3.5mm panrui.cc
SJ-3504、SJ-3505、SJ1-351X、SJ1-351XN、SJ1-352XN、SJ1-352XNG、SJ1-353XN、SJ1-353X、SJ1-353XNG、SJ1-353XNS、SJ-353XNGS、SJ1-354X、SJ1-354XN、SJ1-355XNG、SJ-356X、SJ-357X、SJ-358X
Threaded, 3.5mm
MJ-3502、MJ-3507、MJ-3536、SJ1-351X、SJ1-353X、SJ1-354X、、、、、、、、、、、、、、、、
Non-Threaded, 3.5mm
MJ-3502N、MJ-3507N、MJ-3536N、MJ-3536NG、SJ-3504、SJ-3505、SJ1-351XN、SJ1-352XN、SJ1-352XNG、SJ1-353XN、SJ1-353XNG、SJ1-353XNS、SJ-353XNGS、SJ1-354XN、SJ1-355XNG、SJ-356X、SJ-357X、SJ-358X、、、、、、
Shielded, 3.5mm
2.5/3.5mm Dual Audio Jacks
SJD-3510-33、SJD-3510-45、SJD-3511-33、SJD-3511-45、SJD-3512-33、SJD-3512-45、SJD1-3201-54
6.4mm Audio Jacks
==Right-Angle, 6.4mm
MJ-632X、SJ-630X、SJ-631X、SJ-632X
==Vertical, 6.4mm
MJ-6333G、MJ-6343、MJ-6353、MJ-6363N、SJ-633X、SJ-634X、SJ-635X、SJ-636X
==Mono, 6.4mm
MJ-632X、MJ-6333G、MJ-6343、MJ-6353、MJ-6363N
==Stereo, 6.4mm
SJ-630X、SJ-631X、SJ-632X、SJ-633X、SJ-634X、SJ-635X、SJ-636X
4, 5, & 6 Conductor Audio Jacks
==4 Conductor, 2.5 mm Audio Jack
SJ1-4251X  panrui.cc
==4 Conductor, 2.5 mm Smt Audio Jack
SJ1-4251X-SMT、SJ-4252X-SMT、SJ-4252X-SMT、SJ1-4253X-SMT
==SJ-4351X : 4 conductor 3.5mm audio jack
==SJ-4351X-SMT : 4 conductor 3.5mm smt audio jack
==SJ-43502PM : 4 conductor 3.5mm panel mount audio jack w/nut
==SJ-63516 : 6 conductor 3.5mm audio jack
6.4mm Audio Jacks
MJ-632X、SJ-630X、SJ-631X、SJ-632X、、、
==Vertical, 6.4mm
MJ-6333G、MJ-6343、MJ-6353、MJ-6363N、SJ-633X、SJ-634X、SJ-634X、SJ-635X、SJ-636X
==Mono, 6.4mm
==Stereo, 6.4mm
 DC Power Jacks >   panrui.cc
== Right-Angle, DC
PJ-031CH、PJ-035CH 、PJ-036CH 、PJ-040CH 、PJ-053CH 、PJ-017CH 、PJ-029CH 、PJ-030CH 、PJ-029C 、PJ-030C 、PJ-031C 、PJ-035C 、PJ-036C 、PJ-040C 、PJ-053C 、PJ-056 、PJ-017C、PJ-052C、PJ-031DH、PJ-035DH、PJ-036DH、PJ-040DH、PJ-053DH、PJ-017DH、PJ-029DH、PJ-030DH、PJ-029D、PJ-030D、PJ-031D、PJ-035D、PJ-036D、PJ-040D、PJ-053D、PJ-017D、PJ-052D、PJ-018H、PJ-041H、PJ-042H、PJ-045H、PJ-018、PJ-041、PJ-054、PJ-042、PJ-045、PJ-058AH、PJ-059AH、PJ-038AH、PJ-039AH、PJ-010AH、PJ-037AH、PJ-050AH、PJ-057AH、PJ-047AH、PJ-051AH、PJ-058A、PJ-059A、PJ-026A、PJ-038A、PJ-039A、PJ-037A、PJ-050A、PJ-057A、PJ-047A、PJ-051A、PJ-058BH、PJ-059BH、PJ-037BH、PJ-050BH、PJ-057BH、PJ-047BH、PJ-051BH、PJ-058B、PJ-059B、PJ-026B、PJ-037B、PJ-050B、PJ-057B、PJ-047B、PJ-051B、PJ-048H、PJ-002A、PJ-002B、PJ-002AH、PJ-002BH、PJ-102A、PJ-102B、PJ-102AH、PJ-102BH 、PJ-202A、PJ-202B、PJ-202AH、PJ-202BH、PJ-003A、PJ-003B、PJ-003AH、PJ-003BH、PJ-007、PJ-012A、PJ-012B、PJ-013C、PJ-013D、PJ-014C、PJ-014D、PJ-016、PJ-019、PJ1-021、PJ1-022、PJ1-023、PJ-025;
SMT DC Power Jacks
==2.5mm Center Pin, SMT DC   panrui.cc
PJ-002B-SMT、   PJ-002BH-SMT 、PJ-006B-SMT、PJ-015B-SMT、PJ-036B-SMT、PJ-036B-SMT、PJ-036BH-SMT、PJ-037B-SMT、PJ-037BH-SMT;
==2.1mm Center Pin, SMT DC
PJ-002A-SMT、PJ-002AH-SMT、PJ-006A-SMT、PJ-015A-SMT、PJ-036A-SMT、PJ-036AH-SMT 、PJ-037A-SMT、PJ-037AH-SMT;
==1.65mm Center Pin, SMT DC
PJ-018H-SMT、PJ1-021-SMT;
==1.3mm Center Pin, SMT DC   panrui.cc
PJ-014D-SMT、PJ-014DH-SMT、PJ-030D-SMT
==1.0mm Center Pin, SMT DC
PJ-014C-SMT、PJ-014CH-SMT、PJ-030C-SMT、PJ-035-SMT、PJ-043-SMT;
==0.8mm Center Pin, SMT DC
PJ-028-SMT、PJ-029-SMT;
==0.65mm Center Pin, SMT DC
PJ1-022-SMT、PJ1-023-SMT、PJ-031H-SMT、PJ-032H-SMT、PJ-038-SMT、PJ-034-SMT、PJ-034-SMT、PJ-039-SMT、PJ-040-SMT、PJ-041-SMT、PJ-042-SMT
==Shielded, SMT DC
PJ1-023-SMT、PJ-030C-SMT、PJ-030D-SMT、PJ-032H-SMT、PJ-032H-SMT、PJ-038-SMT、PJ-039-SMT、PJ-043-SMT
==High Current, SMT DC
PJ-002AH-SMT、PJ-002BH-SMT、PJ-014CH-SMT、PJ-014DH-SMT 、PJ-018H-SMT、PJ-031H-SMT、PJ-032H-SMT、PJ-036AH-SMT、PJ-036BH-SMT、PJ-037AH-SMT、PJ-037BH-SMT;
==PJ-035-SMT : 1.0mm/3.80mm right-angle surface mount power jack, 3 conductor
Mini Circular DIN Connectors
==Modular In-Line Plug
==Modular In-Line Receptacle
==Panel Mount Receptacle
MD-XXSN、MD-XXCV、MD-XXSP、MD-XXPL100
==Non-Shielded, Right-Angle PCB
MD-XXS、MD-XXSS
==Side-Shielded, Right-Angle PCB
MD-XXSM、MD-XXSMS、MD-XXSMK、MD-XXSKS、MD-XXSMW、MD-XXSSW
==Fully Shielded, Right-Angle PCB
MD-XXSF、MD-XXSFK、MD-XXSG、MD-XXSGK
==MD2-XXST : Mini-Din Receptacle, Slim Type, R/A PCB MT Full Shld
==w/Normally Closed Switch, Right-Angle PCB
MD-XXSMW、MD-XXSSW;
==MD2-XXST-SMT : mini-din receptacle, slim type, right-angle, SMT, full shield
==MD-XXSV : vertical mount mini circular connector, 3-8 pins
 Standard Circular DIN Connectors
==In-Line Plug
SD-XX : modular in-line plug, 3-13 pins
==Locking Plug
SD-XXLP : locking din plugpanrui.ccv
==In-Line Receptacle
SD-XXJ : modular in-line receptacle, 3-13 pins
==Locking Receptacle
SD-XXLS : locking panel mount receptacle w/solder tabs
==Right Angle Plug
SDR-XX : modular right-angle plug, 3-8 pins
==Right Angle Receptacle
SDS-XXJ : 3-8 pin, right-angle receptacle without front shield
== Right Angle Receptacle with Front Shield
SDF-XXJ : right-angle receptacle with front shield, 3-13 pins
==Surface Mount Right-Angle Receptacle
SDS-XXJ-SMT : right angle surface mount receptacle in tubes
==Standard Panel Mount Receptacle
SD-XXSN : panel mount receptacle, 3-8 pin
==Vertical PCB Mount Receptacle
SD-XXBV : vertical PCB mount receptacle
RCA Jacks
==RCA Jacks
RCJ-01X、RCJ-02X、RCJ-03X、RCJ-04X、RCJ-05X、RCJ-21XX、RCJ-22XX、RCJ-32XXX、RCJ-33XXX、RCJ-41XXXX、RCJ-61XXXXXX
==SMT RCA Jacks
RCJ-01X-SMT : metal right-angle SMT RCA jack
==RCA Plugs
RCP-01X、RCP-02X
DC Power Plugs, Audio Plugs & In-Line Receptacles
==DC Power Plugs & In-Line Receptacles
PP-012、PP-013、PP-014、PP-015、PP-016、PP-017、PP-018、PP-019、PP3-002A、PP3-002C、PP3-002D、PP3-002B、PR-002A、PR-002B;
==Mono Plugs & In-Line Receptacles
MP3-2501、MP3-3501、MR-2501、MR-3501
==Stereo Plugs & In-Line Receptacles
SP-2501、SP-3501、SR-2501、SR-3501
Cable Assemblies
==Power Supply Output Cord Cables
CA-2222、CA-2223、CA-2224、CA-2184、CA-2185、CA-2186、CA-2187、CA-2188、CA-2189、CA-2191、CA-2192、CA-2193、CA-2194、CA-2195、CA-2196、CA-2197、CA-2198、CA-2199、CA-2200、CA-2221;
==4, 5, 6, Conductor Mating Cables
CA-254-M/M、CA-254S-M/M、CA-254、CA-254S、CA-254C-M/M、CA-254CS-M/M、CA-254C、CA-254CS、CA-354-M/M、CA-354S-M/M、CA-354、CA-354S、CA-356C-M/M、CA-356CS-M/M、CA-356C、CA-356CS
== 2.5 mm, 3.5 mm Audio Cables
CA-2201、CA-2202、CA-2203、CA-2204、CA-2205、CA-2206、CA-2207、CA-2208、
==DC Power Extension Cables
CA-2209、CA-2210、CA-2211、CA-2212、CA-2213、CA-2214、CA-2215、CA-2216、CA-2217、CA-2218、CA-2219、CA-2220
