您的位置:控制工程论坛网论坛 » 教程与手册 » 嵌入式词汇5
强强
强强   |   当前状态:离线
总积分:4136  2025年可用积分:0
最后登录时间: 2008-03-03
嵌入式词汇5
强强  发表于 2007/9/14 11:51:52      585 查看 1 回复  [上一主题]  [下一主题]
Oscilloscope(示波器)
  A hardware debugging tool that allows you to view the voltage on one or more electrical lines. For example, you might use an oscilloscope to determine if a particular interrupt is currently asserted.
  一种硬件调试工具,它让你能观察到一个或更多电路上的电压。例如:如果一个特殊的中断发生,你可以用一个示波器去检测它。
PROM(可编程只读存储器)
  Programmable Read-Only Memory. A type of ROM that can be written (programmed) with a device programmer. These memory devices can be programmed only once, so they are sometimes referred to as write-once or one-time programmable devices.
  可编程只读存储器。能被设备编程器写的一种ROM。这种内存设备可以被编程一次,所以它们有时被作为写一次或一次性编程设备来看待。
parallel processing(并行进程)
  The ability to apply two or more processors to a single computation.
  一种在单个计算机上运行两个或多个程序的能力。
processor-independent(处理器无关)
  A piece of software that is independent of the processor on which it will berun. Most programs that can be written in a high-level language are processor-independent. Contrast with processor-specific.
  一个与处理器无关的,并能在其上运行的软件。大多数用高级语言编写程序是处理器无关的。相对于处理器定制。
processor-specific(处理器定制)
  A piece of software that is highly dependent on the processor on which it will be run. Such code must usually be written in assembly language. Contrast with processor-independent.
  一个高度依赖处理器的软件,在上其才能运行。一些代码必须用汇编语言编写。相对于处理器无关。
