您的位置:控制工程论坛网论坛 » 工业以太网 » 泓格 设备服务器,RS-232*3,RS-485*1(金属外壳)
szsxry
szsxry   |   当前状态:在线
总积分:405  2025年可用积分:0
最后登录时间: 2021-12-24
szsxry  发表于 2018/11/26 15:39:02      748 查看 0 回复  [上一主题]  [下一主题]
产品介绍: 设备服务器,RS-232*3,RS-485*1(金属外壳)
产品特点:
  • Incorporate Serial Devices in an Ethernet network
  • "Virtual COM" Extend COM Ports
  • Virtual COM on Windows NT 4.0, 2000/XP/2003 and Vista32
  • Powerful Programmable Device Server
  • Watchdog Timer suitable for use in harsh environments
  • Power Reverse Polarity Protection
  • Serial Port +/-4 kV ESD Protection Circuit
  • Self-Tuner ASIC Controller on the RS-485 Port
  • 5-digit LED Display (for versions with a display)
  • RoHS Compliant with no Halogen
  • Built-in High Performance MiniOS7 from ICP DAS
  • 10/100 Base-TX Ethernet, RJ-45 Port
    (Auto-negotiating, auto MDI/MDI-X, LED indicator)
  • ODM Service Is Available
  • Low power consumption
  • Palm-Sized with multiple Serial Ports
  • Made from fire retardant materials (UL94-V0 Level)
  • Supports D/I, Latched D/I and Counter Functions
产品规格:
CPU
CPU80186-80 MHz or compatible
SRAM512 KB
Flash MemoryFlash ROM: 512 KB ; Erase unit is one sector (64 KB) ; 100,000 erase/write cycles
EEPROM16 KB; Data retention: 40 years; 1,000,000 erase/write cycles.
Built-in Watchdog TimerYes
Communication Interface
Non-isolatedCOM1RS-232 (TxD, RxD, RTS, CTS,GND)
COM2RS-485 (D2+, D2-,GND)
COM3RS-232 (TxD, RxD,GND)
COM4RS-232 (TxD, RxD,GND)
Ethernet10/100 Base-TX, RJ-45 port (Auto-negotiating, auto MDI/MDI-X, LED indicator)
PoE-
Data Bit7, 8: for COM1 and COM2 5, 6, 7, 8: for COM3 ~ COM4
ParityNone, Even, Odd, Mark, Space
Stop Bit1, 2: for COM1 ~ COM4
Baud Rate115200 bps Max.
LED Indicators
5-digit 7 SegmentYes, only for "D" versions
SystemRed
PoE-
ProtectionPower Reverse Polarity Protection
Required Supply Voltage+10 VDC ~ +30 VDC (non-regulated)
Power ConsumptionPDS(M)-743: 2.0 W
FlammabilityFire Retardant Materials (UL94-V0 Level)
Dimension (W x H x D)72 mm x 123 mm x 35 mm (88 mm x 123 mm x 28 mm for "M" versions)
InstallationDIN-Rail or Wall mounting
CasingFire Retardant Plastic (Metal for "M" versions)
Environment
Operating Temperature-25 ~ +75 °C
Storage Temperature-40 ~ +80 °C
Humidity5 ~ 90% RH, non-condensing
