您的位置:控制工程论坛网论坛 » 产品供求 » 意大利teaflex 电缆线槽/塑料/模塑和踢脚线 PIK系列
czmaizi
czmaizi   |   当前状态:在线
总积分:226  2025年可用积分:0
最后登录时间: 2018-02-06
czmaizi  发表于 2018/1/17 10:21:20      1116 查看 0 回复  [上一主题]  [下一主题]
特点
功能:布线
材料:塑料
组态:成型和踢脚线
PIKD15S COPERCHIO MINICANALE L2000  15
PIKD205050 MINIC. COMPL.L2000 50X50
PIKD30S COPERCHIO MINICANALE L2000  30
PIKD40S COPERCHIO MINICANALE L2000  40
PIKD60S COPERCHIO MINICANALE L2000  60
PIKD60VA COPERCHIO MINIC. L2000 INOX
PIKEKR3015 RIDUZ. TERMINALE CANALE 30X15
PIKEKR4015 RIDUZ. TERMINALE CANALE 40X15
PIKEKR6040 RIDUZ. TERMINALE CANALE 60X40
PIKEK10060 TAPPO TERMINALE CANALE  100X60
PIKEK1515 TAPPO TERMINALE CANALE  15X15
PIKEK3030 TAPPO TERMINALE CANALE  30X30
PIKEK4040 TAPPO TERMINALE CANALE  40X40
PIKEK6060 TAPPO TERMINALE CANALE  60X60
PIKEK8060 TAPPO TERMINALE CANALE  80X60
PIKHK15 STAFFA ANCORAGGIO CANALE 15mm
PIKHK30 STAFFA ANCORAGGIO CANALE 30mm
PIKHK40 STAFFA ANCORAGGIO CANALE 40mm
PIKHK60 STAFFA ANCORAGGIO CANALE 60mm
PIKKSSV30 PROTEZIONE LATERALE    30X30
PIKKSSV40 PROTEZIONE LATERALE    40X40
PIKKSSV60 PROTEZIONE LATERALE    60X60
PIKKSS1515 PARASPIGOLI LATERALE    15X15
PIKKSS3030 PARASPIGOLI LATERALE    30X30
PIKKSS4040 PARASPIGOLI LATERALE    40X40
PIKKSS6060 PARASPIGOLI LATERALE    60X60
PIKKS15060 PROTEZIONE ANGOLI CANALE150x60
PIKKS1515 PROTEZIONE ANGOLI CANALE 15X15
PIKKS20060 PROTEZIONE ANGOLI CANALE200x60
PIKKS3030 PROTEZIONE ANGOLI CANALE 30X30
PIKKS4040 PROTEZIONE ANGOLI CANALE 40X40
PIKKS6040 PROTEZIONE ANGOLI CANALE 60X40
PIKKS6060 PROTEZIONE ANGOLI CANALE 60X60
PIKKS8060 PARASPIGOLI CANALA      80X60
PIKK1515S CORPO MINICANALE L2000  15X15
PIKK3030S CORPO MINICANALE L2000  30X30
PIKK4040S CORPO MINICANALE L2000  40X40
PIKK6040VA CORPO MINIC. L2000  60X40 INOX
PIKK6060S CORPO MINICANALE L2000  60X60
PIKSP5050 PROTEZI.TERMINALE CANALE 50X50
PIKTL60S COPERCHIO DOPPIO MM 60
PIKTVF1515 GIUNTO  T A FILO        15X15
PIKTVF3030 GIUNTO  T A FILO        30X30
PIKTVF4040 GIUNTO  T A FILO        40X40
PIKTVF4040VA GIUNTO  T A FILO  INOX  40X40
PIKTVF6060 GIUNTO  T A FILO        60X60
PIKTVF6060VA GIUNTO  T A FILO INOX   60X60
PIKVI1515 GIUNTO INTERNO CANALE  15X15
PIKVI3030 GIUNTO INTERNO CANALE  30X30
PIKVI4040 GIUNTO INTERNO CANALE  40X40
PIKVI4040VA GIUNTO INT. CANALE  40X40 INOX
PIKVI6060 GIUNTO INTERNO CANALE  60X60
PIKVI6060VA GIUNTO INT. CANALE  60X60 INOX
PIKVL90IS ATTACCO PIASTRA 90°
PIKVWA1515 GIUNTO ANGOLARE ESTERNO 15X15
PIKVWA3030 GIUNTO ANGOLARE ESTERNO 30X30
PIKVWA4040 GIUNTO ANGOLARE ESTERNO 40X40
PIKVWA4040VA GIUNTO ANG. ESTERNO 40X40 INOX
PIKVWA6060 GIUNTO ANGOLARE ESTERNO 60X60
PIKVWA6060VA GIUNTO ANG. ESTERNO 60X60 INOX
PIKVWI1515 GIUNTO ANGOLARE INTERNO 15X15
PIKVWI3030 GIUNTO ANGOLARE INTERNO 30X30
PIKVWI4040 GIUNTO ANGOLARE INTERNO 40X40
PIKVWI4040VA GIUNTO ANG. INTERNO 40X40 INOX
PIKVWI6060 GIUNTO ANGOLARE INTERNO 60X60
PIKVWI6060VA GIUNTO ANG. INTERNO 60X60 INOX
PIKWVF1515 GIUNTO ANGOLARE A FILO  15X15
PIKWVF3030 GIUNTO ANGOLARE A FILO  30X30
PIKWVF4040 GIUNTO ANGOLARE A FILO  40X40
PIKWVF4040VA GIUNTO ANG. A FILO  40X40 INOX
PIKWVF6060 GIUNTO ANGOLARE A FILO  60X60
PIKWVF6060VA GIUNTO ANG. A FILO  60X60 INOX
PIK10060S MINICANALE COMPL. L2000 100X60
PIK1515S MINICANALE COMPL. L2000  15X15
PIK1515VA MINIC. COMPL.L2000 15X15 INOX
PIK20060S MINICANALE COMPL. L2000 200X60
PIK3030S MINICANALE COMPL. L2000  30X30
PIK3030VA MINIC. COMPL.L2000 30X30 INOX
PIK4040S MINICANALE COMPL. L2000  40X40
PIK4040VA MINIC. COMPL.L2000 40X40 INOX
PIK6060S MINICANALE COMPL. L2000  60X60
PIK6060VA MINIC. COMPL.L2000 60X60 INOX
PIK8060S MINICANALE COMPL. L2000  80X60
